How do i remove a motor from an otis 77D machine
Nothing so far.
  • 47 Answers
Go to utube.com and do a search and see if you can find instructions.
Posted on Nov 26, 2014
Repair Problem
HI Otis,
I repair LCD Screens in Playstation Portables all the time.  If I can find a replacement case for your garmin I know I can do it.  Give me a little time to locate what you need as far as parts. Do you need a LCD screen or just a case or both? www.playstationclinic.com
Oct 14, 2007 | Garmin StreetPilot 2720 GPS Receiver
How do you remove protect feature
Hi Otis,
Take-off the SD Card.
There is a small button on the left side.
Slide it UP carefully to unlock the card.
That should remove the protect feature, if not write back with the make & model of the camera.
Good Luck!
JP
Oct 12, 2015 | Cameras
I lost the cord to my town craft electric skillet, haven't been able to find one, now Otis leaking oil from just sitting there
I have never hear of any one naming there electric skillet but if "Otis" is leaking oil then he has probably seen better days and it might be better to just replace him.
Apr 12, 2015 | Kitchen Appliances - Others
How do I remove the motor from a 77D machine
Unplug the machine and leave in this state for a few hours. Might be best to have the unit powered on and possibly running if you can when unplugging. Many units will have covers made of plastic that have screws that need to be removed. These screws may have small plastic button pieces that could be covering the screw heads. Sometimes a small flat blade screwdriver can be used to remove these screws. Otherwise try looking on the bottom side of the plastic near the rear end and the front to see if you can find screw heads. Take pictures and remove the screws. The motor should be found near the front.
Nov 25, 2014 | Exercise & Fitness
Pdw u1
Re format your computer that will fix it
Apr 25, 2014 | Sony Televison & Video
I'm new to sewing, have threaded my bobbin, installed it in its casing, and threaded my machine. But when I take the needle down to pick up the bobbin thread, nothing happens. I've taken the bobbin out...
I am having the same problem !! was sewing fine then it stopped, have changed the cotton, needle, took case out and put back in , checked tension on all settings but still not picking up the cotton . Motor works fine and every thing all seems ok but cannot figure out why its not picking up the thread.All i can think is needle is not going down far enough to make contact but took needle out and lowed it but still nothing. Hope some one can help !!!!!!!!!!!!!! PLEASE
Jan 15, 2011 | Singer 1507
My treadmill's incline goes up and down but the treadmill will not start. What could be the problem?
The motor controller. If everything works but the belt will not turn, that's 99.99% your problem. I can get you a controller and walk you through replacing it. Otis@otisfitness.com
Nov 17, 2009 | Icon Image 17.5 S Treadmill
Please help!
remove bottom panel remove as much water as possible from tub ..have lots of towels handy remove clean out port on pump clean and reinstall...also ck as far into pump for something jammed in impeller ..pump may need to be removed to clean if unable to clear jam ..3 screws hold pump motor to pump body remove if necessary also ck to see if pump impeller is spinning freely on motor shaft should be some resistance when turning if impeller spins freely replace pump
Oct 04, 2008 | Kenmore Elite 45986 Front Load Washer
White Sewing Machine 979
I'm sorry I don't know this model, but will try to help you.
Are the buttons still functioning - or is one deffinately seeming broken?
Try selecting other functions and see if there is any life at all.
If there is no life in it whatever, remove the fuse (test it) and replace.
If still nothing, There is an electrical fault either in the foot pedal, or motor.
These can be tested with a meter to determine the fault.
Repair of the motor or footpedal (dependent on tests) may be required - usually the motor.
Hope this helps - if so, rate as fixya!
If not, I'll try and Identify the fault.
Thank you for using Fixya!
Jun 14, 2008 | White Sewing 979
Open Questions:
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
