Question about Dishwashers
Grainy food residue is being left on my plates from a brand new commercial Electrolux dishwasher. Spray arms checked, machine and filters cleaned frequently. Tried different detergent. Even clean plates come out with this sand-like food residue on them. Help!!
    New Friend:
  • 4 Answers
Contact the manufacturer. There may be a problem with the unit. It should be under warranty.
Posted on Nov 25, 2014
  • Ricky Froldi Nov 25, 2014
    I have had 3 call outs which hasn't improved the issue. Also sent a letter of complaint to the manufacturer to which I have had no response.
2 Suggested Answers
omaharox
  • 166 Answers
SOURCE: My Maytag MDB7130AWB dishwasher is leaving detergent residue
Replace the water supply valve under the sink and water supply line to dishwasher.
Over time as you can see minerals deposit in the valve and restrict the water flow to the dishwasher.
This is especially inportant on todays water saving units.
Many people replace an old dishwasher and hate the new unit due to a white film left on dishes.
Although you may have paid for a professional installation a new shut off valve is almost never replaced even though the waterline may have been at an additional cost to you..
Posted on Jan 09, 2010
Indesit D41 Dishwasher draining problem. the filter on my dishwasher isn't letting through water, I attacked it with a plunger but I don't know how to open it up to unblock it. please help
First check this. Clean the water inlet filter at the tap outlet regularly. - Turn off the water tap. - Unscrew the end of the water inlet hose, remove the filter and clean it carefully under running water. - Replace the filter and screw the water hose back into position.
Then, if needed check this. Cleaning the filters
The filter assembly consists of three filters which remove food residues from the washing water and then recirculate the water. They should be cleaned if you wish to achieve the best results in every wash. Clean the filters regularly. The dishwasher should not be used without filters, or if the filter is loose. After several washes, check the filter assembly and if necessary clean it thoroughly under running water, using a non-metallic brush and following the instructions below: 1. Turn the cylindrical filter C in an anti-clockwise direction and pull it out (fig. 1). 2. Remove the cup filter B by exerting a slight pressure on the side flaps (fig. 2). 3. Slide out the stainless steel plate filter A (fig. 3). 4. Inspect the trap and remove any food residue. NEVER REMOVE the wash cycle pump (black detail) (fig. 4).
Always keep the door of the appliance ajar in order to avoid moisture from forming and being trapped inside the machine. Clean the seals around the door and detergent dispensers regularly using a damp sponge. This will avoid food becoming trapped in the seals, which is the main cause behind the formation of unpleasant odours.
Preventing unpleasant odours
Food residue may become encrusted onto the sprayer arms and block the holes used to spray the water. It is therefore recommended that the arms are checked from time to time and cleaned with a small non-metallic brush. The two sprayer arms may both be removed. To remove the upper sprayer arm, rotate the locking ring in an anti-clockwise direction. The upper sprayer arm should be replaced with the holes facing upwards. The lower sprayer arm can be removed by pressing on the side tabs and pulling it upwards.
Cleaning the sprayer arms
After cleaning the filters, replace the filter assembly and fix it in position correctly; this is essential for maintaining the efficient operation of the dishwasher.
Leaving the machine unused for extended periods
If the water hoses are new or have not been used for an extended period of time, let the water run to make sure it is clear and free of impurities before performing the necessary connections. If this precaution is not taken, the water inlet could become blocked and damage the dishwasher.
Cleaning the water inlet filter*
Disconnect the appliance from the electricity supply and shut off the water tap. Leave the door of the appliance ajar.
When you return, run a wash cycle when the dishwasher is empty.
That should cover all your bases
Oct 21, 2013 | Dishwashers
Electrolux-Arthur Martin ASF 64013 My dishwasher shows a red light under the sign ->[. It does not wash properly, soap is not completely disolved and stays on the bottom. I haven't got the user...
do the basics first - check the spray arm jets are completely clear at the very ends, and machine filters are clean. Remember dishwashers are not garbage disposal units - ensure all food is scraped from plates before putting in the machine, or it will work its way to the spray arm jets.
Does machine fill with water, does the circulation pump run on wash, does the water heat up?
Does the machine finish the program in a couple of minutes before that symbol displays? it could be the program has aborted due to not draining well. But check the spray arms first as they very often become blocked and no longer turn.
Feb 03, 2018 | Dishwashers
Hi there, I have an ESL424 Electrolux dishwasher and I'm having some problems with it not washing dishes properly. Is there any common reason for this? The problem seems to be more apparent in the top...
first thing is to ensure the top spray arm is turning freely. make sure nothing is blocking it, for example one of them dishwasher fresheners.
also check the holes on both spray arms to ensure they not blocked up, also if you can remove the spray arms and clean them out, also clean out the filter.
i also always susjest putting the upper basket on the highest setting as high plates etc. in the bottom basket can stop spray arm turning
after checking all of the above, put the spray arms in the 12 o clock posistion and turn the dishwasher on, when it starts washing open the door to see if they have moved.
also always use a good quality diswasher tablet, cheaper ones dont always give good wash results.
Jun 25, 2011 | Electrolux 18 in. ESL424 Built-in...
Food is being left on dishes, not cleaning well. Residue on glasses and pans(white) You can feel a grainy residue on cups and bowls
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Feb 23, 2011 | KitchenAid Dishwashers
Tablets not dissolving no matter what brand of tablet, and not cleaning plates and glasses. Have cleaned all filters and salt and rinse aid dispensers are filled up. What could be the problem?
Dishwasher
How to Buy
heatman101
Dec 08, 2010 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Whirlpool ADG 7550 integrated dishwasher not cleaning properly. Ive checked the filter and there are no signs of blockage. There is no unusual beeping but there is however a weird motor noise that just...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
zcvb
Jul 05, 2010 | Whirlpool 24 in. ADG7540 Built-in...
I have a 5 year old frigidaire electrolux dishwasher that is leaving a grainy residue after a wash
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 18, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Residue and small particles left in upper rack dishes and glasses. maytag mbh940aww dishwasher.Is there a filter to clean?
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Yes there will also be a filter in the base of the unit to clean. This needs to be done regularly to avoid food getting into the working parts of the unit.
Jan 24, 2010 | Maytag Dishwashers
Food particles left on dishes
Many times this caused by food particles clogging the screen or blocking the jets on the spray arms. Find the screen in the bottom of your machine and clean it out. If this doesnt help, remove the spray arms and clean them out.
Jun 17, 2009 | Dishwashers
Hotpoint Aquarius DF61 Dishwasher & Food residue remaining
i have cleaned the filter on my hotpoint aquarius DF61 on cant put it back together.
Nov 17, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
