Question about Pyle Pt588ab 5.1 Ch Am/fm Home Receiver W/ 4xhdmi & Bluetooth
My pt588ab has shopped working. the owners manual said to replace broken fuse. can not find fuse. where is the fuse located? tried to locate fuse. can not find
    Top Expert:
  • Pyle Master
  • 75,581 Answers
Fuse can be located at its main power supply section circuit board.
Posted on Nov 25, 2014
2004 infiniti FX35 door locks not working
If they all quit at once then there is no power getting to them, fuse or loose broken wire or connection.
Mar 12, 2018 | Infiniti Cars & Trucks
How to change fuse of Toyota hilux 2015
  • locate fuse box
  • locate broken fuse
  • pull out broken fuse
  • push in new fuse
May 24, 2016 | Toyota Cars & Trucks
2006 f150 door locks just stoped working where would the fuse be located at ?
Your owner's manual will show location of all fuses. You don't have one? Buy a cheap shop manual and I bet you will use it many times for other issues.
Mar 13, 2015 | Cars & Trucks
My front and rear wiper work on my 2011 ml350 benz. I would like to know if where is the fuse or relay that control circuit located.
Your post says the wipers work, so what is the problem? OK, I'm sure you mean they don't work. You could buy a shop or owners manual, or simply pull every fuse one at a time until you find a bad one.
Jan 08, 2015 | Cars & Trucks
Dash board lights not working
Locate the knob or dial that controls the brightness of the dashboard lights. If the control is not immediately evident, check your owner's manual.
  • 2 Make sure the brightness control is turned on. If it is and the lights aren't working, the problem may be a bad fuse.
  • 3 Check the fuse that controls the dashboard lights (see How to Fix a Faulty Car Fuse). Replace the fuse if necessary.
    Find the fuse box (see A). It is usually located under the dashboard to the left of the steering wheel, at about knee level. Many cars have additional fuse boxes in the engine compartment. Check your owner's manual or call the dealer for the exact location(s)
  • Open the fuse box cover and locate the blown fuse. There are two ways to find the bad fuse: Look for a fuse with a melted center strip (see B, which shows two types of broken fuses). Or, if you know which device isn't working--for example, the radio--look for the fuse that handles that device. The fuse panel may have labels for each device, or the information may be in your owner's manual.
  • 3 Remove the bad fuse with a fuse puller (a small pair of plastic tweezers that should come with the fuse box). Or use a pair of needle-nose pliers.
  • 4 Check the number on the bottom or side of the bad fuse. This indicates the amperage.
  • 5 Buy a new fuse with the same amperage and push it into the slot in the fuse box with your fingers.
  • Oct 09, 2011 | 1999 GMC Yukon
    I need to replace the horn fuse in my 1997 mercury mountaineer
    In your owners manual go to the index and look for fuses then go to that page. Look for the horn fuse which should be in the fuse box under your hood around your engine, in your owners manual is should tell you where it's located. Find the fuse for it by looking at the diagram on your owners manual and then pull that fuse out. You should have replacement fuses in the fuse box that's in your car, you have to open the car door to get to it. If you don't have that fuse just take it up to auto zone and tell them you need a replacement for that fuse.
    Dec 14, 2010 | 1997 Mercury Mountaineer
    My indoor dash lights don't work. Is there a fuse or something to replace?
    yes there is a fuse. refer to owners manual for location. if no owner manual look under dash to locate the fuse box. the lid on fuse box should have location of the fuse you're looking for and the amp fuse it takes.. hope i helped !!
    Aug 23, 2010 | 1994 Nissan Altima
    Radiator cooling fan fuse location for Ford Taurus
    The cooling fan on a ford car usually does not have a fuse. The cooling fans are controlled by a relay in the power distribution box inside the engine compartment. The box is usually located near the battery. Your owners manual should have a guide showing you what each relay in the box is for.
    Jun 29, 2009 | 2001 Ford Taurus
    2001 Jag trunk release in car and on the trunk lid will not work. Still works on remote. Thought it was a fuse and according to owners manual it is located in trunk at the number one location. Relplac
    I had this problem on my 2005 s type.The problem was the valet switch in the glove box was in the lock position.i pressed it ,and now it works fine.Try this..
    Apr 30, 2009 | 2001 Jaguar S-Type
    Pyle Pt588ab 5.1 Ch Am/fm Home Receiver W/ 4xhdmi & Bluetooth Logo
    83 people viewed this question
    Top Pyle Cell Phones Experts
    richie46
    Are you a Pyle Cell Phone Expert? Answer questions, earn points and help others
