Question about Refrigerators
Portable ice maker
Second time i've used the ice maker. It powers up but compressor doesn't turn on. Worked perfect the first time i used it. Any feed back would be appreciated.
  • Jim Ford
    Jim Ford Nov 25, 2014
    Collezioni portable ice maker Mod #ps78111
  • Refrigerators Master
  • 3,368 Answers
Great question but there are a lot of ice makers out there. If you want somebody to help try posting the make and model number.
Posted on Nov 25, 2014
Emerson icemaker gets hot checked it out it's the compressor can this be a reason why my machine want make ice
Heat cannot produce ice
How To Fix Refrigerator That's Not Making Ice ' Fridge Repair
www.partselect.com/Repair/Refrigerator/Not-Making-Ice/
Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common problems and parts like water inlet valves and water filters.
1 How to fix a portable ice machine part 1 of 3 - YouTube
? 8:44
https://www.youtube.com/watch?v=oyaO_Q6CBUM
Apr 18, 2009 - Uploaded by SteveJ619
Part 1 of 3 on how to fix your portable ice machine. ... Fanstopped working on mine, is it an easy repair? ... Dumping theice maker upside down can damage the refrigeration compressor ! .... Emerson Portable Ice Maker - Emerson Portable Ice MakerVideo Review -portable ice maker - Duration: 3:57.
Jan 07, 2016 | Emerson Refrigerators
Compressor not turning on
check wiring for loose connection to compressor relay
Sep 05, 2014 | Sunpentown SPT IM-100 Portable Ice Maker,...
My ice maker will work 1 cycle and then it wont work again for a few days. I can here the compressor start up and it hums for 10 seconds then a click happens and its over. No more humming.
Compressor over load switch is the clicking you here. check the compressor to see if it has a start capacitor if so check to see if it is good. if it dose not have one then check compressor relays make sure there in good working order.
Jul 01, 2013 | Sunpentown SPT IM-100 Portable Ice Maker,...
Hi. We moved to a house with an integrated Teka A-FC1359 Fridge/Freezer. It was working fine. We switched it off 3 months ago. Now we've swithched it back on but it's not working.
It can be issue with faulty compressor capacitor.From main power outlet the power goes to capacitor beside compressor and from there power goes to compressor motor,then after that all unit works.May be that capacitor got shorted or loose from its actual connection.Or other possibility is faulty power wire of refrigerator.Get the wire checked with continuity tester to confirm its not broken in between.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
We have an Emerson IM90 portable ice maker which has worked fine for months. Now it is only making 5 ice cubes per baych. Any ideas?
when mine did that i got out the air compressor and blew all of the dirty and stuff off of the moter and low and behold it worked great but be carefully I tore a blade off the fan and now it runs alittle noisey. still makes great ice now I gonna find another fan blades. you need to unscrew the back to do this.
Aug 29, 2012 | Emerson Im90 Portable Ice Maker
Emerson ice maker not freezing ice, making small cubes and they are soft and mushy.. seems to not freeze ice solid and takes forever to drop ice
When was the last time you cleaned it by running ice machine cleaner through it. After a period of time algea, or slime will form on the chill plate where the ice is made. Sometimes its invisible to the eye, but it doesn't mean its not there. When this happens the machine will freezse the water, and when the ice tries to slide forward to the cutting grid, it catches on the chill plate. There are no sensors in the machine to tell it that this is happening and so the machine moves forward and starts running more water across the plate, which in turn runs across the ice caught on the chill plate melting it and using it as a ramp to fall into the bin melting the ice there as well. So, try cleaning it before taking any further steps, then if the problem persist feel free to get in touch.
May 15, 2012 | Emerson Im90 Portable Ice Maker
Our Ice maker is not producing ice. I've tried using a hair dryer to melt possible frozen water. It worked once, but now that ice maker is back to not producing ice.
The heating element is not working to heat the base and free the ice from the tray. At this point it's probably better to just replace the ice maker. They are about 60-70$
May 19, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
