<!-- from fixya rte -->HOW DO I CHANGE THE WICK FOR TOYOSET RCA 37 - Heating & Cooling
  • 937 Answers
Here is a good web site with lots of links to manuals and videos on changing wicks!
http://www.milesstair.com/by_make/TOYOSET_Kerosene_Heaters.html
Posted on Nov 25, 2014
Wick for a rca 80kerosine heater toyoset where can I buy one
we have no idea but I would check with all local stores that might sell that type of heater or Google it
Feb 07, 2017 | Heating & Cooling
How to take out 2 bad capacitors in my magnavox modle 50f231d/37
Get a soldering iron, some solder and solder wick. Use the wick and the iron to remove the solder off of the legs of the cap. Remove the cap. Install the new cap exactly the same direction the old one was in. With solder and iron, solder the legs on to the board. Cut off the extra length of the legs and you are done.
Apr 14, 2011 | Toymax Magnavox 37MF231D 37 in. LCD TV
Have a Dyna-Glo. Took it apart to change the wick
take the wick back out lower your nob and install wick, I hope this help you, I have made this mistake too
Oct 23, 2009 | Corona 23-DK Compact Heater
Change wick corona dkc22
u need to start at top . remove cage from top. there should be a few screws on the side of the upper case (the round upper part of the heater) once that is removed u will see the shaft the wick is attached to,the heater control are mounted here too. there should be some screws or wing nuts remove them. now lift the shaft out the wick will come with it (carefull wick wiill be wet with kerosene) remove old wick. when replacing new wick make sure to allign the top of the colored band with the top of the wick holder(the piece with the pins that adjusts the wick up & down) lower shaft & wick back onto heater and reasemble heater .be sure all controls and shut off work smoothly and correctly.
Jan 10, 2009 | Corona 23-DK Compact Heater
I need to change the wick on my dk 23 corona kerosene heater
what make and model is it? They are very simple to change,never heard of 1 "Not" lighting tho,unless you have water in tank and the wick sucked up the water...water don't burn,You can also raise the wick in their now if it has never been raised,as long as it don't have "riviet"looking things attached to sides of wick to fit it wick housing(Sears is good for that)If it a round or square heater it pretty much the same you have to remove the outer shell of heater, its always a good idea to dump out fuel first,at the base of wick their is usually 3 wing nuts or screw that hold wick Assembly in,after removing them you pull housing up to remove ,notice how the old one is on and remove and put new one on,when putting back in make sure wick fans out and goes to bottom tank,put back to gether and your done,most replacement wicks come with directions and height setting for the wick, Its not real hard as long as you pay attention
Nov 26, 2008 | Heating & Cooling
Rca d52w20
You will need some solder wick to remove the old solder. You need to heat up the old sloder with a solder iron and while its molten touch the solder wick to the solder and the wick will absorb the old solder. You will need to keep trimming the solder wick end so it will keep soaking up the old solder. Do that to all remaining pins on the flyback. The replacement flyback will not come with the high voltage wire attached so you will need to remove the wires from the flyback. This is accomplished by twisting the wire 90 degrees while exerting upward pressure. Instalation is the reverse of removal. Let me know if you need additional assistance.
May 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Change the wick
You must be very careful and follow the instructions exactly on these wicks. The pins must be inserted into the holes on the wick holder. It is also easy to install the wick holder upside down. Look for a small up arrow on the side.
You must soak your wick for at least 30 minutes, preferably 1 hour. I know it's tempting to light it right away, especially when you are freezing, but you must wait. Wicks work by using capillary action. The fuel must have time to soak in properly.
All wicks are NOT created equal. Buy good ones, under no circumstances should you buy the ones that Walmart sells. They **** and you will be changing it in a day or two. Home depot sells a decent one, but for the really good ones visit Miles Stair wick shop. He also has some good info to deal with condensation and moisture problems.
Also note these heaters will not work if they are dirty. They must be absolutely clean of all dirt and debris, every single part. Especially the parts that come in contact with the wick.
Regular maintenance, good wicks and good fuel will keep these heaters working.
Oct 13, 2007 | Corona 23-DK Compact Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
