I am using Tokyo gas heater model RN-B835FH-WH, & i get this Blinking "01" Error code? can any one pls guide why this error comes & how to solve it?
I am using Tokyo gas heater model RN-B835FH-WH, & i get this Blinking "01" Error code? can any one pls guide why this error comes & how to solve it? this "01 Error(Blinking with dot red light)" come once in a day.
    Master:
  • 755 Answers
Do a google search for a manual or look on you tube you may get lucky on finding that code , good luck
Posted on Nov 25, 2014
muleskinner2
  • 270 Answers
SOURCE: Error Light
This is the add toner light. Replace the tube of toner and will be well.
Posted on Dec 28, 2007
  • 412 Answers
SOURCE: Canon GP 225 - Error code: E007-01
This can be either of three main thing.
1. The machine detects the film out of place and needs to be reset, you do this by activating the service mode. Insert paper clip into hole (inside machine), then * * and service mode shud activate, then click error code and clear all errors.
2. The film is out of place, the fuser needs to be removed and the film manually moved back to the hope position
3. The film is torn and needs to be replaced (LONG WORK AHEAD)[/code]
Good Luck!!
Posted on Mar 18, 2009
  • 700 Answers
SOURCE: green & red light is blinking
If you try to print and it say "end of service life ........thing" . You have to reset the printer counter to 0 count.
Use a third party software for this, key in in your web search bar " epson reset software" the upper most link is the one, try to read the procedure.
Hope you get it easily.
Posted on May 25, 2009
  • 990 Answers
SOURCE: sharp photocopier with error code L4-01
Hello sir L4-001 that's driving problem, check the main motor ,gears belts.
Posted on Jun 02, 2009
Joed911
  • 4338 Answers
SOURCE: i face error code 2,114,0 error in canon printer
Is it a refill or compatible cartridge? If so then the printer will not read full ink levels only with genuine Canon ink.
The printer will work with refills/compatibles but you need to press the reset button (this should be a small round button which has a red triangle in a circle on it) hold it down for a fair few seconds and that will get the printer working. You just ignore the message of low ink.
If they are genuine inks then it may be the connectors need a gentle wipe with cartridge flush as there may be something on them that's not allowing them to make the correct connection with the printer.
If they still won't work you need to take them back to where you bought them and ask for replacements as the ones you were given are faulty.
Posted on Feb 06, 2011
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
Mar 31, 2015 | Asko TL751 Electric Dryer
Tokyo gas fan heater user guide rn-a120fh-wh
Hi can u please send me the translation operation buttons in English language of RN 240 TFH fan heater manufactured by (Tokyo Gas) thanks.
Dec 12, 2013 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Noritz Boiler NH-1501-DV-NG Shuts off at radom times with blinking error code 123
error code 123 is a flame rod sensor problem. Chances are the flame rod is sending a weak signal to the control unit. Check for a loose flame rod electrical connector. Peek in the flame inspection windows to ensure there is a proper flame on that side of the burner. If non of the above then try removing the flame rod and cleaning with 400 grit sandpaper or replace it with part order # SKC7448 (called an Ignition plug ELV & Packing EHK SETV)
Dec 16, 2012 | Noritz NH150-DV-NG Indoor Direct Vent...
I have an error code displayed on the copier as, H5-01 Please can you help/advice on the reset code which i could use.
When your copier heater unite thermostat is out of order then show H5-01 is blinking.
You can reset it Press # interrupt 0 Interrupt press 14 press print key or start button then machine is ready.If are not success you must change it.
Aug 03, 2010 | Sharp AR-M162 All-In-One Laser Printer
Rheem Tankless wh model rtg-74pvn shuts off error code c4 76
Contact Rheem; the Burner control unit has lost comm with the remote...the part is warranteed for up to five years.
Nov 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
My new tankless WH stopped working. It gives hot water for about 15 sec, then starts flashing C7 12 or C2 11. How can I fix this, We had it for a month now & it worked before.
11 The Gas Shutoff Valve is not opened
completely.
12 Gas Service has been interrupted.
LP Gas is running low. (LP models only)
I think C7 is where the startup sequence ended...and then you get the error code
If less than a month old...contact your customer support
Nov 01, 2009 | Rheem EcoSense by 7.4 GPM Outdoor...
I have a Sharp AR-M207 with an H4-00 error. We have installed a new fuser but still get the error the moment that we turn on the device. I have seen several responses telling which buttons to press to...
heat roller low temperture detection&check the thermistor abnormality,heatlamp abnormality,thermostat abnormality,clean the paerdust guide &use sim 5-02
check the heater lamp blinking operation
use sim 14 to clear the slf diagnostic display
Oct 19, 2009 | Sharp AR-M207 All-In-One Laser Printer
Sharp ar-c330 with an error code of H4-01. Any
The fuser temperature is low.
Use sim. 5-02 to check blinking of the heater lamp.
if it blinks normally check the thermistor and the harness.
If it not lighted check the heater lamp and thermostat if its defective replace the heater lamp or the thermostat.
Jun 10, 2009 | Sharp AR-C270 Color Copier
I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Jun 09, 2009 | Sharp Office Equipment & Supplies
Circuit board light blinks 3 times heater will not turn on
The error code refers to a defective combustion air switch. Coleman Evcons made around 2007 had defective pressure switches or as they call them "combustion air switch". Replace it and the problem is gone.
Dec 13, 2008 | Goodman GMS90703BXA Heater
271 people viewed this question
k24674
jasbo
jasbo
