Question about Husqvarna Garden
The area where the spark plug screws into is stripped out. How do I fix that? I have a Husqvarna 455 Rancher
    New Friend:
  • 76 Answers
If the helicoil does not fit perfectly ( and it has to be tight because of the compression from the engine will just blow it and the plug out, you can take some drastic measures and JBWeld the Helicoil into the block.
Posted on Nov 25, 2014
    Master:
  • 467 Answers
The threads can be repaired using a helicoil. Here is an example. Just make sure to get the correct thread for the unit you are repairing.
Helicoil 5334 14 Save Thread Thread Repair Kit M14 1 25
  • 83 Answers
SOURCE: no fire
Two possibilities left.
You have a short in your stop circuit or bent/out of place component. To check this unhook the small wire on the coil and tuck it out of the way. Put your recoil back on and try to start it. If it starts you need to follow the wire and look for any exposed wire. No exposed wire then you need to follow the mechanical portion of the on/off switch, something is not aligned right or a spring is worn out.
Next check your flywheel to coil air gap. Place a cover of a notebook or a piece of cardboard from a cigarette pack between the flywheel and the coil. This will get you the proper air gap. Then tighten down the coil. If that's not it, you have a bad flywheel. It's very rare but does happen.
Note: while you have the flywheel exposed, clean it up with light grit sandpaper (180 grit or finer) or steel wool. Rust can interfere with the electrical field.
Posted on Mar 31, 2009
SOURCE: my 455 rancher won't maintain power. I have
If you have been running ethnol mix in your saw there is a good chance that your fuel vent line is plugged. Loosen your fuel cap and start saw on its side and see if it runs. If it does you will have to clean your fuel vent.
Posted on Aug 03, 2009
  • 636 Answers
SOURCE: i have a 455 rancher i have spark (dont know if
Check to see if your ignition switch ( on& off) switch still have both wires attached. Common problem with that saw, loose or disconnected wire
Posted on Aug 17, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a husqvarna 455 rancher. It was working
Why would you pay for something and then not force them to make good? I have a large bridge for sale, CHEAP. Make you a heck of a deal.
Take it back!!!
Lou
Posted on Sep 17, 2009
dontbother10
  • 2220 Answers
SOURCE: husqvarna rancher... chain tensioner not working
A Husqvarva IPL for a 455 Rancher 2005-01, follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2005/I05000/I0501036.pdf
See print "A" (clutch cover) pn 537 28 64-01 & pn 503 21 70-10, if missing or loose these may cause your problem. If not an inspection of the parts beneath may disclose the defect.
If the bar is what can be moved pn 537 28 65-01 or 537 28 66-01 may be stripped. After I determined what parts need replacement, I would contact a local Husky Dealer. They may have these parts on hand and if not ordering through them should save you shipping and handling fees.
If your saw was not manufactured between Jan 2005 and Mar 2005 you can find your IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 15, 2010
Will not start
Do you have good compression.
If its flooding then its probably a carb issue. Strip and clean carb, check diaphrams and reset hi and low screws to standard settings. Screw both needles in and unscrew them:- H 3/4 of a turn anticlockwise and L 1 full turn anti clockwise.
Here's the breakdown for the carb. (dont use airlines to clean carbs)
Oct 14, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 rancher new filters /plug get spark wont start put gas in cylinder and wont start what am i missing
Check to see if there is a leak in the air purge bulb (primer bulb), sometimes they crack and allow air in and don't push the gas through properly. Here is the manual for your saw.
Cheers!
http://www.manualslib.com/manual/514275/Husqvarna-455e-Rancher.html#manual
Sep 10, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
455 rancher engine bogging down and starting to smoke
Make sure you are using the correct fuel mix.
Check fuel tank vent, prone to blocking an can effect the performance
Clean air filter, check Spark plug.
Oct 03, 2010 | Husqvarna 455 Rancher 555cc 35 hp 20"...
Husqvarna rancher... chain tensioner not working
HusqvarnaUSA.com
06 1500198
Lou
Mar 15, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Take it right back to repair shop and have them fix under their warranty.
It is possible the fuel hasn't got to the carbureator due to plugged fuel filter or fuel finder OR an air leak in the fuel hose.
Sep 15, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a 455 rancher i have spark (dont know if good spark) and gas new spark plug and air filter and it wont start.
Aug 16, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
77 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
