Question about Whirlpool Washing Machines
Whirlpool gu940scgt2 makes high pitched noise in wash cycle...what is the cause?
  • ken winger
    ken winger Nov 25, 2014
    no,no,no....this is a dishwasher...not washing machine
    Genius:
  • Whirlpool Master
  • 1,466 Answers
Could be motor bearing or the Belt, make sure the pump is clear and pumping okay in case problem here.Not always a good idea to lubricate a bearing as it can cause premature failure.
Posted on Nov 25, 2014
jsrock516
  • 5911 Answers
SOURCE: whirlpool awm8121 - spin cycle high pitch sound/scretch
Front loaders are great for savings on water and electricity. Most of these machines only use about 5 to 7 gallons (US) of water and spin with a velocity anywhere between 1300 to 1800 rpms. This also saves on dry times because your clothes are virtually spun dry. Why am I telling you all this? People buy them with good intentions, but the common complaint I hear is that they are noisy. It is this spin velocity that contributes to that noise. You need to make sure that the foundation under the washer is stable. If your washer is located in a mobile home, upstairs laundry room, home with a crawl space, etc., sometimes these floors have a tendency to flex as the washer spins. If the floor flexes (even a little) the washer will vibrate and make noise. An easy fix to help redistribute to weight of the washer is to place a sheet of thick (at least 3/4" in the US) plywood under the washer to help reinforce the floor. This must be screwed down or affixed in such a way that it does not move. This will take care of any vibrating issues. Now, if your problem is strictly with noise from the machine, some of that is normal I'm afraid to say. However, if it sounds REALLY loud (like a rumble) this is a symptom of a rear bearing that is going bad. If that is the case, the entire back shell of the wash tub has to be replaced in order to replace the bearing as they are molded into the plastic. This can be an expensive repair job if you decide to pursue this option. Let me know if any of this helps. Kinda hard for me to diagnose without being there to hear it.
Posted on Jun 24, 2007
dididsaythat
  • 291 Answers
SOURCE: kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Posted on Sep 07, 2007
  • 107 Answers
SOURCE: high pitched screeching noise when in spin cycle
Sounds like something is in the pump or the pump bearing went bad. The pump runs CONSTANTLY in agitate, it runs backwards and spin and drain the motor reverses, so if there's something in it, it'll make noise the entire time.
Posted on Mar 25, 2009
App King
  • 55 Answers
SOURCE: LG makes a high pitched sound during water add cycle
Hello.
The high pitched sound is a definite sign that the water valve in use is failing. The squeal is from a restricted water flow through the valve because it is not opening all the way. You will need to choose cold or hot to narrow down which valve is bad and replace that one.
Posted on Jul 16, 2009
heatman101
  • 43501 Answers
SOURCE: squealing noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
98f
Posted on Sep 29, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Our whirlpool top loading washer starts making a high pitched whirring noise in the beginning of the first spin cycle. Once it gets going full speed the noise stops. What could be?
If you can hear the motor humming during the spin cycle, it could signal a defective motor drive. It's possible for the motor to fail in just one direction, which may be why you only hear it some times.
This kind of issue often requires the help of a professional. To learn more about this issue, read Washing machine will not spin but will pump and agitate. I hope this helps.
Sep 12, 2012 | Whirlpool Washing Machines
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The washing unit makes a high pitched loud noise
Check to see if you have a bra underwire or nail stuck in the spin tub. Look around inside the tub looking for something stuck in one of the holes. Dont use the machine until you find the problem or you cut the tub in half with like a nail or screw and then the machine has to be rebuilt $$$$
You may have other problems, However start here. Let me know if you have other questions
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
High Pitched Noise
try washing on hottest cycle it may be the seal in the spray pump somethimes the rinse aid can put a glaze on the seal if that doesnt work you can replace just the front part of the motor( in australia) dont know where you are.
Feb 06, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Whining noise, only in rinse and spin cycle, sounds awful.
Check the pump to make sure there isn't something stuck in it.
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
