Question about 2001-2005 Dodge Stratus 2DR RT Custom Style Spoiler
My brake lights don't work all other lights do. i lowered steering colume to put dash would that cause the problem with brake lights ad blower not working
Checked fuses
    Champion:
  • 252 Answers
The brake light circuit has power all the time. the blower circuit only has power with the key on. there is a brake light switch on the lever part of the brake pedal, it might have been moved out of adjustment
Posted on Nov 27, 2014
  • 937 Answers
With more than one thing not working I would think it is a power problem. Are the brakes & blower on the same circuit/fuse? Perhaps it is blown... Or maybe something as simple as a wire got knocked loose.
Posted on Nov 25, 2014
How do I fix brake lights on my 2001 Dodge Ram? I have tail lights but no brake lights. I checked the fuse & its not blown.
do the signals lights work at the back if so then it sounds like you have a bad brake light switch or its out of adjustment. the brake lights and the signal lights work the same bulbs but are controlled by different circuits. the switch is located under the dash at the base of the steering colume were the brake pedal pushes against the switch.
Mar 06, 2014 | Cars & Trucks
Put in new starter in 2003 ford expodition and it still won't start what can my problem be won't even turn over?
Smart lock? do you have a picture of a red hand on instrument panel? With falcons quite common. Turn & hold key @ start posision, Hit dash upwards on left side of steering colum, If start = faulty smart lock module. I don't know if expodition has smart lock but probably does
Jun 15, 2012 | 2003 Ford Expedition
Headlights will work on bright but not on dim. Tail lights will work regardless if one has it on bright or dim. Daytime driving lights work. The problems must be in the light switch on the left side of...
you could have a dimmer switch problem that may need an adjustment or replacement.do you hear the switch click when you try to change from high to low,if not than these could be the problem.the switch is located on the top of the steering colume and the base of the colume under the dash.if you work the dimmer switch on the colume and put your hand on the colume under the dash you should be able to feel the rod that pushes on the switch.follow the rod down and it will go to the dimmer switch.there are 2 5/16 bolts that hold it in place that if you loosen them and push the switch up towards the steering wheel it will move it so the rod won`t have to move as far to change from low to high.if this is not the problem and you don`t hear a click then its usually a switch replacement.
Sep 18, 2011 | 1994 Chevrolet Cavalier
I have a 1996 dakota with no tail lights. The brake lights work. I think it may be a fuse, but I don't have a manual to see what fuse it may be,????
Why would it be a fuse?
You have front parking lights? Then no fuse
If it was a fuse ---would that fix it -- NO it wouldn't
Why do fuses blow?
Have you even removed the tail light housing & checked the bulbs,
or checked the sockets for ground or under truck for wiring
harness issues?
Don't need a manual to check all fuses under the dash &
in the box near brake booster
Jul 01, 2011 | 1996 Dodge Dakota
What could cause brake lights to work every now and then
I would check your brake light swich located under dash just fallow your brake pedle with a test light see if you have power going to it slitely press brake pedle see if other side of switch has power (key on car not running) if not try ajusting it by pulling on it or unscewing it if all checks out ok replace turn signal switch disconnect battery remove center part of steerring remove center bolt with steerring puller pull steering wheel with locking plate puller pull locking plate remove turn signal handle emergency button three scews holding turn signal under dash fallow steering colum disconect wires on right side (passenger side) tape a long wire to end of connector pull turn signal without pulling tape wire all the way out so you can tape it to new turn signal wire connector to be able to pull wires back down steerring colume (you might have to losen steerring colume and bracket two scews under dash four on steering colume)
Jun 27, 2011 | 1998 Dodge Ram 3500 2WD
Need to replace the turn signal flasher. the dash lites & tail lights don't work.
It is located behind the fuse block on the driver's side. When you open the drivers door you can plainly see the fuse block. (marked "FUSES") Flasher is behind that. You have to get to it from under the dash. Take out panels under steering wheel. If you get your head down by the brake pedal you can see it.
When someone changed theirs, they took out the little bracket that holds it in and relocated it to a lower place - they clipped the flasher bracket onto the little access door closest to the emergency brake (on the panel that you have to take out). Luckily the wires were long enough to enable this, so if you have to change it again, it's a lot easier.
May 10, 2011 | 1995 Pontiac Grand Am
1991 buick regal, i need instructions on how to replace a ignition switch
key switch,remove center cap and pull steering wheel off with wheel puller.disconect horn,blinkers assembly.push pin remove ignition. ignition switch, remove panel under dash un bolt steering colum lower to seat un screw ignition from top steering colum un hook rod,un plug harnees put new one on put back together
Feb 02, 2010 | Buick Regal Cars & Trucks
Tail lights and brake lights not working - not fuse - what can it be?
Brake light switch, located on upper brake pedal should be checked, that is most likely your brake light issue, but U say tail lights aren't working, but running lights do, tail lights and running lights I would consider to be the same, so can u clarify that for me? Let me know how the u do w/ brake light switch, and if u have issue w/ tail lights?
Nov 01, 2008 | 1994 Ford Thunderbird
Put the starter in and hooked up the battery and no power to the starter it dont even turn over and the battery is fully charged
sounds like sthe ignition switch. when you turn the key to run do yhe dash lights come on? there is a rod that connects to the key switch and runs down the top of the steering colume. at the top of your colume just before the brake pedal. you should see it. that is actually the switch . to access easier take lower panel off and remove the two bolts that secure the colume. the colume will come down some to give better access. you will need it. there is a couple of small screws that hold it. also check the plug for overheating,this is common. good luck
Aug 02, 2008 | 1995 Chevrolet Camaro
2001-2005 Dodge Stratus 2DR RT Custom Style Spoiler Logo
Top Razzi Vehicle Parts & Accessories Experts
Johnathan Lence
Johnathan Lence
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Are you a Razzi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
