Question about Mach Speed TRIO Stealth G2 10.1" 16 GB Wi-Fi Black Tablet Android 4.0, LCD Touchscreen
Why does my tablet need to be plugged in to turn on.
Tried to turn on by pushing the tab on the top of the tablet
    Problem Solver:
  • 8 Answers
My best guess is something has changed in its configuration, either hardware or, more likely, software.
I don't know that model, assuming that the tab is the power switch:
What is the last thing you did before the tablet stopped working 'right'?
Did you attempt to start it using any other combinations of buttons. (you might have accidentally restored it to its original OS version and configuration settings which may have been for a bench tech repair setup)
Is the battery fully charged?
Did someone try to upgrade the OS?
Posted on Nov 25, 2014
    Problem Solver:
  • 14 Answers
Two things, 1) The battery is finished.
2) On/off switch is broken.
Good Luck,
dean.
  • Betty-Jane
    Betty-Jane Jan 17, 2015
    this is a replacement. only turns on when it is plugged in to an outlet
Why won't my Samsung Galaxy Tab 4 turn on?
Try to charge it even more before pulling out the charger and trying to turn it on
Oct 08, 2015 | Samsung Tablets & eReaders
How do I turn my Samsung galaxy 10.1 2014 edition tablet on
hi,
to turn your
Samsung galaxy 10.1 2014 edition tablet on you need to long press the power button which is at the top-right side of the tablet.Hope youo get your problem fixed. Thanx
Feb 11, 2015 | Samsung Galaxy Tab 101 Tablet...
When I plug the headphones into my Samsung Galaxy 10.1 tablet, the sound comes from both the headphones and the speakers on the tablet, shouldn't the speakers be turned off by the headphones?
This can be a hardware (bad headphone jack) or a software (rom update) issue. If the tablet is in warranty, try taking it to your dealer and see if they have a fix.
Otherwise, some people have had success doing one of the following:
1. Plug headphones in after starting music. Watch for headphone icon to appear on screen, meaning tablet has recognized that headphones are attached. Make sure plug has been put into socket all the way.
2. Install app SoundAbout on your tablet and see if you can route sound to headphones only.
3. Check Settings/About Device to see if there is a software update for your tablet. Install the update and see if that fixes the problem
Jan 12, 2015 | Samsung Galaxy Tab 101 Tablet...
My kocaso tab wont turn on whille charging
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Dec 28, 2014 | Kocaso Sx9700
On my samsung galaxy 3 tablet my gmail wont log on. i tried changing my password and restarting the tablet and that did not work either please help
Are you pushing on the correct app there are two email apps one reads gmail and the other has a @ mark maybe you need to check which one you put your address under. Hope that helps.
Aug 02, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
My 7 inch Samsung galaxy tablet will not come on.
have you tried turning off tablet with charger plugged in and letting it charge up. You should see a battery symbol come onto the screen with a pulsing level indicating the battery is being charged. hold in power till unit turns off then plug in charger cable into tablet and switch on charger at power point . Do not try and push power switch to power up tablet see if screen indicates charging is occurring. I have experienced this exact problem on a samsung tablet !
May 03, 2014 | Tablets & eReaders
Galaxy tab 10.1 frozen
Remove the battery and memory card, wait 60 seconds for the processor to reset, and power up.
Jul 11, 2012 | Samsung Galaxy Tab 2
I have a HP Compaq tc4400 tablet pc. The battery light flashes 8 times then stops when I try to turn the pc on. I can't find anything in any of the documentation that tells what the problem is. The...
Sorry about this.
Have you tried charging your tab to full capacity first. You need to plug it into ac mains and leave for a few minutes to allow the battery get some charge on/in it.
Secondly, I am persuaded your tablet PC is windows OS (I stand to be corrected on this please).
Was the system board confirmed fully configured/operational with all drivers installed?
Aside of drained battery in need of charge or boost; suspected fault may have to do with getting your tab PC to initialize boot sequence.
Oct 10, 2017 | Compaq tc4400 Tablet PC
When I turn on M275 I get power light, hard drive
I have the same M275 tablet and was looking for a solution when I came across your post. I couldn't find a solution so I went over every nook and cranny of my tablet and found my hard drive was not completely pushed in. I pushed it in tried the power button again and it worked! I am shocked because my laptop has been down for a year now. I thought maybe it was a motherboard problem and it was junk. I'm so excited. Anyway all I can suggest is check that the hard drive on the right side is completely plugged/pushed in. I hope that works for you.
Feb 06, 2010 | Gateway M275 Tablet PC
Mach Speed TRIO Stealth G2 10.1" 16 GB Wi-Fi Black Tablet Android 4.0, LCD Touchscreen Logo
87 people viewed this question
Top Mach Speed Tablets & eReaders Experts
BrikimG
Level 1 Expert
David Payne
David Payne
Robert Graf
Are you a Mach Speed Tablet and eReader Expert? Answer questions, earn points and help others
