Question about Eastern Tools & Equipment ETQ Tg1200 1200 Watt 2 HP 2-Cycle Gas Po by Eastern Tools Equipment
Further to my question about a weak spark on my etq 1200 ,would one of these be the problem, magneto,igniter ir capacitor?
Checked compression,gas& changed the spark plug twice. All of the above are good!
  • 27 Answers
That's pretty annoying. Usually the problems with small gas equip is the carburetor, plugged up passages and jets, that's a carb rebuild. Remove and check the plug color for run condition and ground it out to verify it is sparking. That's probably a magneto, so give it a good pull when you ground the plug. That's a two cycle so you might also have old or too oily a gas mix, toss the gas and mix fresh.
Posted on Nov 25, 2014
  • Eastern Tool... Master
  • 1,169 Answers
A lot small ignition spark appears to be weak when they are not.
A couple things to check. make sure your spark arrestor is clean and your ignition timing is correct; otherwords, that the flywheel key is not sheared.
Stihl BR 320 no spark
has that electronic magneto ignition system (coil)
you can see it at part 21 page 10 of this 46 page pdf
english is in the middle row
http://www.motoculture-jean.fr/upload/pdf/BR320_BR320L_BR400_SR320_SR400.pdf
user manual 30 page pdf
http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/BR320_400_Manual.pdf
May 30, 2016 | Stihl Br320 Backpack Leaf Blower Heavy Use...
Tb7oss trimmer won't start
to be honest, it would probably be less expensive and far less time consuming to replace the entire trimmer with a new/used timmer. If you are willing to invest the time, replace the magneto, the spark line and be certain the spark plug is clean and properly gapped.
Oct 06, 2014 | Troy Bilt Tb70ss Gas Trimmer
I have a etq 1200 generator that runs but doesnt have ac. what could be the problem?
Check that the GFI receptical is not tripped
Check that there are no blown fuses or tripped breakers
Verify that the engine is running at full RPM
If there is still no output, then either the field needs to be flashed (look on line to find a video on how to do this - YouTube), or the generator will need further diagnostics.
Sep 04, 2014 | Eastern Tools & Equipment ETQ Tg1200 1200...
Craftsman LT2000 w/ 18.5 HP B&S engine- will not start-been sitting up for year in shed- new battery- checked fuel flow to carb: OK - checked spark plug: cleaned , seems OK- engine turns over but not...
A 'cranks but doesn't start" problem just needs to be narrowed down to compression,fuel,or ignition.The compression is pretty obvious-does it sound like the stater is getting a load when cranking?The next one is fuel-do you smell raw gas fumes coming out of the exhaust?The last one is spark-take the plug out and clamp it to the block,crank it,do you see a spark? If you have compression and spark,try a shot of starter fluid down the carb.(sometimes the float needle can get stuck,and just getting the engine to fire will shake it loose).If you don't have spark,then look for why(not sure if you have a magneto or ignition coil system).
Apr 14, 2012 | Craftsman Garden
I HAVE A ETQ 1200 GENERATOR I NEED ON THE
The pdf for this generator is available at easterntools.com
Feb 07, 2010 | Eastern Tools And Equipment 1200 Watt...
The blower stalled after running for 15min.it is getting gas,i cleaned the carb+ replaced the gas filter.the air cleaner is clean and i replaced the spark plug.i seem to be getting a very weak spark.any...
Hello . If you have a weak spark it could be the ignition coil that needs adjustment or a bad ignition coil . To find the ignition coil simply follow the spark plug wire . To readjust the coil get a piece of paper , loose the bolts on the coil and put the paper between the coil and the flywheel (higher part of the flywheel or magneto) tight the bolts and remove the paper .
Check for spark . If still a weak spark just replace the ignition coil .
Hope this help.
Jun 30, 2009 | Husqvarna Garden
Eastern Tools & Equipment ETQ Tg1200 1200 Watt 2 HP 2-Cycle Gas Po by Eastern Tools Equipment Logo
134 people viewed this question
Top Eastern Tools & Equipment Electrical Supplies Experts
Bernie Knutson
Bernie Knutson
Level 1 Expert
jhnolson
wadingriver
wadingriver
Are you an Eastern Tools & Equipment Electrical Supply Expert? Answer questions, earn points and help others
