Question about Sony KDL60EX500 TV
Sony KDL60EX500 power comes on indicator is green.No sound no picture. No back light or video. Cannot shut off with remote or TV switch. Power supply voltage is good but not drawing current (running c
Sony KDL60EX500 power comes on indicator is green.No sound no picture. No back light or video. Cannot shut off with remote or TV switch. Power supply voltage is good but not drawing current (running cool).When power reset, starts in standby mode.Remote or switch turns the TV on from standby. Any ideas ?
  • Sony Master
  • 5,568 Answers
Likely power supply failure. Sometimes affecting the series of sets.
Remove the back panel (unplugged, of course), locate the power supply which will be a separate block of components with larger, coarser parts.
The parts most likely to fail (electrolytic capacitors) may be exposed enough to examine them.
Look for cylindrical parts, usually 90 degrees from the board plane, with exposed aluminum that is scored, mostly in a "Y" pattern.
Look for any whose tops are bulging or indeed split open along the score lines.
This is about the only visible indication of failure, otherwise a special (LCR) meter will be needed for testing.
If you find such parts, you might try emailing Sony to see if they have an exchange program on the supply; these are not tough to remove and replace.
If not, try to find a local tech who will check the possible failed parts and replace them.
If you go this route, tell them to add 0.1 to 0.47 microfarad (25-50VDC OK) ceramic caps (under the board) parallel to the replaced parts
This will prevent renewed failure of the capacitors by bypassing the chemical caps for the high frequencies which causes them to fail.
Posted on Nov 26, 2014
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Posted on Jun 24, 2009
  • 2318 Answers
SOURCE: No sound no picture, the stand by light blinks four times
If you have the above model, then the four blinks indicate a backlight failure. The back light inverter board might be defective or the voltage from the power supply (+24v) is low or missing.
Let me know if you require further assistance.
Posted on Dec 30, 2008
SOURCE: Sony KDL 46V2500 - turns off, then on
We had the same problem, not quite as often...but I ck'd the power cord connection at the back of the tv and it was loose. I know,sounds so simple - but it worked. Good luck.
Posted on Oct 19, 2008
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
  • 16 Answers
SOURCE: Picture & sound suddenly shut off. power light blinks red 5X...5X
http://www.sonya20tvclassaction.com/main/home.sfx MAKE SONY FIX IT
Posted on Dec 03, 2009
Flat screen tv
Open internal fuse or power supply failure
Aug 30, 2016 | Televison & Video
I have a sony KDL 46xBR2 when I turn on powers up green light stays on but a dark gray screen no picture or sound
The green light merely indicates that power is getting to your TV. The symptoms you describe point to internal power supply failure
Mar 17, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
I have a Sony Model # KDF-E55A20 HD Television. I
So what ur prob?Yes the power supply prob.if getting nothing,no response to power,click when turn on,or no standby light indicator.
Oct 19, 2009 | Sony KDF-E55A20 55 in. LCD Television
Picture wont come on screen
this problem is in the power supply.the red lights indicate as the standby mode.
Jan 23, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
AKAI LCT26Z4AD wont power up.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 10, 2017 | Televison & Video
SONY TRINITRON KV-28LS35U
Error 11 means the 8V supply is missing.
Check the power supply.
Jul 25, 2017 | Sony FD Trinitron WEGA KV-30HS510 30" TV
Sony KV-32S22 32" TV Problem
Intermittent dead with red standby light on, but won't switch back on, comes back on it's own, won't respond to remote or local controls
Low 5v standby supply due to diode D869 faulty, check by replacement
Nov 23, 2007 | Sony KV-32S22 32" TV
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Sony KDL60EX500 TV Logo
102 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
