Question about Rinnai Heating & Cooling
I just moved into an apartment with a Rinnai energy saver gas heater. It is incremented by 4 degrees...60,64,68,72 etc. 64 is a little too cold and 68 is a little too warm. Do you know of a way I c
I just moved into an apartment with a Rinnai energy saver gas heater. It is incremented by 4 degrees...60,64,68,72 etc. 64 is a little too cold and 68 is a little too warm. Do you know of a way I can set it to 66 or 67 degrees? Any help would be appreciated!
  • 1,340 Answers
Sure, try using a small (desk) fan to move air around the apartment this will allow for more even heating.
hope that fixya up . give me a vote if'n I was of help.I love praise, it's the fuel that keeps me fix'n yer stuff.. Jay
I just moved into an apartment with a Rinnai energ - c3322dbd-a12d-4b35-bf1c-67f50b75350a.jpg
Posted on Nov 25, 2014
Testimonial: "I actually have two ceiling fans that are moving the air about. Thank you for your input although this didn't really answer the original question. I very much appreciate your response. Your idea is a good one in general for everyone."
  • Jay Finke
    Jay Finke Nov 26, 2014
    Well ok try .Rinnai Thermistor Assembly For RHFE-1004 and ES38 Heaters - 1004F-2057 it's a $20 part SEE picture I added (it should look similar to this) and should be a easy fix.. .for others.. you thermostat might be getting air from inside the wall, the wires that hook up to that stat must sealed so no air can bleed threw from the wall . hey you guys the mor info you give us fixya guys like model numbers or pictures make answering questions fun and allot easier on us.. Thanks .. jay the pool pump motor repair guy in longwood florida.
  • Jay Finke
    Jay Finke Dec 05, 2014
    did you get it going? Thermistor are are the highest fail part in this scenario , and can be a easy fix for the average new fixya member, it's a cool fix that can saveyou hundreds of $
Therinnaiguy
  • 1420 Answers
SOURCE: error code 11 on my rinnai
A code 11 also means that it might not be getting any gas. On thr right side of the unit you will find a small door. open it up and make sure the valve is in the open position. If it is, you should contact your gas company to come and diagnose what is going on. The Rinnai is not a do it yourself fix it type of heater.
Posted on Nov 07, 2007
  • 126 Answers
SOURCE: Rinnai heater turns itself off
Dannizen,
You could have something as simple as an air hose off, or a piece of carbon on the flame sensor. Your problem could also be a gas valve , which is much more complicated. If you are handy with tools you could be able fix either quickly. If you’re not good with tools you will need to get some help. Either way you have to have some back ground info on your heater. Get in touch with Rinnai and get a service manual for your unit. They cost around $15. If you have to call a service guy, use the Rinnai web site to find an authorized service person. Don’t just let your fingers do the walking and get some guy who has no idea what a Rinnai is. You’re only asking for trouble there. Your unit is a little older so don’t be surprised if parts are hard to find.
Good luck,
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Posted on Mar 07, 2009
  • 53 Answers
SOURCE: Rinnai Energy Saver 302 convection gas heater has
Energysavers have fixed flue lengths, more likely your problem is the thermistor at the bottom left of the heater inside the grille getting a false temp reading. Look for yellow wire with a black bulb (like a drop of water). measure the air temp next to it while heater running, if its above room temp down there the heater will turn off early. It needs to be clean and have unobstructed air flow over it for it to work correctly.
Posted on Jul 18, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Rinnai Energy Saver 1001F
Try this link http://www.rinnai.us/documentation/downloads/Owners_Manual_1001-551.pdf
Posted on Sep 09, 2009
  • 120 Answers
SOURCE: how do i clean the
Here is a link to the users manual
http://www.rinnai.us/documentation/downloads/ES38_1004RFA_Manual.pdf
Check out page 10. As it shows the filter slide up from the top rear. Use a brush or vacuum cleaner.
Posted on Sep 16, 2010
My rinnai 556fa thinks that it is 10 degrees warmer in space than setting and won't come on???
Where is the room sensor? High on the wall will be warmer than close to the floor.
Tom
Sep 30, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Our heater seems to have therostat set low. We are cold.
not sure if this unit has any type of sensor to protect you from carbon monoxide but if it is ventless and operates on gas it may be tripping on sensor any ventless unit must be operated with fresh air for combustion
Apr 06, 2009 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
Rinnai 556F Not Exactly and "Energy Saver"...
Raise the thermistor. It is a black rubber probe located on the back of the heater close to the coldest spot in your home, the floor. Raise it a few inches. To do this you will need to unhook it from its holder and open the front of the heater to unravel the extra length of yellow wire.
Jan 24, 2009 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Rinnai 1004 heats to a temp 4 degrees higher than set temp, adjustment?
You can adjust the position of the room air sensor found on the back of the unit between the heater and the wall. It is a black rubber bulb with yellow wires. There is a few inches of extra wire you can extend higher to get a more accurate reading of room air. While you are back there, check for drafts that will give you false readings.
Sep 23, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 551FT (I couldnt see it on list!)
Try vacuum cleaning the filter as the heater shuts down to protect itself from over-temperature. NB-turn off the heater before doing it. And yes, you add water to the tray (...carefully) - this increases the apparent heat. Peter
Jul 15, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
91 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
