Question about GE Profile : Profile Spacemaker 1.8 Cu. Ft. XL1800 Sensor Microwave Oven
The stove light in my Ge Spacemaker XL1800 went out. I took the panel off the bottom (it's about 2 1/2 by 6 inches ) and I see 2 wierd little bulbs I cannot remove easily. What to do? Thanks,
I have the small panel off but don't see how to get bulbs out
  • 937 Answers
Here is the owners manual:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40570-2.pdf
The bulb changing instructions are on page 35.
It basically says pull the bulbs straight out and replace with WB36x10213 halogen bulbs.
Posted on Nov 25, 2014
MicrowaveSvc
  • 9047 Answers
SOURCE: My ge profile spacemaker xl1800 turntable stopped .
It's probably a bad turntable motor or coupler.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Broken handle on GE Spacemaker XL1800 microwave
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 07, 2008
vitg55
  • 70 Answers
SOURCE: My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Posted on Dec 15, 2008
SOURCE: have a ge spacemaker xl1800 - f3 error
I had the same problem. I removed the grill and opened the control panel as I read an answer from "GENE" on APP (Appliance Pros) that this indicated a short in the circuit board (TouchPad). I was going to replace the faulty circuit board but when I opened the control panel there it was......One wire harness had just came unplugged!! I plugged it in, reassembled and the microwave works again!
Mike
Tampa, FL
Posted on Jan 14, 2009
  • 3 Answers
SOURCE: I have a GE Spacemaker XL1800, no heat and a humming noise.
magnetron problem DON'T KNOW IF WITH FIXING - WOULD LIKE TO KNOW MYSELF
Posted on May 03, 2010
G.E. profile Spacemaker XL1800 over the range microwave. the microwave comes on but dose not make anything hot. what is the fix & where is the replacement part located ?
We would need the full model number and we would need a little more information.
Please repost here with that information, and let us know - when you press "Start" to cook - if the inside light, turntable, and internal cooling fan all come on.
Nov 28, 2012 | GE Microwave Ovens
GE Spacemaker XL1800 microwave suddenly didn't work. All buttons on the front panel except "Clock" don't work. Open the machine, shorten the thermostat, the vent fan runs automatically....
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ==-
Sep 14, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker XL1800 Adora Microwave (manufactured in 2004) and the light bulb went out but I can't located it to replace it. Where is it located? Thanks
If it is meant to be user replaceable, then your owner's manual will cover it.
If not, then you may need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Either way, you can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jan 17, 2011 | GE XL1800 1100 Watts Microwave Oven
Looking manual on how to change bulbs of microwave GE Profile Spacemaker XL1800, Model #JVM1870WF06
See pages 35 & 36 of the owner's manual here.
If your lights are struck on, you'll need circuit board repair. Details are here.
Aug 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do i unlock the control panel on my GE Spacemaker XL1800?
directions are behind the door toward the bottom left. all you have to do is press the clear/off button for three seconds.
Oct 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Apr 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile : Profile Spacemaker 1.8 Cu. Ft. XL1800 Sensor Microwave Oven Logo
241 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
