Question about Westinghouse LTV-40w1 HDC 40.02 in. LCD HDTV
Remote control I am not electronic savvy in the least. I cannot program my remote control for my new LTV-40w1HDC Widescreen DVD Combo. I need Help using the simplest of terms. Thanks!
Re: remote control
Need to set up a remote control to my tv. I lost instructions and codes.
Posted on Nov 12, 2007
0 characters
3 Points
Looking for the AT&T uverse remote control Proscan 24" LCD combo TV/DVD
If you wish to know its programming procedure, check the sites linked here. it is difficult to type all all here by this wondow.
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 08, 2014 | Proscan 26LB30QD 26 in. LCD HDTV
Westinghouse LTV-32w4 HDC widescreen DVD Combo
Hi Mouse999. From reading a bit, it seems that there's no region free hacks for the built in dvd player in that specific model. A solution for you, would be to purchase a standalone dvd player, one that is region free or one that has a region free hack available, and to connect it to that tv. If you're in europe and your tv is pal, you also need to have a dvd player that will read both Pal and NTSC video dvd's ! If that doesn't help, please be more specific, i'll be glad to help. Thanks, cheebster.
Jul 10, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Got new tv Westinghouse LTV-32W1 32 Inch Widescreen LCD TV LTV-32W1 in need of help! do not have the remote and trying to progam it to turn on but blue light turns green and picture turns blank
in this case i have to know if your tuner is working fine or not. First of all i like you to connect any external player Exp. DVD or blue-ray player if that works with audio then it is inverter board. if audio doesn't work then its main board. Also you will find out that if dvd is working fine on your tv than your tv setting is wrong or the tunes is dead. either way if tuner is gone then you have to change the main board. Either way let me know what went wrong i can provide you more information about what part need and where can you get it from.
Please let me know if you have any further questions or concerns. Also rate me if you like this post.
May 11, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Dvd stuck in RCA widescreen tv
There are two things you can try to correct this problem on your TV/DVD combo unit:
  • If you're using the remote control, press the DVD/TV button first to make sure the remote control is in TV mode.
  • If you're trying to use the buttons on the front of the unit, unplug the TV/DVD for two minutes, and then plug it back in. Press the ON/OFF button and try again.
Feb 20, 2010 | RCA L40HD33D 40 in. LCD HDTV
I get no picture turns on bulbs are working but I get no pic with tv or dvd and I cant see the menu or any of its properties .... but I do get sound, Thanks. The lcd tv is a westinghouse 40 inch dvd...
You need a T-con Board and I have that one for $80.00.
I reclaim working components for TV damaged in shipping or returned for other reasons. Simple repair for any body with a Philips screwdriver. NO special tools needed.
Jul 11, 2009 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Programm bell expressvu 4100 remote control
I had the same problem. I used the code 660 and that works fine for power, volume, and stations for my Insignia with the bell remote. Hold tv button till all 4 lights light up and then press 660 # and everything (minus the menu option) should work. I also tried these insignia codes (which might work if this dont.) 659, 573, 570, 405, 245, 456.
Mar 09, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Program Remote
I had the same problem. I used the code 660 and that works fine for power, volume, and stations for my Insignia. I also tried these insignia codes (which might work if this dont.) 659, 573, 570, 405, 245, 456.
Feb 05, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Cannot return to TV from DVD play
If you have a Directv receiver, and you have to be on channel 3 on the TV to watch it, then we have to get you off the video input. On a Directv remote, there should be a button toward the top left hand side that says "TV input." Try pressing this first. If that doesn't work, then look for the button on the Insignia TV remote control that says "tv/video," "source," "input," or something along those lines. Press it (some TV's make you press it several times to change the input). Just make sure that your Directv receiver is on before you start pushing buttons.
Give that a shot.
Jan 06, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Will a universal/replacement remote work with a Tv/Dvd combo?
Go to lidl store and buy a replacemrnt remote control for £6 and that will do the job for you. Ted10
Jan 06, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Instructions for Programming Innovage Jumbo Universal Remote
You can download documentation for the Innovage remote here:
Dec 31, 2007 | Flat Panel Televisions
Flat Panel Televisions Logo
163 people viewed this question
Top Westinghouse Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Westinghouse Flat Panel Television Expert? Answer questions, earn points and help others
