How canIenter my unique numbers if the page form does not show on the screen
  • Computers & ... Master
  • 3,368 Answers
That all depends on what email program you are using. Either check the manual or use the help function.
Posted on Nov 25, 2014
Tip
Dreamweaver Thought that Teaches You, to search a database with phpmysql...
OK, this should work... First of all, there is one great extension for DW & PHP ADOB object model that is free and great! Download it and install from www.interakt.ro its called PHAKT (NOT impakt, because its not free).
Install it and you will have another type of PHP ADOB document type.
Start project with PHP ADOB (not old PHP MYSQL).
Page 1
Create form that has come Editbox and one button. Name Edit box something like e.g. "Search" without quotes.
That form should have form action="results.php" and type set to POST NOT, Create Page 2 and name it results.php.
Create new recordset in dw like this
SELECT "
FROM table WHERE table.column.you.r.searching LIKE '%colname%' OR table.other.column LIKE '%colname%' ORDER BY table.tableid this means that we want to select ALL (*) records in table WHERE content of column is similar (Dav, will return Dave, David, Davidof...) to search keyword.
Next, in variables click + and add variable name colname default value set to % if you want to show all records if form is submited blank, or -1 if You want to show none if form is submited blank. Finaly for Run-time value type $HTTP_POST_VARS['search'] Runtime value is equal name of Edit box name you set up in first page...
Now, from bindings tab, select values and insert it on page, that You would like to show on page. Ill skip this part assuming You know how to format output and how to limit it but if you dont know ask in reply...
So now You have page with results. Test it and see if its working.
If it is, create page 3 and name it details.php. Now, select value from page that you want to link with details page and click on link. Select details.php page and click on parameters. For param name enter something like id since this should be PK in table and unique value, and for value click on lightning icon, and select primary key in your table. In live page link should be like details.php?id=<some_value>.
As for details page recordset it should look like
SELECT *
FROM table
WHERE table.id = 'colname'
create vars as for page 2, but change Runtime to $HTTP_GET_VARS['id']
and format output on page. That should be it, but since im typing it in "realtime" maby i forgot something...
Home I did helped You.
on Jan 21, 2010 | Computers & Internet
Samsung gravity t cell phone unlocking
hai, your question hasn't correct form. If you want to remove or unlock your t-mobile network lock in your samsung gravity, use unlock codes.
1 - Switch ON your Samsung Gravity without any SIM Card.
2 - From the standby screen, use the dial pad to enter the number sequence.
3 - Compose : #7465625*638*CODE#.
4 - Device should say: "Network Lock Deactivated".
Each Samsung Gravity mobile phone has an unique unlock code. You can get the unique unlock code for your Samsung Gravity mobile phone at TheUnlockArena.com
Sep 09, 2012 | Cell Phones
Need an owners manual for model d120
I would suggest going to http://www.jennair.com/flash.cmd?/ and looking under their Customer Care menu option.
I could not find a range with model number d120 in their lists. Under Customer Care select Find Model Number and then select Ranges from the list. The site will then show a number of pictures of different models and where the model number is located on those ranges.
Once you have that go back to the home page and under Customer Care select Find Guides And Manuals. Select the Consumer option in the first form field and input the model number into the second form field.
Jul 03, 2012 | Jenn-Air Kitchen Ranges
How do I do this "Type the unique PIN into the
Hi rhienjen,
Each router has its own unique PIN. The PIN will be asked only once for setting up your router.
You can find the unique PIN behind the router written on a sticker which states the model number, serial number and the pin number.
If this information was helpful for you, please rate it.
Thank you for using fixya,
Arun Zac
Nov 27, 2010 | D-Link DI 514 Wireless Router (DI-514)
Do you have the Paragon Replacement Mech in a 220V?
Fixya answers questions about broken things and missing manuals.
Paragon has a replacement part page:
http://www.paragontimecontrols.com/parts_accessories.htm
You need model number of timer.
Page shows Order form for trippers on left side a bit below 'contact us.
But page doesn't have clear-cut way to order other parts shown on page.
Nov 19, 2010 | Paragon REPLACMENT MECHANISM 110V SPST -...
Hi! I am having a problem editing page numbers in adobe
Rotate the page before inserting a box for the page number. You have to use the Forms function to insert a box and add the page number. Then Rotate back. Then print the form to PDF. When you open page number will be where you placed it.
Nov 24, 2009 | Adobe Acrobat Professional 7.0 for PC
What is imei number?
The International Mobile Equipment Identity or IMEI (pronounced /aɪˈmiː/) is a number unique to every GSM and WCDMA and iDEN mobile phone, as well as some satellite phones. It is usually found printed inside the battery compartment of the phone. It can also be displayed on the screen of the phone by entering *#06# into the keypad.
May 29, 2009 | Nokia 1100
How to take self test page form Canon LBP-2410 printer
Go to printers and faxes, right click on the LBP-2410 go to properties at the bottom and you'll see the print test page on the General tab
May 06, 2009 | Canon LBP 2410 Laser Printer
Increment a number per record in Microsoft Excel
For what you are talking about doing, Microsoft Access would probably be a better option. With Microsoft Access, you can create a custom form and have it automatically give a number.
More information about Access:
http://www.bcschools.net/staff/AccessHelp.htm
Dec 18, 2008 | Microsoft Excel for PC
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
