Hi, i have ONHF 6117 Hoover washing machine which i dropped while moving house the problem is there no motor action, i had someone look at it he changed the pcb module board, motor and pressure switch
Changed module board, motor and pressure switch also checked wiring wasn't broken
  • 1,358 Answers
Door switch comes to mind, how far was the drop ? does the lights or motor buzz ? did the power cord get pulled on ? check with a volt meter at were the power cord attaches to the unit. GOOD ? = then check every last plug in the unit, to make sure it is seated properly into it' respective socket.
Hope this gets ya running again. ask if you need more help, and don't forget to vote if i was of help
Posted on Nov 25, 2014
heatman101
  • 43501 Answers
SOURCE: pressure switch keeps onening
Replace gasket, but you also could have water or some other obstruction in the vent pipe. Bees, bird, etc...
Posted on Nov 12, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: 3 flashing light....Aire-Flo furnace AF80MPA100B5A
That control board is several hundred dollars. If I may make a suggestion, take a jumper and when the inducer fan starts, jump out the pressure switch. If it starts, it's not the board but a bad switch, hose or blocked exhaust vent.
Posted on Jan 15, 2010
  • 182 Answers
SOURCE: boiler starts up for a few seconds then cuts cuts
This could indicate flame failure. may have a failed igniter. model and serial number if you have it.
Posted on Dec 17, 2010
james1barret
  • 27 Answers
SOURCE: My burners are not lighting up. circuit board said
So, 2 things you want to check here-
First, the circuit board that controls that pressure switch can be bad and thus giving a faulty message pointing to the pressure switch, when it really may be the board that is bad.
Second, the pressure switch detects proper pressure for the inducer motor all the way through the venting- it seems like you already checked that but you may want to do a double check( I often over look simple blockages on the termination outside).
Hope this helps, James
Posted on Jan 05, 2011
Testimonial: "It was the circuit board giving the wrong message, I could not get pass what I was seeing. Thanks"
  • 1015 Answers
SOURCE: These is day three and I'm having the same
Sounds like you have tried about everything except the gas valve so I would change it and see if that solves your problem. You said you are getting 24 volts to gas valve but the burners are not working then I think you are going in the right direction. Good luck. Thank you.
Posted on Jan 06, 2011
Hi, i have ONHF 6117 Hoover washing machine which dropped out of my van while moving house the problem is there no motor action, i had someone look at it he changed the pcb module board, motor and pre
All washing machines have a switch that is activated when the lid or door is closed. This tells the machine its safe to run the motor. If this thing dropped out of a van, it's possible the housing twisted and the little metal bracket on the door is not making contact with the safety switch or the switch may now be broken.
Nov 25, 2014 | Hoover Washing Machines
Hoover 1400 AAA washing machine tripping house fuse
Possible that the control panel is short and so is tripping the fuse. Remove the connection to the panel and check if there is short , also remove the motor and check and this can confirm the case.
Jul 03, 2012 | Hoover Washing Machines
Not working at all. my washer was on working and i heard a big bang and my electrics went off, i turned everything back on and the washer started up again but then stopped and now will not work. when...
The ticking that you hear is probably the timing motor for the dial.
Was the "bang" from outside the house? If so, then a transformer probably blew and hit your house with a power surge. Motor is likely damaged, and will need replacement.
If the bang was inside the house, the capacitor on the motor probably blew (unusual failure mode though), and will need to be replaced, motor is likely damaged as well.
Sep 18, 2010 | Hoover Washing Machines
I have a Hoover top load 610 and it wont start wash cycle
These are a great little machine,I dont know why they have to go changing things.Anyway this sounds to me like the timer.It fills & the water cuts off so the inlet valve is ok.It drains so the pump is ok.It spins so the motor should be ok.Try it on other cycles like gentle or delicate & see if it agitates.I'm sure it will be the Timer.
May 22, 2010 | Washing Machines
Hoover AL 120 washing machine won't spin
i would check the motor carbons it could be your problem if it fills goes through the programme until the end but has motor action
Apr 12, 2010 | Hoover AL120 Front Load Washer
Hoover error E08
hi I had this fault, google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on youtube http://www.youtube.com/watch?v=xYn-f78GB4U and it shows you how to test the tacho and how to change the brushes, hope this helps someone
Oct 02, 2009 | Washing Machines
Hoover Elite 1205 washing machine
Does an Hoover elite 920 gearbox fit the hoover elite 1205 thanks
Sep 18, 2007 | Washing Machines
How to use hoover ac121
normally the numbers are the same for all uk machines, if the previous washer you used had numbers on it, just remember them and use them as you would, so if a number 2 was a 90 degree boil wash them it would be the same number for all uk machines, that is my experience, or older machines had letters example letter D = non fast coloureds
Aug 30, 2007 | Hoover Nextra HNWL 3136 Front Load Washer...
My Hoover Model Not listed/stops during the cycle
the cycle timer is beginning to sieze because it needs oil. disassemble washer to the point where you can apply small drops of 30W machine oil to the timer's bearings
May 20, 2007 | Hoover HTC243 Top Load Washer
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
