Question about Eastern Tools & Equipment ETQ Tg1200 1200 Watt 2 HP 2-Cycle Gas Po by Eastern Tools Equipment
What would be tge cause of a weak spark?
I've got good compression, new plug, gas, but it won't fire and the spark seems to be weak.
    Problem Solver:
  • 13 Answers
Sounds like it could be a weak ignition coil.
Posted on Nov 25, 2014
Having trouible restarting it. What can I do?
James, is there spark, fuel and is the choke staying on properly.
If it is trying to fire it could be a weak plug, stale fuel, dirty carburetor, or clogged exhaust screen in muffler, worn out low compression.
No spark with new plug, faulty switch, faulty coil. faulty plug wire, dirty weak magnets on flywheel.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
chainsaw troubleshooting woodland forum at permies
Chainsaw Won Start
Mar 22, 2016 | Garden
I have a 2002 pt cruiser it is getting gas and fire but the fire is weak
Weak spark could be bad coil(s) or ignition module. Even a bad groud strap can cause this, but most common is module.
May 04, 2015 | 2002 Chrysler PT Cruiser
WHEN I GIVE IT GAS IT START TO MISFIRE
Misfires are caused by one of 3 things-gas, spark, or compression-one of those is the problem. For gas, check the fuel pressure and see if it is at the right pressure for your car. Low fuel pressure will cause misfires. If pressure is good, it could still be an injector problem, like a clogged injector. If low pressure, suspect the fuel pump or the fuel filter.
For an ignition spark problem, check your spark plugs. Pull them out and inspect them for broken or cracked plugs, check the spark plug gap, check for oil fouled plugs. You may be able to isolate the misfire to a cylinder or two by the plugs condition. A misfiring plug or cylinder should show more black, sooty deposits than the other plugs. A normal firing plug will have a tan or brown colored insulator on the end with very little deposits. If the plugs are okay, clean them a bit if needed, and check for spark on the spark plug wire ends with engine cranking. Buy an inexpensive spark tester, or hold each spark plug wire metal end terminal 1/4 inch from a ground on the engine block, while cranking the engine. Wear a heavy glove to avoid getting shocked. Check that every cylinder is getting a strong blue spark to eliminate ignition as a problem. A weak, yellow or orange spark is an ignition problem, possibly a bad coil, or other ignition part.
If spark and gas is good, you may need to check engine compression. Any cylinder that has significantly lower compression than the other cylinders will cause a misfire, and set a misfire code. You should check for any trouble codes in the engine computer. A code reader or scanner would have to be connected to the diagnostic connector under the dash. What is "significantly lower" compression? About 15-20% less compression. Say you checked and had 150 psi compression in most cylinders. If one had 20% lower compression ( 150 X 20%= 30 psi, 150 -30 =120 psi, or same as saying 150 X 80%= 120 psi.), a condition like that can cause a misfire. I hope I have made sense here. Good luck, and post back what you find, or if any questions.
Apr 10, 2014 | 1998 Ford Windstar
The Stihl 038 super won't start. It is getting too much gas on the spark plug when I try to crank it. Just replaced the carb hoping it was that but still it won't start. The saw was working fine a...
hi there mwb15
have you made sure the ignition coil is producing enough voltage to fire under compression load ?
you may get a spark at the plug unloaded but under load it may be breaking down / weak making you think its got a fuel problem ?
does your system use a cdi coil system or point/condenser system ?
spark usually falls into weak spark, no spark catergory
if compression , fuel ( you replaced carb) and exhaust are ok , and you have air and vaccuum tight c/cases only things left are timming and spark
remember F A C T S
F = Fuel A = Air & ( air tight c/cases ) C = Compression T = Timming S = Spark
compression should be about 130- 140 approx if in good running order
take a look and let me know
cheers pauly46
Jun 18, 2011 | Garden
I have a Husq. 326 L trimmer; my pull cord seems to tug and becomes almost unpullable and it wont start; I have a new spark plug-what could be causing this?
Pull your plug back out and see if your cylinder is full of fuel, if this is the case your needle/seat is leaking fuel into cylinder causing hydrolocking (gas won't compress) good luck
May 02, 2011 | Husqvarna 28cc Gas Line Trimmer
Motor turns over but will not start, seems to be getting gas, & spark
I don't have enough info to give you a specific answer so I've listed a bunch of possible problem that could cause your engine to roll over but not start.
Check the battery and connections, a weak battery or bad connections can cause a weak spark and stop the engine from firing.
Fuel pump or fuel filter, low gas pressure can cause to lean of a air/fuel mixture for the engine to start.
Bad gas, old gas or water in the gas can stop the engine from firing.
Bad or fouled spark plugs, could be caused by bad gas.
Ignition wiring problems, can cause weak or unreliable spark.
Bad, poorly connected or misconnected spark plug wires. Even 2 wire out of order can stop the engine from firing.
Oily spark plug wires, can cause the spark to fire at the wrong cylinder or misfire.
Worn, damaged or wet ignition components.
Jun 08, 2010 | 1996 Jeep Grand Cherokee
P0300 Engine Code Ford ZX2 2002 ZTEC dual over head cam engine. Has 107K miles. Has new plugs, Only thing I really notice is when I turn on AC the car seems to stumble at steady speeds, especially...
P0300 Random Misfire
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
A Random Misfire code usually indicates a vacuum leak or bad gas.
NOTE: If a misfire in a specific cylinder should lead you to check the spark plug, fuel injector and compression.
Jul 25, 2009 | 2002 Ford ZX2
1998 2.4 starts but idles bad the #2 plug not firing the gas.
black smoke is usually fuel...white is usually coolant...you may have a warped cylinder head or some other mechanical problem. do a compression test. If you disable the #2 injector does smoke continue? if it does, it's not fuel. When you remove #2 spark plug, is it wet? if so what's on it?
Jun 19, 2009 | 1998 Chevrolet Malibu
Eastern Tools & Equipment ETQ Tg1200 1200 Watt 2 HP 2-Cycle Gas Po by Eastern Tools Equipment Logo
93 people viewed this question
Top Eastern Tools & Equipment Electrical Supplies Experts
Bernie Knutson
Bernie Knutson
Level 1 Expert
jhnolson
wadingriver
wadingriver
Are you an Eastern Tools & Equipment Electrical Supply Expert? Answer questions, earn points and help others
