Question about Dell 4610X Wireless Dlp Multimedia Projector With Hdmi-
Power bottom light flashes amber and the temperature light is steady amber after DMD chip replacement.
I recently replaced the DMD chip on my Dell 4610x and after I put it back together the darn thing wont power on and the power bottom light flashes amber and the temperature light is steady amber, the user manual says that this means Fault - DC supplies (secondary) Power supply has been interrupted. The projector automatically shuts down. Unplug the power cord after three minutes and then turn on the projector. If this problem persists, contact Dell I took it apart again to make sure everything was connected right but still does the same, do you have a clue on what could be going on? thanks
  • 27 Answers
Sounds like a board problem or a bad temp sensor. Those things get pretty hot (charred) and you may have open circuit it when you swapped. Did you put the old one back in?
Posted on Nov 25, 2014
Projector is not on red light is blinking
check the lamp first
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Dec 16, 2013 | Dell 1210S Projector
Dell Optiplex 775 Power light, is flashing, wont turn on. I have recently replaced the PSU with a brand new dell one, as i was getting booting problems, since putting the new one in, i just get the...
could also be a ram stick that ate it. Also some of the older mother boards dont have a 12 volt supply that new cpu chips need might check that as well. Make sure the power supply is turning as well as cpu
Sep 03, 2011 | Dell Optiplex 755 Minitower Desktop...
Dell inspiron 1525 - plugged in not charging shown on battery icon. Battery power light blinks 4 times amber then once blue.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See
Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for
instructions.)
Feb 13, 2011 | Dell Inspiron 1525 Notebook
Power light is blinking green and amber
my power light flashes green/ amber as soon as it is plugged in, with a dead battery. It seems to go to steady amber if the plug is tapped, but goes back to flashing. It will not hold a charge on a new battery.
Dec 28, 2010 | Dell Axim X51v Pocket PC
Dell 6000 power problem?
Troubleshooting a power problem is fairly simple:
1 Try a different AC adapter, see if there is any change 2 If system will not power on with a known good or new AC adapter, then the power connection on the motherboard is likely damaged and the motherboard will need to be replaced.
Mar 24, 2010 | Dell Inspiron 6000 Notebook
Steady amber Power light
You are looking at a new mother board. I would take it to a certified technician shop, so they can run a stress test on the motherboard for final benidiction.
Aug 13, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
I have a flickering amber light on the power button; replaced power supply and motherboard with no luck
FIRST IF YOU REPLACED THE POWER SUPPLY OF YOUR DELL PC,
MAKE SURE IS A RECOMMEND POWER SUPPLY FOR DELL COMPUTERS ONLY
BECAUSE DELL USE A DIFFERENT (NONSTARD) PS
AN PLEASE DON'T TURN YOUR PC ON, TILE YOU ARE SURE I'TS A DELL COMPATIBLE POWER SUPPLY
YOU CAN FRY YOUR COMPUTER
ON THE MOTHERBOARD I'T MAY BE THE BIOS (BIOS STANDS FOR INPUT /OUTPUT SYSTEM) I'T A CHIP ON YOUR MOTHERBOARD THAT CONTROLS THE SYSTEM HARDWARE AND ACTS AS AN INTERFACE BETWEEN THE OPERATING SYSTEM AND THE HARDWARE
I'T MAY BE FLASH
IF IS FLASH ,
YOU PROBABLY NEED TO REPLACE THE MOTHERBOARD
OR CALL DELL TO SEE IF THEY CAN FIX IT
Aug 20, 2008 | Dell OptiPlex GX520 PC Desktop
Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Aug 08, 2008 | Dell Dimension 8300 PC Desktop
Dell 4610X Wireless Dlp Multimedia Projector With Hdmi- Logo
61 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
