Question about Hardware & Accessories
How do i reset Clarity ctvl37w2hdf led tv or at least set the timer to off?
I go to settings but there is no timer off setting it just says timer on and when you click on that a clock comes up with no option to actually turn it off
    Problem Solver:
  • 12 Answers
To reset the tv, hold the power button while you unplug the TV. Keep holding the power button for :15 seconds, then release it and turn the power back on. That should reset any timer.
Posted on Nov 25, 2014
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
How do I reset my LG 55"UHD LED LCD 100Hz Model No 55UBB850t TV. When tv was initialy set up we said yes to set top box accidentally but we don't have one. I have TV running through Austar but we ha
http://www.lg.com/us/search/srch_manuals-tab?customerModelCode=55UB8500&mobileFlag=N#
Restoring the Default Settings
mr14_home.png ">w14_settings.png ">General > Reset to Initial Settings
Delete all the TV settings data and reset the TV. All the options in the Settings Menu will be reset to the default settings.
After reset, the TV will automatically turn off and on.
Type the password to Reset to Initial Settings
Do not turn off the power during initialization.
Jan 04, 2015 | LG 55" Black UHD 4K LED 3D Smart HDTV With...
Sound goes off after 15 Min
Assuming it is not hardware but soft settings...
1) Check and make sure that your TV does not have the timer set.
The Timer feature allows you to set a day and time for the TV to turn on automatically and the device and channel to display when it switches on. If the TV is already on at the requested time, the TV automatically tunes to the channel you designated in the Timer menu.
When the Timer turns on the TV, the following message is displayed: "Press a button for the TV to stay on." Press any button on the remote control within five minutes if you wish the TV to remain on.
Note: The TV clock must be set before you can use the
Timer feature (see preceding page to set the clock).
On/Off
Press down arrow / up arrow to enable or disable the Timer.
2) If not working, try SYSTEM RESET. Press SYSTEM RESET button on the front panel with pointed object (e.g. straight paperclip). TV turns off, green LED flashes for about 1 minute. When it stops flashing turn the TV on again. All settings other than Parental Lock need to be set again using the manual.
3) TV RESET. If all else fails for soft error. Your manual describes this last resort for soft type error. It could be hardware problem needing more expertise.
Manual can be viewed on a computer at
http://www.audiolabga.com/pdf/V32-V32L_Service_Manual.pdf
Aug 05, 2014 | Mitsubishi WD-62531 Projection Television
I have a mitsubishi WD 6573TV. Sound Issue. Last night I came home and have picture but no sound. I completely powered it down and let it set overnight. Came in today had sound but could not control
Try a "REBOOT"
Reset, Initialization &
Option Menu
Front Panel Reset & Initialization
Many customer generated symptoms, intermittent symptoms
or symptoms that cannot be duplicated can be resolved
by performing resets or initialization from the front
panel. To avoid making nuisance service calls that may
not be covered under the warranty, ask the customer to
perform the following functions before going to their
home.
The most common are:
• System Reset (Re-boot)
• A/V Reset (Resets Customer Audio/Video
Settings)
• Initialization (Resets all customer options,
settings and menu items)
Use the Front Panel Guide as a reference to quickly
perform the desired function. Note: Button location may
differ by model.
The Reset - Initialization Guide details all resets and initialization
functions.
Front Panel Guide
FRONT PANEL
1) SYSTEM RESET1 - Reboots Set
(Same as Cycling AC Power)
Power LED will flash for about
1 minute.
2) A/V RESET2 <FORMAT+GUIDE>
Resets all Customer Audio/Video Settings
FORMAT GUIDE INPUT
ENTER CANCEL
SYSTEM
RESET
MENU
VOLUME
ADJUST
CH
ADJUST
3) INITIAL2 <FORMAT+INPUT>
Resets all Customer Menu and
A/V Settings
LED DIAGNOSTICS3 <INPUT+MENU>
In case of failure, a 2 digit error code will
be indicated by the POWER/TIMER LED.
1 Perform while the set is either On or Off. (See section on LED Diagnostics)
2 Perform while the set is On.
3 Perform while the set is Off.
Apr 21, 2014 | Mitsubishi WD-65731 65" HDTV
Flashing timer led
There is no reset button like in the old days. You can reset the microprocessor to it's default state by unplugging the set, let it stay unplugged for 10 or more minutes. Plug the set back and it will reset itself.
You might lose stored channels and settings but they will all be reset to the manufacturers specs. This is true for anything that has a microprocessor (computer) in it.
Apr 19, 2010 | JVC AV-32D502 32" TV
TV won't turn on
Have you tried switching inputs? On some sets if it is set to s video all you get is a dark screen. Check your connections if you have other inputs. If you can't switch you should at least get the menu on the screen proving the tv is working and it is a setting.
Sep 18, 2009 | Televison & Video
Model WD-57731 LED Timer Light
You have a dm board problem could be the capacitors or you may need to change the entire board.
Sep 16, 2009 | Mitsubishi WD-57731 57" Projection HDTV
JVC AV-32260 timer led flashes
When your set first turns on it runs a systems check to see if the boards inside are safe to apply voltage to. also it checks the power supply to see if it is safe to power up.
Either it needs a factory reset which the procedure changes for each model. or it simply has more wrong with it after the surge and requires more to fix it then the cost of a new set.
The best bet is to look on EBAY for a similar set with something like a broken screen. swap out your screen into its chassis.
if you do not feel up to the challenge of doing that you may be looking at repair costs and parts that are more then a new set.
Apr 30, 2008 | Televison & Video
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Blinking Stand By/Timer LED
You can try this on the remote in standby mode, meaning tv plugged in but set off. Press Display,5,vol+,power on remote.Press each button within a 1 sec interv. Next the CRT display the item being adjusted. Press 1or4 on remote to select item. 3or6 to change the data. Press Muting then Enter to write into memory. Service Reset muting green enter red. Press 8 then enter on remote to initialize. turn set off to exit. wait least 10 sec. before turning back on.
Sep 10, 2007 | Sony KV-32V40 32" TV
Hardware & Accessories Logo
82 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
