High piched sound in wash - Washing Machines
  • 24 Answers
There's not too much to a washing machine...I would guess it may be the bearing is/has gone out in the motor.
Posted on Nov 25, 2014
High pitched whine
The most common cause would be a defective power steering pump.
Aug 29, 2012 | Cars & Trucks
1999 station Wagon.Car not moving foreward nor reverse.Oil level above low level.High pich noise when pres the pedal gas.
Did you check the transmission fluid level? Sounds like you have a converter or a trans. pressure problem.
Jul 27, 2011 | 1999 Ford Taurus
Once we turn the tv on it would start making a sound like a whinning high pitch sound with no picture..and it wont turn off anymore unless you pull the plug..
hello jackiea0819,
pich sound on HLR6768W because of the collor wheel. The color wheel not rotate properly.
My suggestion you replace the color wheel. Call samsung technician to replace it.
Good luck.
Mar 29, 2011 | Samsung HLR6768W 67" Rear Projection HDTV
High piched squeal
Sounds like a color wheel. Bearings in color wheel make such a sound when bad.
Nov 27, 2010 | RCA R52WM24 52" HDTV Projection Television
My traxxas revo 3.3's gears are grinding, the car has slowed down
sounds like engine is running to lean. count how many times the high end needle is out. will have to retune engine before piston seizes completly up.
Jul 20, 2010 | Traxxas Rc Revo Nitro Monster Truck
I have 4.3 L and i keep on hereing a high piched noises
You need to determine which pulley your noise is coming from,the best way is to use a long extension and place it on each item and just touch it to your ear,then you will be able to hear how each of them have there own sound.but from here,i'll place my money on the alternator,they do put off a high pitch noise when the front bearing is drying out on them
Dec 18, 2009 | 1996 GMC Jimmy
Noise from drivers side
hi how are you.there is a couple of things that will cause a rubbing sound.if it is a high pich sound then look at your dust cover behind your brake rotor.a low pich or a growling noise check your wheel bearing/hub assembly.with wheel off the ground wiggle it side to side and up and down you will have alot of play.or there is something hitting the tire.
Feb 02, 2009 | 2001 Daewoo Lanos
No Picture/High Piched Sound
bring it to the authorise service center man, simple. Fred-Modern Home Qatar
Jan 26, 2007 | Panasonic CT-36D11 36" TV
Televison
The high pitched sound is probably comming from the power supply, possibly due to its trying to drive voltage into a shorted component in the high voltage deflection circuits. You may be lookng at about a $250 repair. If it has been used a lot and its picture quality didn't knock your socks off, I would replace it with a HDTV set. A 37 inch LCD from Toshiba might be a good place to start and should do nicely for you.
Jan 24, 2007 | Panasonic CT-36D11 36" TV
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
