Question about Juicers
Pusher stuck in fusion juicer
Pulling twisting running under hot water
  • 27 Answers
May not be repairable if pusher is distorted or damaged. If jammed with a foreign body, need to carefully pry apart and clean out. Find a handy person and offer a fine juice meal.
Posted on Nov 25, 2014
I need to remove the parts for washing How I do this?
Things You'll Need:
  • Soft-bristled brush
  • Stiff-bristled brush
  • Dishwasher (optional)
  • Mild detergent
  • Lint-free microfiber cloths
  1. Unplug your Acme 6001 Juicer. Carry it to a countertop near your kitchen sink.
  2. Remove the pusher and cover, and set the pieces in a sink. Unscrew the clutch, remove it and set it in the sink. Remove the cutter blade, strainer basket and juice bowl, and place the pieces in the sink.
  3. Discard or remove and store any pulp that you find in the strainer basket. When you're finished, rinse the remaining fruit and vegetable pulp and juice from the pieces under cool, running water. Dislodge hard-to-remove pulp from the cutter blade and strainer basket with a soft-bristled brush or with a stiff-bristled brush if necessary.
  4. Wash the pieces in a dishwasher or by hand. To wash in a dishwasher, place the stainless steel pieces in the lower rack and the plastic in the top rack and wash on a normal cycle with other kitchenware. To wash by hand, fill the sink with warm water and a few drops of mild detergent and wash with a lint-free microfiber cloth.
  5. Run the pieces through the rinse cycle in your dishwasher or rinse under running tap water by hand. Air or wipe dry the pieces.
  6. Wipe the base with a slightly soapy cloth. Rinse with a damp cloth and wipe dry. Reassemble your juicer by returning the pieces to the base in reverse order.
     for a visual:http://www.youtube.com/watch?v=alumocbDHg4
     "DON'T FORGET TO VOTE PLZ"
Jan 28, 2011 | Acme 6001 Juice Extractor
Cannot twist off the filter basket of the breville JE 900 Juicer
I had the same problem. It must juat got a bit stuck - I gave it a really good twist anti-clockwise and it came unstuck and popped lose.
May 13, 2010 | Breville JE900 Juicer
I was putting re-juicing a clump of wheatgrass and the omega juicer stopped. Now I can't unscrew the front piece off to get the wad of wheatgrass out. Help! I tried to run it under hot water.
I soaked it in hot water and it loosened enough to unscrew the outer portion and also moistened the stuck wheatgrass enough to pull it out. whew.
Jan 20, 2010 | Omega 8001 Wheatgrass Juicer
Jack Lalanne pusher is stuck in the shoot, was put is the wrong way. Can not pull it back out. Any suggestions.
Heat or cold makes things small or big. Soak it in warm water or put it in fridge then try to take it apart. Hope it helps.
Nov 19, 2009 | Jack Lalanne Power Juicer (Stainless...
I have the Jack Lalanne juicer. After cleaning the pusher, there is water stuck inside of it. How can I get the water out?
Drill a small hole, take the water out and cover the hole with glue. Or put it in a sack of uncooked rice for 2 days. Or put it in a bag of silica desiccant gel. You can buy it cheap from ebay.
Sep 29, 2009 | Jack Lalanne Power Juicer 250 Watts
Pusher is jammed and won't come our
there should be a flat part on the pusher and a flat part on where you put it into...This happened the first time I used it. It will take 2 people but one of you holds the machine while the other pulls on the pusher. I recommend the stronger one pull. Also make sure it is unplugged and that it is off.
May 22, 2009 | Jack Lalanne Power Juicer 250 Watts
Pusher is too long
Buy a file or sandpaper from a hardware and file off the part that touches the blade. I've done this no prob.
Jan 08, 2009 | Jack Lalanne Power Juicer 250 Watts
Pusher won't come out
Hi,my name is patricia ,and i found a solution,first the black button .the black vise grip put it in the blade while the blade is still in turn the black vise grip to the left while still in the blade keep turning to the left and the blade will come off of the black button.the black button do not come off or up.When you put food in but smaller pieces in and have all your pieces near you so you can continue to drop in in the processer while running it and can slowly put the long tube in to keep food from splashing do it slowly .hope that help
Aug 27, 2008 | Jack Lalanne Power Juicer (Stainless...
Jack Lalanne's Power Juicer Pusher Stuck
It will take two people to get the Lalanne Juicer pusher unstuck. We wrapped a sock inside a sock and put the top part of a hammer in the sock, then I lifted the large white part up while he hammered the pusher out. It took 6 hits and voila!
May 17, 2008 | Jack Lalanne Power Juicer (Stainless...
Juicers Logo
166 people viewed this question
Top Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
