My oce colour wave 300 have an error 4533. - Office Equipment & Supplies
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 77 Answers
This sounds like you may have a wifi or wireless connection issue. Try reinstalling the printer and drivers and see if this resolves the issue.
Posted on Nov 27, 2014
Oce TDS 300 Printer. Erore Prob. Hi I have a printer Oce TDS 300, I Get A new Erore code 8507,i want A Solution
Turn off the printer, and let it cool for an hour. The problem will return, but you may have the ability to get some emergency plots out in the mean time. The error code has to do with a thermistor in the fuser section. These thermistors are made out of a delicate ceramic and are easily broken or cracked if installed incorrectly. I would recommend that you call an authorized Oce/Canon service representative unless you want to spend several hundred dollars on incorrect, or broken thermistors you may get via other official channels. Each Oce model may have a different rating of thermistor, so just putting any thermistor in most likely will not solve your problem and may cause others.
Mar 10, 2017 | OCE Office Equipment & Supplies
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
www.fixya.com/tags/clear_error_message_replace...oce_fx_2081/.../oce
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
Oce Plot Wave 300. What does error 22701 mean?
The cause can be trying to place new programs over old one that aren't fully uninstalled or malicious software.
Scan and repair any missing or damaged window registry files use RegCure Pro
maximize and eliminate use spyhunter
Jul 25, 2015 | Office Equipment & Supplies
Our Oce Plot Wave 300 is going through toner very fast. The toner waste bottle is supposed to last through two toner bottles but fills up in less than one bottle. The OCE technician has looked at it but...
Dear
the service engineer is right, Pl. check the resolution of the printer, next check the toner cart. if possible try disconnect the ground connection to the doc.blade.
Thanks.
Mar 03, 2015 | Office Equipment & Supplies
Oce colour wave300 has an error 4533.how to solve?
Dear sir;
Let's go to reset the fuser error first. the procedure is;
1st turn power off then turn it on while holding down the "utility/counter" key, the touch the " trouble reset " when " OK " display then turn power off, wait for about 15 sec. then turn it on .
hopefully you enjoy with it.
Nov 25, 2014 | Office Equipment & Supplies
I have an Oce Plotwave 300 giving 22529 errors. Have replaced the spider board and usb cables. Any suggestions ?
Clean the paper tray, rollers, and clear any jams. The OCE Plotwave, being a large scale printer (used for posters and the like) is prone to jams and gumming up of the rollers. The error occurs when the paper doesn't move along properly and the sensors that read the surface and adjust the paper can't get it to adjust. Other issues can cause the same generic error. This includes incorrect PIN settings on the mainboard (some of these printers have PIN controllers that determine if it will read a certain way). It could be a read/write error in the USB control board (check to make sure all ribbons are correctly seated and all connections are making proper contact and are in the right ports). I suggest trying the OCE cleaning tool to see if that helps. Oc PlotWave 300.
Jul 31, 2014 | Oc Plotwave 300 Developer
Oce plotwave 300
This error will be caused by a jamb inside the cutter assembly of the lower roller drawer. Remove the two black Torx screws at the left and right sides inside the lower paper drawer. Next remove the galvanized cover. You should then be able to see the edge of the paper. Grasp it firmly with a pair of needle nose pliers and pull straight up and out. Clear your errors and commence printing.
May 03, 2013 | Office Equipment & Supplies
OCE PLOTWAVE 300 ERROR CODE 8510
JAI UN PROBLEME AU PLOTWAVE 300 MARQUE OCE
CODE ERREUR 8510
C QUOI LE PROBLEME ET C DU A QUOI ET QUESQUE JE DOIT CHANGER
MERCI
REPONDEZ PAR EMAIL
benztirage@yahoo.fr
Jun 27, 2012 | Office Equipment & Supplies
Oce plotwave 300 error 8513
Dear Sunilkudal20,
the error code referes to an electronic failure in the fuser section.
  • You can try to reset the system by turn the machine off and on.
  • Check if there is no media is in the fuser section.
If this is not solving the issue, I advice you to contact you local service organization.
If you leave your country of origin, email adress and / or your telephone number, I can ask a colleque to contact you.
Kind regards,
Jack de Weirdt
Oce Technologies B.V.
The Netherlands
Jul 26, 2011 | Office Equipment & Supplies
OCE Plotwave 300. Error Code 22701\printer.
Dec 10, 2009 | Office Equipment & Supplies
191 people viewed this question
k24674
jasbo
jasbo
