Question about Honeywell TH8110U1003 VisionPRO 1H/1C Programmable Thermostat with
My thermostat showing on screen 76F when really room temperature is 70F and I HAVE MEASURED PROPER room sensor resistance OHMS to real room temperature. Why thermostat showing higher temperature and n
Why thermostat showing 6 degree higher temperature like really is in the room if room sensor value is proper to real room temperature.
  • 52 Answers
Where is the thermostat in relation to the return? Is there air flow or is the air stagnant in the area of the thermostat. Have you placed a thermometer in varios locations where the thermostat is located? Try these locations and see if the thermostat needs to be placed in a location better able to reflect room temperature. Also how long have you lived in the house? If it is a newer home I suggest that you contact the builder or the air conditioner/heater installer to see if they have a schematic of the placement of the thermostats.
Posted on Nov 25, 2014
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
My Eden pure model Gen 3 doesn't turn on ? The red light on front is lite and filter is clean Why not
Edenpure has a troubleshooting guide at this website: MY HEATER WILL NOT TURN ON.
  • Make sure the power source is good. Plug in a lamp to see if it works correctly.
  • Make sure the front power switch/button is set to the "ON" position.
  • Unplug the power for 30 minutes. Plug the power back in and try operating the heater again. This will reset the internal sensors.
  • Some heater models are designed to be operated in temperatures less than 75 degrees Fahrenheit. The heater will not operate when the temperature is too high. Test the heater in a room that is below 75 degrees Fahrenheit.
  • Bring the heater inside to warm up for at least one hour before operating if it has been stored in a freezing or near freezing environment.
  • Make sure the filter is clean.
  • Remember, it will take a few minutes for the heater to warm up. The fan will start to blow after the heater has warmed up.
Heaters FAQ
Dec 07, 2016 | Air Purifiers
New a/c - furnace installed, no instruction manual, it is 23 degrees outside, and I have no idea how to turn on heat instead of a/c. Need thermostat instructions.
Usually just put the thermostat fan on auto, the a/c heat switch to heat and set the temperature where you want it. If it's a gas furnace, you will need to light the pilot. Usually instructions are on the furnace door, maybe inside furnace door.
Dec 05, 2013 | Air Purifiers
Temperature Coulant Sensor
Under hood, driver side, upper engine area, mounted in end of cylinder head
Jul 15, 2013 | AM Auto Parts 2006 VW Touareg Mass Air...
Xl-115 Automatic setting not working?
your sensor board has failed , a realy common problem , most if not all are dead and no parts are made for it ...... you do not need the sensor anyway it was only installed as a knee **** reaction to fda worrys of ozone levels over 0.05 ppm in bedrooms . so the board was installed to cut at 0.05 ...... it was a failure , so a bypass switch was added to get around the problem board ... just set on man , adjust for your sq ft ... you will be fine
Sep 08, 2009 | Ecoquest Living Air Classic Air Purifier
Broken internal wire
There are no replacement parts for these devices. the parent company that distributed these units are no longer servicing the units. Sharper filed for bankruptcy two years ago.
Jun 15, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Have a Living Air XL15 > everything works motor, fan, BUT .....
look through the front grill while its "on" you should see a glow from a neon lamp inside. If its not on chances are the circuit card is dead (should have about 350VDC plate voltage).
I have a used but good board if anyone needs one.
dale.gilchrist@gmail.com
Apr 26, 2009 | Ecoquest Living Air Classic Air Purifier
Ionic breeze quadra not functioning
I had the same problem and could not find an answer anywhere. So here's what I figured out. The small wires running from top to bottom just inside the cover are your problem. Not the metal grid with plates that you can remove. The buzzing sound you heard is the resistance one or more of the wires is causing. The resisitance tells the pc board that your grid must be wet and therefore the unit goes into drying mode. I replaced my small wires and my unit is working better than ever. The wire is .005 diameter( important so that you keep the same resistance flowing to the pc board) and can be purchased at any good suppy house. I have since repaired another unit with an even simplier fix. I took the unit into a dark room and then turned it on. Watching the grid I could see the wire arching that was causing the resistance. Unplugged the unit, turned it over and with a flat head screw driver pushed the wire off its base connedtion. Turned the unit right side up and removed the wire from its top support. The unit works fine without the troubled wire. Hope this helps.
Apr 04, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Honeywell TH8110U1003 VisionPRO 1H/1C Programmable Thermostat with Logo
100 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
