How do i use only the manual button to switch on and off?
  • 141 Answers
Hold the button down for 5 seconds or so to power it off
Posted on Nov 25, 2014
PROGRAMING SWITCH TIMERS
1) Copy following links to help identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
2) Add a comment and describe timer in detail, including what the timer does, and what buttons appear on timer face, and location of each button.
Feb 15, 2013 | Intermatic Inc. EJ500C Digital Wall Switch...
Reeeeeeeeeeeeeeeeeeeeeeeeee
  • Hey, nofarmark91
    Turn the Coleman furnace system switch to the "Off" position on the electric service panel.
  • Locate the manual reset switch near the left side of your furnace blower. Your Coleman furnace has an upper limit switch for manual reset and a lower limit switch for automatic reset.
  • Press the reset button, which you will find in the middle of the limit switch. Use this manual reset button when the furnace burner will not operate. (See Reference 1 pg 4 "The Furnace Controls and their Function/Important" & Reference 4 # 3)
  • Turn the system switch to the "On" position.
  • Good Luck
    Jul 29, 2012 | Coleman Heating & Cooling
    I have a ET100C and the lights will only stay on for a few seconds in both manual and auto modes
    Before you attempt any reprogramming, you might be better served by performing a RESET on the clock. TO RESET TIME SWITCH COMPLETELY: Press the recessed RESET switch for five seconds to remove all eight available events and to reset time of day clock to 12:00 A.M.
    After resetting, try reprogramming again. The procedure below is copied from the manual (which can be downloaded here):
    TO MANUALLY TURN ON OR OFF: Program Selector switch must be in RUN position. In AUTO or MANUAL Press ON/OFF button. Display indicates load is either on or off.
    TO SET TIME: Slide Program Selector switch to TIME SET. Press HOUR and
    MINUTE buttons individually to select current time of day. Note that clock is a 12 hour AM/PM repeating clock.
    TO SET OR CHANGE PROGRAMMED SET POINTS: Select PROGRAM mode with Program Selector. Note that the event display shows Event #1. There are eight possible programmed events. Four ON and four OFF which are programmed alternately. All available events need not be used.
    Press the HOUR and MINUTE buttons separately to program the first ON time
    desired. Note the ON indicator (OFF in the next step) will only be displayed after the hour has been selected unless an ON time was previously entered.
    Press EVENT button. The display now shows the next Event #2. Press HOUR and MINUTE buttons separately to select first OFF time or Event #2.
    Press EVENT button to select Event #3. This is the second ON time. Program the ON time by pressing the HOUR and MINUTE buttons. Repeat this procedure for up to 4 ON and 4 OFF times (8 Events) as required. Return Program Selector switch to RUN Position. Be sure Manual/Auto switch is in the AUTO position.
    TO OVERRIDE PROGRAM: Program can be overridden at any time by selecting the MANUAL position. Program set times will be maintained but will not operate the controlled load(s) automatically.
    TO CHANGE OR DELETE PROGRAM SET POINTS: Place Program Selector switch into PROGRAM mode. Press EVENT button to step through the eight possible events. Note that the times which have been programmed will be displayed or 0:00 will be displayed if no set point has been entered. To change an event time, press the HOUR and/or MINUTE buttons to change the time currently in the program to the new time desired. Press EVENT button to proceed to next programmed event. To remove a programmed Event: Press the ON/OFF button two times. When this is done, the display will show 0:00 and the event number.
    I hope this helps & good luck!
    Nov 16, 2011 | Intermatic ET100C Energy Controls -...
    2003 Saturn ION 2 trunk Problem
    there is a manual switch that is located near the trunk latch for a safty lockout it might have been switched by accident look to make sure.hope this helps.
    Jun 21, 2009 | 2003 Saturn ION
    Need help with Compaq MV5500 CRT 15 inch monitor
    hi there, your switch botton is failling, manual buttons on the front to adjust controls, do some switch test, replace micro botton switch. ty
    Dec 26, 2007 | Gateway FPD2275W LCD Monitor
    Switching to Video
    Perhaps purchasing a universal remote, then program it, and press the input button or w.e.
    Aug 29, 2007 | Sharp 27SC260 27" TV
    Computers & Internet Logo
    21 people viewed this question
    David Payne
    David Payne
