Question about Peavey Music
What is the value of rex040 on a peavey ul15 protection board
    Master:
  • 752 Answers
Is this discussion any use to you Cliff ? it mentions contacting Peavey, which you might try...
http://peavey.com/forum/viewtopic.php?f=26&t=2260&p=19183
25.November.2014
Posted on Nov 25, 2014
I have a peavey max 126 bass amp and am looking for a schematic or even just the value of the resistor in r22. Can you help?
If the resister is still intact, upload a picture of it and I will tell you the value...
Aug 20, 2017 | Peavey Music
Peavey KB100 EQ pots what value?
should say on the back of the pot
Mar 02, 2015 | Peavey Music
I require a circuit diagram
More information needed please. Is rex040 a part or a model number? What is the device?
Nov 25, 2014 | Music
I need to know which volume control I need for a Peavey century 120 series bass head
Man this is a tough one....I can't locate a schematic anywhere online so I suggest calling Peavey In Mississippi and talk with technical assistance. A helpful tech can pull the paperwork and give you the correct value in about 2 minutes. Good luck.
Dec 19, 2013 | Peavey Music
Peavey xr600f
R252 = 680 ohms
R255 = 680 ohms
May 20, 2013 | Music
Peavey SP3 (older model) Can not get any sound thru horn.
They have a "soundgard" protection network that uses a polyfuse and an automotive lamp. Open the unit and check the circuitry. Both the polyfuse and he lamp may be blown. Do ohmmeter check of these, otherwise the horn is blown.
Aug 08, 2011 | Peavey New Peavey Sp3 15" 3 Way PA Speaker
Blown fuse on the board.The fuse is so welded in? does this fuse control the crossover?
There is a speaker protection network in most of Peavey speakers protecting the tweeter horn.
It consists of a Polyfuse (round disk about the size of a nickle or quarter, a resistor and an incandescent bulb.
Circuit can be found at: (go to last post attachment) http://forums.peavey.com/viewtopic.php?f=26&t=2260
Copied from earlier post I made for another.
For the MOST PART the lamp is NOT the primary path for the speaker current, the POLYFUSE is and is a low resistance until it is overdriven.
The bulb is a 12 volt bulb and is nominally 2.1 amps when used on 12.8 volts.
If this is in regards to the other problem mentioning 32 watts and 12.8 volts... this bulb is NOT 32 Watts, it is 32 CP or 32 Candlepower which is NOT Watts in general. The lamp is actually around 27 Watts when run at its ratings.
It is important to realize that the lamp and the resistor are there ONLY as a "soft" path when the POLYFUSE opens due to overcurrent. When the polyfuse cools, the lamp and resistors are effectively shorted by the Polyfuse and most of the current again flows through the polyfuse..
Mar 06, 2011 | Peavey PR15 400w PA Speakers
Could u please send me a circuit diagram of Peavey sp2 crossover with the exact rattings or values of the parts? cos the image of the bulb you have sent is different from the one in my speakers
Here is a link to forum that someone has posted the soundguard protection circuit down the page:
http://forums.peavey.com/viewtopic.php?f=26&t=2168&view=previous
The 1156 lamp MAY have slightly different shapes but is an automotive lamp. If the bulb is blown, the polyswitch fuse is likely blown as well.
Jan 14, 2011 | Peavey SP2 PA Passive Speaker
CAN I POWER UL15 AND XT115 [WITH CROSSOVER] WITH 1 AMP
You need 1 channel of amplifier per stack. Assuming the ul 15 is a full range box, and the XT115 is a subwoofer. But be careful with your Ohm ratings for the speakers and your power ratings of your amps. You want the proper Ohm load on the amplifier for maximum power. And use proper speaker cable, with correct wiring.
Wire the to the sub first, and then jump to the ul 15.
Feb 20, 2010 | Peavey Pv 2600 Power Amplifier
Peavey SP 2G has a burnt ceramic capacitor in crossover
Ive been through this. Although it certainly appears to be a ceramic capacitor, its actually called a polyswitch. .65 amp. Parts express carries them. Part no. 071-256.
Mar 28, 2009 | Music
Music Logo
52 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
