Question about Kitchen Ranges
How do I run the flex clean option? - Kitchen Ranges
    Sergeant:
  • 233 Answers
Check the owners manual for the range or check the support section on the manufacturers website for a manual you can download from them. They are most often in .PDF format meaning you will need adobe reader (free) to open and read it
Posted on Nov 26, 2014
My whirlpool ler5636jqo electric dryer reun fine for 5 minutes then turns off.the cloths have heat and are still damp. when its run in fluff mode{no heat}, the dryer runs the entire cycle. Vent and exhaust...
Yes Bruce, I'd suggest cleaning the lint out of the blower intake under the lint basket. Then remove the flex duct off the back and clean the discharge of the blower as good as possible. Even check for build up inside the flex duct and outdoor termination. What you are experiencing is the typical 'lack of airflow' causing an increase in temperature rise across the heating elements which results in the tripping of the high temp limit switch. If those areas are clean as you indicate, the problem is within the confines of the blower assembly itself and blower wheel itself.
Many times, the top has to be raised and the front removed to facilitate proper cleaning of the blower and related areas. If so MAKE SURE YOU UNPLUG IT FIRST !!!!! Mark all wires that may have to be removed or write inside the white surfaces your notes about wire color and location with a majic marker.
Mar 08, 2015 | Whirlpool Dryers
Cracked flex cable so pls help
REPLACE CABLE OR PAINT WITH LIQUID WIRE INSULATION.
Oct 31, 2014 | Cameras
Need to hard reset insignia flex
There are two options for resetting the Insignia FLEX:
1) Insert a straightened paperclip into the reset hole on the side of the unit.
2) Hold down the volume up or down key while pressing the POWER button.
Dec 09, 2013 | Insignia - Flex 10.1" Tablet with 16GB...
Motorola insert sim problem
Please follow this steps :
* check the simcard or try a new one for a test.
* check simcard socket if its clean or align.'
need to dismantle the phone
* unscrew (4) all screw using T5-T6 precision screw,remove the plate cover
* remove camera by lifting up the flex connector
* remove the earpiece (white socket)
* remove the flex connector below connected on the keypad board.lift up the keypad board
* try to clean the flex connector
* as well as the keypad board were the simcard socket is attached.this is may due to a corrosion.
if everything is clean,assemble the phone and test if the simcard will be recognized.
if cleaning and alignment doesn't work,it needs to replace flex connector or keypad boad.
good luck....
Jun 17, 2011 | Motorola Mobility SLVR L7 Cellular Phone
Our Bissell 9200 carpet cleaner will not spray cleaning fluid through the tools nozzle. With the tool dial set to "floor" fluid comes out of the front nozzle. With the tool dial set to...
Assuming this is the pro heat version
Most likely you have some debris blocking the system. You need to follow the hand tool cleaning instructions.
remove the hand tool and manually wash it
select the tools cleaning option
place the tube in a bowl of clean water and allow it to **** the water up - this should clean out any blockages in the pipe.
Dec 14, 2010 | Bissell 9200 Upright Vacuum
I received a code PO176. The engine runs for about
You will have to change the flex fuel sensor on the truck sounds like its working on and off.
Oct 30, 2009 | 2000 Ford Ranger SuperCab
Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
Sep 27, 2008 | Hotpoint NVL333EY Electric Dryer
05 susuki forenza
Removal Procedure
1. Disconnect the negative battery cable.
2. Drain the engine oil from the engine crankcase.
3. Remove the exhaust flex pipe retaining nuts from
the exhaust manifold.
4. Remove the exhaust flex pipe retaining nuts from
the catalytic converter or the connecting pipe.
5. Remove the exhaust flex pipe.
6. Remove the oil pan flange–to–transaxle retaining
bolts.
7. Remove the oil pan retaining bolts.
8. Remove the oil pan from the engine block.
Cleaning Procedure
1. Clean the oil pan sealing surface.
2. Clean the engine block sealing surface.
3. Clean the oil pan retaining bolts.
4. Clean the oil pan attaching bolt holes in the engine
block.
5. Clean the oil pan scraper.
Installation Procedure
1. Coat the new oil pan gasket with sealant.
Important : Install the oil pan within 5 minutes after applying
the liquid gasket to the oil pan.
2. Install the oil pan to the engine block.
3. Install the oil pan retaining bolts.
Tighten
Tighten the oil pan retaining bolts to 10 NSm (89 lb–in).
4. Install the oil pan flange–to–transaxle retaining
bolts.
Tighten
Tighten the oil pan flange–to–transaxle bolts to 40
NSm (30 lb–ft).
5. Install the exhaust flex pipe.
6. Install the exhaust flex pipe retaining nuts to the
exhaust manifold.
Tighten
Tighten the exhaust flex pipe–to–exhaust manifold
retaining nuts to 35 NSm (26 lb–ft).
7. Install the exhaust flex pipe retaining nuts to the
Tighten
Tighten the exhaust flex pipe–to–catalytic converter
or connecting pipe retaining nuts to 35 NSm (26 lb–ft).
8. Connect the negative battery cable.
9. Install the oil pan drain plug.
Tighten
Tighten the oil pan drain plug to 35 NSm (26 lb–ft).
10. Refill the engine crankcase with engine oil.
Jun 14, 2008 | 2005 Suzuki Forenza
Error Message
you either have a flex cable problem or your camera is faulty. your first and easiet option is to change the camera...the second option is to check or replace your main flex cable. you need to check a cell phone service repair shop to deal with tnhese issues.
sam !
May 03, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Camera Problems
try to open the top flip there are four screw covers around your display then take them out whit a little pin then take the screws out whit the t5 screw driver after that hold the caller id down whit your left hand and pull up the top flip whit ur rigth hand or u can use a thiny plastic around the top flip to take it out after u take it out u will see two flex cables on the top one is the end of the camera and the other is the end of the flex cable. pull the flex cable up and desconect it clean the flex cable connector whit alcohol or just blow it then put it back a little hard till u heard the click then try to clean the camera connector there is a little brown plastic on the top of the camera connector pull it up and open it like a door after u clean it put it back and close it then put the side keys back if they were moved then the top flip, screws, and screw covers. if the problem still u have to buy the lcd display but the lcd is too expensive it would be better to buy another v3
Jul 14, 2007 | Motorola Mobility RAZR V3
Kitchen Ranges Logo
73 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
