Can you provide Manual for remote control
Trying to connect video and sound cables to TV input sources
  • 53 Answers
Hi
If you provide a model number I can
Posted on Nov 25, 2014
Testimonial: "Inovix iDP-713D Portable DivX DVD Player Widescreen 7""
SOURCE: Vizio codes for cable remote control
I don't have any trouble getting my directv remote to run my Vizio. I can't get my Vizio remote to run my directv hd dvr receiver. The Vizio remote is way cooler. I would rather use that one. Can anyone help?
Posted on Oct 23, 2008
shbuckler
  • 126 Answers
SOURCE: DVI-->HDMI cable causes tv speakers to hiss and pop
DVi to HDMI. ? hmmmmm
I recon you spend £49.99 and get a DVI & Audio to HDMI Converter. This will resolve the issue
Posted on Dec 25, 2008
dsacco86
  • 1077 Answers
SOURCE: 50" Vizio Plasma reads "No Signal" on all inputs?
Well, your TV is still under warranty. That's the good part.
The only thing I can recommend without voiding the warranty is leaving the TV unplugged for 30min. That way, the TV can reset itself and hopefully correct the problem.
If that doesn't solve the problem, it's time to use the VIZIO warranty.
Here's contact info if you need it.
Technical Support
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
techsupport@vizio.com
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
Posted on Jun 17, 2009
satavlad
  • 405 Answers
SOURCE: sharp model lc19sb25u sound and no picture screen
Part called main unit failed and require replacement. part number duntke352fm02.
Posted on Oct 28, 2009
budmrtn
  • 11361 Answers
SOURCE: I have a Westinghouse W3223 TV which has decided
This going to be tough one to figure out, but at least the back light inverter board and power supply are working, unhook it at least 1/2 hour?
You may have bad main logic board problem. Try reading my guide here and see how much the main baord may cost you.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 25, 2010
Testimonial: "Thanks very much! That seems to have worked."
How do I get rid of a no signal sign on my tv
You may have the wrong input source selected. There are a number of different source connections on the back of today's TV sets. Using the remote's SOURCE button, cycle through the different inputs until you find the one that your input device is attached to. It is common for users to inadvertently cycle off the correct input when pushing remote buttons.
Mar 02, 2015 | Televison & Video
ON SCREEN HAD POWER ONLY V8.02.8
FOLLOW this instruction and fix it. God bless you
Connect the component video, HDMI1 or AV1 cable from the component device (such a DVD player) to the appropriate input port on the TV. This port may say "Video IN" on the back of the TV. Ensure that the cable is connected securely at both ends.
· 2
Use the remote control's device button(s) to access the menu and select the input through the menu that matches the type of cable input connected to the back of the TV. For example, if you connect the cable to the HDMI1 input port on the back of the TV, selecting anything but the HDMI1 option with the remote control may cause the "No Display" message to appear, which usually means that the TV is not receiving a signal at the connection input you have selected.
· 3 Turn the power on to the component you want to view. If the power was off, turning it on will activate the display and replace the "No Display" message.
· 4
Test any other connected components at their selected inputs to see that the TV is receiving the video signal properly from those sources.
· 5
Check with your cable or satellite provider if their set-top box is the source of the "No Display" message and is powered on, to see if the problem is caused by a disruption in their service. If using an antenna, adjust the antenna and re-scan for available channels.
Jul 20, 2013 | LG 55LE5400 55IN LED HDTV 1080P 120HZ 4...
How to connect samsung hdt550 dvd home entertainment system to cable tv? so the audio outcome would work when watching regular tv as well
The quick and easy way is to take a set of RF cables(the red and white audio cables), from the back of the tv (connected to audio output 1).
You will want to connect these on the other end to your audio reciever(connected to audio input 1).
This way any sound which is produced by the tv will be reproduced at the reciever if you have selected audio input 1 as the source on your audio recievers remote control.
If you are connected this way you will just want to feed all video and audio signals directly into the tv and it will do the rest.
If you provide more details such as the model numbers of every component you are trying to make work together I could provide a much more detailed response.
Good luck, cheers.
Apr 14, 2011 | Samsung Televison & Video
I have the bd230 5.1 system hooked up the speakers, attached the power cord and hdmi cable from receiver to the tv what else do I need to get sound from my tv I have a hd cable.box do I need to run a cable...
The home theater box performs the production of the sound generation. Also, the theater box, distributes the sound to any display devices like TVs, Music MIxers, DVDR, VCRs, ext. The theater box also has connection ports that are recognisable as receptacle area from speakers, woofers, and twitters that combined to form the home theater of devices acquired. First, start by connecting the component parts of the theater system to the box. For example, speakers to an area on the box, twitters, woofers. At which point, the box would require a power cable to an electrican circuit to display functionality mode. The next step is deciding on which display reciver would be providing sound to the theater setup of blasters. For example, choosing to acquire sound from a TV set is achieved by connection cables that derived sound out of the TV to the theater box. E.G. The TV audio output area provides the connectivity of any external audio blasters like with the theater setup. Using the appropiate audio input output connection cables to acquire sound transfer matters. The device may not have been provided with a TV audio input out cable of connections. Acquire from retail input output cables from TV to theater boxes. Remember that, the theater box may have come with a remote control that require separe operations than the TV. The theater system theraafter would require power on buttons if any separate remote controls were acquired as well. Also, the television set would require alteration settings with the remote control. Adjusting the TV sound settings to acquire or direct internal sound to an external setup infrusture is possible explanation also achievable with TV REMOte controller soon after every wireing cables have been established alos powered on to source of current. GOOdluck
Jan 11, 2011 | Panasonic Home Theater System System
2004 jvc 56in projection tv, has sound but no picture
Hello
Change the channel to ensure the problem isn't with the current station broadcast. Check the channel at a later time to see if the broadcast problem is resolved.
The type of programming you are trying to watch determines the proper input source. Press the "Input" button on the remote control to change to the proper input source. For example, if the source is a cable or satellite service, press the "Input" button until "TV" mode is selected. A component device, such as a DVD player, will operate on a different input source, such as "Video-1."
Check the coaxial cable, which connects your television broadcast service provider to your television. You need to securely connect the coaxial cable to the "ATSC/Digital Cable In" jack on the back of the television, and the other end to the wall jack. If the cable appears damaged, replace it with a new cable.
If you are using a component device as the source of your programming, ensure the component cables are plugged into the "Video Input" and "Audio Input" jacks on the back of the television or that the S-Video cable is plugged into the "S-Video Input" jack on the back of the television. Connect the other end of the cables to the "Video Output" and "Audio Output" jacks or "S-Video Output" jack on the component device.
Oct 02, 2010 | JVC AV-56WP84 56" Rear Projection...
I have a Soyo Model# DYLT032C. My remote has been broken since I bought the TV. However, I'm just trying to make the DVD Player work. No cable TV, just want the DVD working. Since the TV Remote is...
As you look at the tv from the front, you have the tv function keys on the lower right hand side, press the key described as source once at a time till you get to the input you are using for the dvd player, ex: if dvd is connected to input 2, press the source key repeatedly untill you get to input2, this should give you control over the external inputs you are trying to use. As for the remote control, there should be a universal remote control you can program to use with your soyo tv.
Jan 30, 2010 | Televison & Video
I have a 19" phillips lcd tv and when i turn the tv on the phillips screen comes up but when it is going the show the channel it shut off by itself how can i fix this problem?
Hello. I may be able to assist you. If you are using a direct cable connection from the wall outlet;
  • Check the incoming cable or antenna signal connection to ensure that it is properly secured to the TV's antenna input.
  • If the connection is good, perform the automatic installation again to search for all available channels.
If you are using a coaxial connection from the Cable or Satellite box to the TV;
  • Set the TV to the channel specified by the service provider.
  • Change the channels at the Cable or Satellite box to view the program.
If you are using a video connection (CVBS, S-Video, YPbPr, HDMI) from the source (DVD, Cable or Satellite box) to the TV;
  • You do not need to perform automatic installation to search for the channels.
  • Press the 'SOURCE' 071218044349_22024.gif button on the remote control repeatedly to select the correct input source.
If you are using an HDMI connection from the source (DVD, Cable or Satellite box) to the TV;
  1. Reset the TV and source by unplugging it from the power outlet for 30 seconds.
  2. Turn on the TV and press the play button on your source device. If the source is HDMI CEC compliant, the TV will automatically switch to the HDMI input.
  3. If your source is not HDMI CEC compliant, turn on the TV and switch to the HDMI input.
  4. Turn on your source.
If you are sure you have selected the correct input or channel but still have no picture or sound;
  • Try resetting the TV by unplugging it from the power outlet for 30 seconds.
  • Press the 'SOURCE' 071218044349_22024.gif button to select the correct input source.
  • Check the connection cables.
  • Try the connected source with another TV.
  • Connect a different source on the same connection of your TV.
Dec 14, 2009 | Televison & Video
I have a sony trinitron XBR and the PIP won't turn off. Any help is greatly appreciated.
Please make sure that one input is connected to the UHF/VHF port of the TV and other is connected to composite or component ports. If you have connected likewise, please perform the steps below:
  1. Ensure the video source is turned on.
  2. Ensure the video source is connected to an available VIDEO input jack on the back of the television. IMPORTANT: The VIDEO 5 input cannot be used to view a program in the PIP window.
  3. On the television remote control, press the TV FUNCTION button.
  4. On the television remote control, in the PIP section, press the TV/VIDEO button to select the appropriate video input for the PIP window.
  5. If the issue is not resolved, connect the Audio/Video (A/V) cable from the video source to a different VIDEO input jack on the television.
  6. On the television remote control, in the PIP section, press the TV/VIDEO button to select the appropriate video input for the PIP window.
  7. If the issue is not resolved, replace the A/V cable.
Sep 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Nov 25, 2007 | Sony SLV-D350P DVD Player/VCR
Playback on TV.
our television must be equipped with a/v inputs. 1. Using the A/V cable provided, connect the proper end to the a/v input jack on your camcorder. 2. Connect the other end to the A/V Inputs on your television. 3. You must tune your television to the proper source / video mode. (Consult television User Manual or manufacturer for further support) Helpful hint: To tune to video mode using the television remote, look for a button labeled: TV/Video Source Input or press 00
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
