Question about Cooktops
<!-- from fixya rte -->How do I replace a gas hob ignitor - Cooktops
  • 3,382 Answers
There are a lot of cook tops out there but we cannot guess which one you have. Give more info such as make and model so somebody can help you.
Posted on Nov 25, 2014
4 Suggested Answers
  • 222 Answers
SOURCE: Ignitor will not stop sparking on AEG Electrolux Cooker Hob
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
Posted on Jan 11, 2009
  • 842 Answers
SOURCE: The ignitor keeps sparking and won't stop.Do not
First of all, the model number is under the cooktop bottom, and secondly, this can happen due to the burner switches got wet somehow. Best thing to do is to unplug unit for 6-12 hours, allow to dry, then re-plug unit back in, this should be enough time to dry out the burner switches.
Good luck
Posted on Jul 13, 2011
SOURCE: Baumatic B40 Gas Hob : Gas not staying on.
have the same problem with two hobs and one of them is baumatic and i solved the problem, it isnt a manufacture problem but indeed its dirt problem, next the ignition there is a heat sensor that works on magnetic source you should clean the very top of it with a knife by passing it you should remove the black dirt and then brush it with a t
Posted on Sep 14, 2013
Westinghouse gas hob four burner only one igniting the other three only light with a match gas coming through but no spark
Clean the wires going to the ignitor of each burner, clean the burners as well. Chances are you have too much oil and dirt on them that is why your burners are not igniting.
Jan 27, 2014 | Cooktops
The ignitor on my AEG gas hob keeps firing. I have not spilt anything on it.
Take the switch buttons off and use a hairdryer to blow dirt out and dry up any damp. Also make sure buttons go up and down cleanly.
Mar 03, 2011 | Baumatic 27 in. B67 Gas Cooktop
One igniter produces no spark. is it bad? can i
Looks like you may have a bad ignitor. Try adjusting the arc gap. Sometimes of the ignitor is too close to the burner, the ignitor will not spark. It may also be that te burner is dirty and needs a little cleaning to allow for the electric ignitor spark to arc accross, thus producing ignition. Good luck.
Jul 14, 2010 | AEG 34942G-M Gas Cooktop
Ignitor keeps sparking not wet or dirty even when no burner on
Will most probably be a problem with your ignition box. If you want to test this try taking off the hob by undoing the screws under the burners, be very careful with these however as it is very easy to strip the thread on them, once you have the hob off try unplugging the ignitor that keeps sparking and swapping where its plugged into the ignition box with another ignitor. These ignitor can be plugged into any plug in the box so no worries there. If the ignitor keeps sparkings in another hole its the ignitor. If the new ignitor sparks its the ignition box. It will most probably be the ignition box. Is a common fault
Aug 08, 2009 | Fisher and Paykel GC913 - Stainless Steel...
Miele KM 320 G gas cooktop ignitor
I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat. The surface of the board was charred beyond repair.
To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs. If it ignites, then it is the control knob electronics. If it doesn’t, then there is something wrong with the igniter.
Note: The 2-zone Wok Burner had a different control knob that the other burners.
To open the cook top, do NOT loosen any of the Phillips screws on the sides. Here are the instructions from the user manual:
Disassembly
Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs.
In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports.
Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob.
Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals.
To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
Mar 04, 2009 | Miele 35 in. KM326G Gas Cooktop
Jan 09, 2009 | Cooktops
Creda gas hob now keeps ignighting
the ignitors have got wet usually due to cleaning. they are usually located under the rotating switches just let them dry out ( very well .....may take days) and it will work normally again
Dec 23, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
No gas to hobs
use mactches for ur gas burner if the ignition not really work.put all gas in off position b4 cleaning by using a vacium in the place of the control knob,turn off the power b4 try to clean,tnx
Nov 24, 2008 | Dacor Preference SGM466 Gas Cooktop
Is this a design fault?
What were the readings and at what points where they checked at?? is this unit Natural or LP gas??
Jan 25, 2008 | Fisher and Paykel GC913 - Stainless Steel...
we have the same problem... try removing the knob, ours works fine without the knobs ????
Dec 19, 2007 | Baumatic 24 in. B40 Gas Cooktop
Cooktops Logo
80 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
