Question about Hyundai Televison & Video
I have a Hyundai TV that I want to use as a computer monitor. I need a driver for this model of tv, please advise, thanks Ellie
I have plugged in the HDMI cable and extended the display on my computer but nothing appears on the TV. The TV is working properly but I do not have the driver for it. Do you know the name of the driver or wher I can get it from thanks?
    Top Expert:
  • Hyundai Master
  • 74,630 Answers
What is the model number to your Hyundai TV? Doesn't both your computer and TV have VGA sockets? Provide more details; please. http://electronicshelponline.blogspot.com/
Posted on Nov 25, 2014
Benimur
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
  • 453 Answers
SOURCE: HDMI outlet seems to be bad/ no picture
u need a main signal board replacement
Posted on May 08, 2009
  • 4234 Answers
SOURCE: my sharp tv is pc ready. I hook everything up and
There are a number of things to check here:
1) Verify that the resolution on the PC is set to a supported level for the TV. Usually the TV will show "no signal" if the resolution is out of range or the message "out of range" will appear.
2) You don't indicate whether you are connecting to a desktop or laptop. If a laptop, you may need to turn on the external monitor. This is done by using the function key and either F5 or F6 (the key should have a picture of a screen on it). Hitting this combination will toggle between the main screen with.without the external monitor.
3) Verify that the TV port is selected correctly (AV1,AV2 etc)
4) You will need a separate cable or the audio regardless of the system type. Also verify that the audio cable is in the corresponding audio input jacks for the video option selected.
If you have completed the above and it still doesn't work, please post the details about the computer being used and the exact cable setup that you have and I'll check into this further.
Thanks,
Dan
Posted on Mar 13, 2010
  • 10 Answers
SOURCE: Philips LCD TV "47, model PFL 8404H/12, NO SIGNAL on all 4 HDMI
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL8404H/12&slg=en&scy=CZ
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
Posted on May 11, 2010
budmrtn
  • 11361 Answers
SOURCE: My LC320SLX Sylvania TV displays the message
You are getting that message becuase the MAC video resolution is too high for the TV handle, you need to lower your MAC video resolution to the native resolution of the TV, read your manual to find out what it is.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Aug 08, 2010
Hi, I'm wanting to buy new tv for my computer. Needs to be LG and have PIP??? 40-48 inches Can you please advise me on the type that has this function. Thanks Carl
TV's used as monitors won't have the resolution of a straight monitor. You'll have picture sizing issues too because the monitors and TVs have different horizontal frequencies.
Mar 13, 2017 | LG Televison & Video
I am using FRONTECH LCD TV tuner MODEL NO:-JIL-0622.Recently connected to my new DELL LED then i was just changing the configuration of screen resolution but somewhere in middle it got stuck later on the...
update your driver of tv tuner for os of your computer.like win7 or win8.
second do windows update for your computer and do update for your graphic card--and do update bios of your computer.
thanks
Jul 14, 2014 | Philips SAA7130 TV Tuner/FM Radio/Video...
Use my hdtv as a monitor
Use the PC in on the TV if equiped. if not you will need a HDMI cable from computer to TV if your computer is equipped with HDMI.
Apr 28, 2012 | Canopus ADVC-110 A/D Converter...
I need the drivers for my Insignia 19" LCD TV 720p (model NS-LCD19-09). Can you assist?
Hi There are no specific drivers for the TV / monitor. If you are planning to use it with a PC , please check the drivers of the graphics card. (right click anywhere on the desktop , go to properties and settings there you should see the second monitor if the pc is able to connect to the TV otherwise you would need to use a standard driver
please specify what you are planning to do , for example PC make , operating system what connection etc
May 05, 2011 | Insignia NS-LCD19-09 Monitor
I would like to use my Sylvania LC320ss8 Flat screen tv as a computer monitor but when I plug in the monitor plug the screen on the tv says format not supported. My operating system is Windows 7 and...
If you have connected the TV to the computer with a VGA cable, what resolution was your previous monitor using? You may need to change the resolution or refresh rate with your regular monitor attached. This TV has a native resolution of 1366 x 768 .
If you are connected via one of the HDMI ports, check the specifications for your TV. Then try using the VGA output. Not all TVs support a computer signal over HDMI. Unfortunately, I can't find the LC320ss8 at the Sylvania Support site: http://www.sylvaniaconsumerelectronics.com/ . If the model number has an error, click on Downloads and enter the correct model number.
I hope this helps.
Mar 31, 2011 | Sylvania LC320SS8 32 in. LCD Television
Hello i have a hyundai tv plasma HPT 428 1H
Try a computer/electronics store. Ask for a power cable for an lcd monitor. It should be the cable you need.
Oct 06, 2009 | Televison & Video
I am trying to hook up my HP Laptop to my 47'' Insignia HDTV. When I plug in the display, my laptop displays only my desktop background and the tv says ''Mode Not Supported''. I am unable to even change...
try changing your resolution for your laptop before you plug in your TV, the screen refresh rate of your monitor,(click the following, control panel, personalization, display settings, advanced, monitor Tab). Also what make/model video adaptor are you using, try updating the drivers, if this helps, please give a fixya rating. Thanks
Jul 10, 2009 | Televison & Video
Hyundai imagequest B90D orange standby
hyundai will not repair this however a electronic service center aka tv repair may. I can do it as most likely is it several capacitors that have blown. Hyundai is also a little picky to open they are assembled very well actually compared to other monitors (they are difficult to open up) let me know what you would liek to do.
Nov 13, 2008 | Hyundai ImageQuest L70N 17" LCD Monitor
Can't get sound to play on my AOC LCD from my XP computer.
did you have an installation disk?? If so it may not have loaded in the setting to make the sound card accept the monitor..Or simpler--is the right wire plugged into your computer for the sound??
color codes don't always match for generics.
Oct 12, 2008 | AOC A15X221 15 in. LCD Television
Televison & Video Logo
53 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
