Question about LG 50 50PZ550 50 3D Plasma TV
How do i fix my lg plasma tv that has screen filled with multi collored vertical lines abd screen showint three bands of color green, light green and purple?
No attempts
    Top Expert:
  • LG Master
  • 6,702 Answers
If you have to ask this, I assume you don't have the kills to repair a plasma TV. Then please don't start this. Opening it can be very dangerous, and without the technical skills, you even don't know where to look for. Most to the time I advice to visit ifixit, but this time they don't have the manual or video for LG. Perhaps they can show you some openings. But they never show you how to rebuild.
They can help with spare parts. So if you really want to do this yourself. On your own risk:
Black screen on my LG plasma TV model 50ps60 LG Television
Posted on Nov 25, 2014
  • 31 Answers
SOURCE: 50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
Posted on Mar 10, 2008
  • 6 Answers
SOURCE: Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Posted on Mar 23, 2008
Kindofcheap
  • 241 Answers
SOURCE: 42inch LG plasma TV
well if you could please give out the model nuumber thank you
Posted on Sep 10, 2008
gsalmen
  • 77 Answers
SOURCE: thin red vertical lines on left side of 50
this is not an easy fix. the screen ,or the x or y screen drivers are bad .
Posted on Jul 10, 2009
SD Tech
  • 14553 Answers
SOURCE: LG 50PK550 Plasma Single Thin Green Vertical Line
It is going to be one of two basic issues:
1. There is a poor connection somewhere in the set--either with a plug or cable or on one of the boards.
2. There is a board that is beginning to fail causing this.
Either would require a shop and may or may not be worth the cause.
Having seen hundreds of these sets all are more prone to flaky problems than the older sets and average life span is 3-5 years.
Shop I work for 80% of them are 2 years old or less.
If problem began shortly after set was moved or relocated I would lean towards a bad connection somewhere.
Posted on Mar 17, 2012
LED LG 55LS4500 multi color vertical lines no picture but do have sound, what causes this?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 23, 2016 | LG 55LS4500 55 in. TV
I have an LG 2009 60ps60 plasma TV with multi color vertical lines on the left side of screen. Is there a board I can change to correct this problem??
1. Identify the TCON board.
2. Reset the Left side ribbon cables on the T-CON board
3. Replace CON board if you find a spare
Apr 13, 2016 | LG Televison & Video
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Vertical green line
? 4:45
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Several thin black vertical lines in picture. Picture color also very distorted, including menu screens.
First check the menu setting of collor.Try to decrease the color adjustment.If did not work.Your TV have loose board problem.Try to resolder the board.
Oct 05, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Mar 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
Plasma tv vertical lines
I am getting a vertical green line on my lg 50 incs is the screen or have you a solution
Sep 03, 2006 | Sony WEGA KZ-42TS1 42 in. Plasma...
LG 50 50PZ550 50 3D Plasma TV Logo
224 people viewed this question
