Question about GE Refrigerators
How to replace the upper light bulb on my ref
Model # GSH25JFXB WW
  • 76 Answers
Here ya go, the manual. Most fridge light bulbs are easy and quick to swap out. If it's covered by a clear cover, just remove cover and unscrew bulb. General Electric Side By Side Refrigerator Specification Sheet...
Posted on Nov 25, 2014
3 Suggested Answers
  • 41 Answers
SOURCE: Where can I order a replacement light bulb guard?
I would try Home Depot!! they have a wide veriety of light bulbs there
Posted on Sep 21, 2009
  • 1833 Answers
SOURCE: I HAVE A GE REF.
To solve this GE Refrigerator problem, check the unit asfollows: 1. The freezer section has the only cooling coil. It soundslike it is blocked with frost and thus won't let the air circulate from freezerto refrigerator.
2. There is a defrost timer, (or board), a defrost heater, and a defrost safetythermostat. Any One of these or a combination of 2 can be your problem. If youhave an energy efficient model that has electronic controls then you will havea board. The procedures for checking the circuit on a board vary bymanufacturer of the board used and manufacturer of the appliance.
3. The defrost heater always has resistance and is attached to the freezercoil.
The defrost thermostat is also attached to the heater electrically, unless itis an electronic sensor type. Sensor types have a range of resistance thatneeds to be known to check and varies slightly with the temperature of thesensor. If you can reach to the circuit board,you may find wires to the defrost heater which is fused. If you find such thinglike fuse, make sure that the fuse is not blow out, and you can also check thosewires for continuity. Hope this will help you. Good Luck.
Posted on Sep 27, 2011
How do I replace bulbs on model DS5603 Mod G electric fireplace
Do you need to replace the upper or lower light bulbs?
For both, first open the door of the fireplace. For the upper light, locate the upper bulb bracket (above the door). Bend the bracket down. Unscrew the old bulb and replace it with 7 W clear chandelier or candelabra bulb with an E12 base. Bend the bracket back up to its original position. Close the door, if only the upper bulb is out.
You will need a Phillips blade screwdriver to replace lower bulbs. Open the door (if it wasn't already open). Locate the screw that holds the log set in the center of the ember bed. Remove that screw and the log set. Locate the bulbs that are behind the log set and determine if one or both bulbs need to be replaced. Unscrew the bulb(s) to be replaced. Screw in the replacement 60 W clear chandelier or candelabra bulb with the E12 base. Replace the log set and press firmly against the glass. Replace the screw that holds the log set. Close the fireplace door.
The procedure to replace the bulbs is on page 4 of the service manual. It is also on pages 10-11 of the Owner's Manual. The documentation is available from Dimplex: http://www.dimplex.com/en/customer_support/technical_and_troubleshooting . The direct link to the service manual is http://www.dimplex.com/cms/publications/7400650000R04.pdf . The Owner's manual is here: http://www.dimplex.com/cms/publications/7206570100R09.pdf .
I hope this helps.
Jan 12, 2017 | Heating & Cooling
I need to replace a bulb in ceiling fan.The dead bulb is a 30 Watt Slyvania #FC9T9/DSW/RS I need to know the size as no one carries it.
You should be able to use one of the following as a replacement:
S6505
FC12T9/WW
32W T9 4 Pin Base Warm White Circline Fluorescent Light Bulb
Satco
S6507
FC30/SW FC9T9/SW FCL30LEX
30W T-9 9in 4-Pin
Satco
11085
FC12T9/KB
32W -Bulb: Circline T9 -Base:4-Pin G10q Single-End -
GE
20037
FC12T9/WW/RS
32W -Bulb:Circline T9 -Base:4-Pin
Sylvania
20233
FC12T9/DSW/RP
Sylvania
391227
FC12T9/SOFT WHITE
32W -Bulb:T9 Circline -Base: 4-Pin
Philips
Dec 01, 2014 | Dryers
Burned out light in refrigerator
Can be behind a plastic cover held in place by philips head screw or screws. The plastic cover can have side clips that need to be squeezed in gently to allow them to release from a slot in the ridge. Once the cover is removed, the bulb should be a screw type. Remove and then buy a replacement - the edison screw size and wattage are the most important thing to fit. Bulb shape to suit size behind the cover. Buy at WW or Coles otherwise spare parts on possibly ebay if you can be precise on model etc.
Feb 25, 2014 | Westinghouse Refrigerators
Silhouette manual
I am guessing you want to replace the bulb! Remove plastic cover which can be held in place by philips head screw or screws. The plastic cover can have side clips that need to be squeezed in gently to allow them to release from a slot in the fridge. Once the cover is removed, the bulb should be a screw type. Remove and then buy a replacement - the edison screw size and wattage are the most important thing to fit. Bulb shape to suit size behind the cover. Buy at WW or Coles otherwise spare parts on possibly ebay if you can be precise on model etc.
Jan 17, 2014 | Westinghouse Refrigerators
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
I have a twenty plus year old 18 cu ft model (top freezer style) and the 40 watt light went out. I replaced the light, but new bulb does not work. Is there a reset button??
two possibilities
1)the door switch is defective and not sending power to light socket
2) the small tab in the light socket is not contacting the bulb (the tab contacts the bulb at the bottom of the bulb) i have found that to be the case numberous times and what i have done to fix it is UNPLUG THE REF then have taken a small flatblade screwdriver and bent the tab so it makes better contact with the bulb since the cold temps will over time cause the metal of the tab to deform
Jul 22, 2011 | Kenmore 18.3 cu. ft. Top Freezer...
How do change the ref bulb on sharp ref model sj p43n - sl
Unplug the refrigerator. Remove the lamp cover by lifting up at the bottom of the cover. Then unscrew the old bulb and replace with an identical appliance bulb (Base E12, 240V, MAX 15W, T-20). This bulb is at the top center of the fridge.
The manual is available here: http://safemanuals.com/414159.php?ID=1286636&k=3942fa3f433aa4c53ff8bcb7d07ae8e8&q=SHARP%20SJ-P43N/P47N/43N/47N . You will need to review the fridge or enter a code to download the PDF. The light replacement instructions are on page 6.
I hope this helps.
Feb 25, 2011 | Refrigerators
Bulb replacement for KEMS308GSS1
Take the sample they will match one for you.
May 12, 2009 | Microwave Ovens
Light inside microwave dos not illuminate
bulb to be replaced with same similer, if it is not available please get me touch, 9791055855, india, The bulb cost is Rs: 125.00
G.K.Mahendran
Aug 01, 2008 | GE JVM1340AW/BW/WW Microwave Oven
Refrigerators Logo
196 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
