My zoom studio says error when I try to burn a disc it's an mrs-1044
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
Try selecting a lower burn speed.
Posted on Nov 26, 2014
Zoom mrs-1044 says error when I try to burn a disc
Is it possible to post the actual error or error code you receive when you try to burn a disk. This will give me a bit more information to work off of to help provide a solution for your problem. Thanks!!
Nov 25, 2014 | Computers & Internet
TOSHIBA Disc Creator 2.1.0.2 give me Error Code: 380381-26-51037200 when I try to burn a DVD (Data Disc). I have a TOSHIBA Satellite PSL 40E laptop with Win 7 Ultimate. Can you help me to solve the...
Have you tried using another software ? One like
http://www.softpedia.com/get/CD-DVD-Tools/Data-CD-DVD-Burning/Ashampoo-Burning-Studio-Free.shtml
Nov 11, 2010 | Computers & Internet
I can not play my dvd on sony dvd player i get message canot play.i have a sony dvd recorder in which my laproscopic surgeries are recorded.if i play my unedited dvd on player it runs or plays very well...
My guess is the Pinnacle software isn't writing correctly. Read this from the Pinnacle support site.
Use this FAQ to troubleshoot any problems where Studio is failing during the process of burning the DVD.
  1. INSTALL THE LASTEST PATCH:
If you have Studio version 12, download the latest version here.
If you have Studio version 11, download the latest version here.
Note: Studio 11 patches will only patch a previous install of Studio 11.
If you have an older version of Studio (Studio 9, 10, or 11 etc), it is advised for you to update to the current Studio software. The current version is Studio 12. Click Here to go to the Studio 12 Upgrade page.
How to download and install a patch:
  • When downloading the patch make a note of where it is being saved to. We recommend saving the patch to the desktop.
  • Before installing the patch, make sure that you do not have any other programs running. Studio must not be running.
  • Once it is fully downloaded, double-click on the patch to begin the installation.
  • Follow any on-screen prompts to complete the installation. Reboot the computer after applying the patch.
  1. MAKE DISC SETTING, SAFE MODE BURN OPTION: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Safe Mode: create disc content and then burn" by clicking on the radio button in front of the setting and then click OK. While troubleshooting this problem, always use this setting.
  1. RESTART STUDIO: Shut down Studio, then relaunch it. Try to create the DVD again using the safe mode setting above.
  1. RESTART THE COMPUTER: Try opening the door of the DVD burner. If it won't open, then shut down Studio, then restart the computer. Launch Studio and try to create the DVD again using the safe mode setting.
  1. MEDIA:
BLANK MEDIA IN THE DRIVE: Make sure that there is a blank, write-once media or rewriteable media in the DVD burner.
TYPE OF DVD: Make sure that your DVD burner supports the media you use. As for any problem with burning a DVD, we recommend customer use rewriteable media to reduce the number of wasted DVDs when they have to troubleshoot a failure while burning DVDs. In this case, if you have only used rewriteable media, (RW) we would also recommend trying to use a write once (-/+ R) DVD and erasing the RW media.
BRAND OF DVD: Pinnacle recommends using a name brand of DVD, i.e. Sony, Apple, Memorex, etc. Also we recommend trying a DVD from a different manufacturer to see if the problem is related to the brand of DVD that is being used.
NOTE: Check with the following site to find information on the media being used.
http://www.videohelp.com/dvdmedia
  1. LOWER THE WRITE SPEED: In the Make Disc settings try lowering the Write Speed to the lowest possible setting.
  1. GET THE LATEST FIRMWARE: Ensure that the DVD burner being used has the latest firmware update from the burner manufacturer.
  1. CHECK DISC SPEED: Make sure that the disc media speed (printed on the media or on the media box) is compatible with the DVD burner. Some burners may not work with media that has a higher maximum supported burn speed. For example, if the burner being used supports 4x disc media, do not use 16x disc media.
  1. DELETE AUXILIARY FILES: Try deleting the Auxiliary Files for the current project. To do this, go to File -> Delete Auxiliary Files and select "Delete auxiliary files for current project." Press OK and try to re-render and burn the project.
  1. ALWAYS RE-ENCODE: Go to the Make Disc settings and check the box called "Always re-encode entire movie".
  1. SAFE MODE: Try burning with the safe mode option selected. To do this, go to the Make Disc settings. In the Burn options are select the option called: "Safe mode: create disc content and then burn.". This step does not apply if you are using Studio 12 since this is the default burn method.
  1. CREATE A DISC IMAGE: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Create disc content but don't burn" by clicking on the radio button in front of the setting and then click OK. Then click the Create disc button in the Make Movie section to begin the image creation process.
    If the image is not created, it is likely that the problem is a Render problem rather than a burn problem. Click Here to see the FAQ on Render problems.
    If the disc image file is created successfully, burn the disc from the new disc image by selecting "Burn from previously created disc content" in Burn Options.
    NOTE: When troubleshooting all burn or playback issues, it is recommended to use rewritable media to avoid wasting discs.
Nov 04, 2010 | Sony DVP-NS530 DVD Player
I get an error message to use a blank or erasable DVD
I would try simply copying one of the already completed discs using a stable and well known burning program like Nero. Programs like Pinnacle can be very temperamental when exporting their projects to disc.
Jul 19, 2010 | Gear Head 8XDVDEXT DVD External Slim...
Whenever I try to burn a disc on Pinnacle 12 Ultimate the burn fails. Then it tells me that I need to use an empty or re-writable dvd. I then used an empty re writable dvd and still the burn failed, and it...
The new Pinnacle Studio 12 includes more than 25 new features and more than a ... This is an upgrade. so you need Pinnacle studio 11 first. ...... could you tell me if u have tried that on a different computer with out ..... of data of the Pacific and burn it then because a compact disc and then the ...
thepiratebay.org/.../Pinnacle_Studio_12_Ultimate_-_by_Mick_(Full_Version)
Jul 18, 2010 | Pinnacle Studio Ultimate 12 for PC
My zoom multitrack says "check disk"
http://www.zoom.co.jp/archive/English_Manual/E_MRS1044v2.pdf If this is the model you have you have to format the hard disk before using it the first time. You may also have to restore the machine to factory settings using the recovery disk that came with it. The link is to the download for the manual.
Aug 07, 2009 | Music
Burned DVD will not play
Try burning it with another burning software like Nero, sometimes studio pro burns in an extention assigned to this particular macpro, try other type of DVD discs too, it will work eventually
Mar 12, 2007 | Apple DVD Studio Pro 4 for Mac
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
