Have a brada washing machine top loaded and its making a sound when on wash doesnt sound right what could the problem be
Well ive took of the back of the machine cause originally thought it was actual pump as if something was lodged ...but it rinces and spins fine ....its the noise it makes on wash cycle i turned it right off ...my machine does not have an agetator but thats where i think the problem is what is it and how can i fix
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Very hard for me to guess without knowing more.
The machine must be on a level surface.
To determine this you need a tool called a level.
The longer the level is the better it will measure flatness.
Someone local seeing it might be best.
Short of that, here's what I would do.
Determine if it's the clothes (imbalanced) causing the problem.
Do a wash with no clothes in the washer.
If the problem continues, it's not the clothes.
Good luck. Happier Thanksgiving.
Posted on Nov 26, 2014
  • 641 Answers
SOURCE: Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Posted on Jul 26, 2007
dauphine
  • 207 Answers
SOURCE: Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Posted on Apr 11, 2008
SOURCE: maytag pavt234aww
I had to replace the pump assembly, the pulley has a bushing in it that was working its way out and rubbing against the base plate of the machine.
Posted on Feb 14, 2009
  • 151 Answers
SOURCE: GE Prodigy Washing machine making clunking noise
One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
Posted on May 03, 2009
  • 6 Answers
SOURCE: I have a Westinghouse mastermind 708 washing
I would check the internal coin trap/drain to make sure it is not blocked with socks or 3-in1 dryer sheets. If the water does not drain it backs up and causes error messages and spin problems. These are normally not listed in the manual so you have to take off a panel to find it. Could be at the bottom or in the back. Unscrew and check the trap and remove any blockage. Prepare for a mess if you can't fit a bucket under the trap!
Posted on Oct 23, 2009
On spin cycle, buzzing sound but doesnt drain or spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 27, 2011 | Kenmore Washing Machines
We have a load in....it is full of water....it wont drain and spin...the cancel button doesnt work and door wont open....I checked for kinks in drain hose...none. I took off top panel and front lower...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Nov 12, 2010 | Kenmore Washing Machines
The dial moves forward several numbers when set on a wash and it does not spin, it drains, makes a sound as if its going to spin but doesnt. The clothes are not washed properly nor spun when I eventually...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 02, 2010 | Washing Machines
Top load washing maching does not complete the cycle
Sounds like you have a pump issue, make sure it is not blocked or restricted :)
Jul 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
The washing machine doesnt aggitate
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | GE WBSR3140DW Top Load Washer
Water still behind the drum .
i giot the same thing happen to me and the brink says its normal also samsung says it normal too it doesn't make sense to me because all the other brand don't have any water in the drum after.....im trying to find some one with the same model so i can check to make sure its mormal because the brick is no help what so ever
Feb 23, 2010 | Samsung Washing Machines
Washing machine zanussi jet wash
unplug machine turn water off then take water pipe off machine,take machine outside and lay on its back,there is two moters up in the top right off machine looking in the bottom of machine, undo the three pipes and two/three srews take both pumps out undo three screws on the top pump split it and unblock then pup it all back.remember to right down wot you have done to pup it back right,it took me approx half hour to fix mine
Mar 26, 2008 | Zanussi FJS1225W Front Load Washer
My washing machine wont drain the water
if its making a humming sound the pump may be blocked turn the pump fan by hand to see if its free,
Mar 14, 2008 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
