Question about Music
Iv got a Yamaha amp and it power up but cuts back out and don't know why ?
    Top Expert:
  • Music Master
  • 3,141 Answers
Generally what you're discribing is a problem with the power supply in the amp. This will not be a user servicable problem and will need to go to the shop.
Posted on Nov 25, 2014
While playing, the power cord was accidentally pulled out. When plugged back in, the amp cuts on, but there is no sound and the led lights for peak and tone selection flash.
You have probably blown a tube. This amp has one 12ax7 and one 12au7 in the vintage preamp. You can try replacing the preamp tubes, but it can be quite dangerous if you don't know what you're doing!
Sep 20, 2011 | Ampeg BA600-210 Bass Combo (with )
Yamaha psr e313 can't switch on. The adapter is
Check that your power adapter is 12 volts DC AND MOST IMPORTANT is the center pin is positive... this is reversed of MANY adapters used for pedals, etc. The current rating should be around 1.5 amps. Don't take another techs word for it... check it yourself.
Sep 01, 2011 | Yamaha PSR-E323 Keyboard
I need to find SOME kind of adequate replacement tweeter or dome or horn for a Yamaha MS150 powered speaker. (used for instruments or PA) The only specs i have are: The back of the magnet reads...
That is a very wide range cone type (oval) type tweeter that probably covers from around 2500 Hz up to 20KHz. You will probably NOT be satisfied with generic speaker... this one is special for sure. Try calling http://www.speakerrepair.com/ocsdiaphragms.html and see if you can get it reconed. Most speakers that are cheap will NOT take the power that the amp will deliver.
Jul 04, 2011 | Yamaha Music
I need to reset ( Factory settings) my Yamaha DTEXPRESS IV drum kit. Erase all input and bring it back to factory setting. Is that possible? Many thanks P.
Here is a link to the manual if you don't have one:http://www.dtxperience.com/documents/Manuals/DTXPRESS_IV/DTXPRESS_IV_Owners_Manual.pdf The procedure is on page 35.
Nov 15, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Can I sign four toms to my dtxpress iv? thanks Arpi
Yes you can my friend. You can even have up to four more I believe. Please read here that everything is easy to understand:
http://www.arrangerworkstation.com/forums/showflat.php?Cat=&Board=DTXpressIV&Number=441199&page=&view=&sb=&o=&fpart=1&vc=1
Take care and enjoy your DTXPRESS IV!
Nov 13, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
In some pictures for the Yamaha DTXpress IV Special, the hit-hat has this trigger system under it and other pictures don't.What is it?
I see pictures that show an extra device beneath the Hi-Hat and the ads mention a "stereo hi-hat controller"... on the RHH130 there is a clutch to improve the feel of the Hi Hat... I think this is what you see in some ads.
Cut and paste:
This hi-hat pad design attaches to a standard hi-hat stand. Inside of the pad is a sensor system and built-in hi-hat clutch that feels,realistic when pressed. The RHH130 also features a dual zone design consisting of pad and edge sections that offer greater dynamic realism. The pad can also produce a foot splash.
Jul 23, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Put wrong power adapter into a Yamaha DTXPRESS IV
You should immediately quarantine what you plugged in and compare it to the correct one.
IF you put too low aq voltage of the CORRECT polarity nothing should have happened.
If you put backwards polarity of any voltage the regulator is probably fried internally and possibly an input bypass cap. Also if you put an AC adapter and it wants a DC the same destruction could happen.
if you put too high a voltage, possibly the power input cap may be bad.
It appears that the correct supply is the PA3C which is a 12 volt, 700ma with positive on the center pin.
Mar 29, 2010 | Yamaha Music
My Yamaha DT125 won't start.
First thing is to check your power adapter is the right one AND is putting out correct voltage.
Buy inexpensive meter at Harbor Freight tools.
Dec 12, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Unit will not turn on. I think it was stored in a car for a while and do not know anything about this unit.
Try here:http://www.yamaha.co.jp/manual/english/result.php for the manual. Try here for advice:http://www.yamaha.com/yamahavgn/CDA/ContentDetail/Text_WithCatMenu_SC.html?CTID=410055#opt3
Oct 16, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
I want to connect my YAMAHA DTXPRESS IV SPECIAL to my PC
Any pro-audio interface with a midi input would do the trick. There are numerous products out there that offer this. You can get a simple usb midi interface, and connect the Yamaha up with a midi cable running from the midi out of the drum module to the nidi in of the interface.
one of the simpler ones:...
http://www.amazon.com/M-Audio-Midisport-Uno-MIDI-Interface/dp/B00007JRBM
Jan 24, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Music Logo
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
