Question about Sony Video Cameras
SONY DCR200 CAMCORDER turn off when I Opend th LCD but it's working when attached with AC power Cable
I facing a problem with SONY DCR200 CAMCORDER. My camcorder getting turn off when I open the LCD screen. but while attached the AC power cable it is working perfectly. Today I Replaced the battery Sony NP-FH60 (attaced with camera when purchased) with new battery NP-FV70. I recharged it aprox 6 Hr(s) and takeout the AC power Cable when I found that Re-chargable light is not blinking (fully charged) and now i swich on the camara open light is blinking camera is opened while i open the lcd Camera again Turn off, Again I re-install the battery and add the Power cable and turn on and open the LCD it is working perfectly. but without power cable it is not working. Please help me to resolve
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 31 Answers
More than likely the camera has an internal problem in the power supply section. There is an electronic switching circuit that switches between the battery input and the DC input coming from the AC adapter. Your camera requires professional servicing. One such place is AVRepair.com Home Services Consumer Camcorder Sony
Posted on Nov 25, 2014
Will not turn on or start up..Sony Handycam DCR-DVD300 DVD
Try resetting the Camcorder to the factory settings by pressing the reset button. If the issue persists, try power resetting the camcorder. To power reset, remove the battery of the Camcorder and press and hold the power button for 30 second(or turn the Power switch to ON position for 30 seconds) and reinsert the battery after one minute and check the operation. If the issue still persists, the service is required.
Jul 27, 2010 | Sony Handycam DCR-DVD300 DVD Camcorder
LCD screen working only if turn counterclockwise
make sure you open the lens 90 degrees to the camcorder.normal operation of the cam will allow you to rotate the lcd to a maximum of 180 degrees and can eve close it with the lcd screen side facing out. you can try pressing the reset button.if it still won't work try removing the battery and unplugging it from the ac adaptor for at least a minute.if still doesn't work properly,issue could be with a bad ribbon inside the lcd that loses contact when you turn it clockwise.that of course would need replacement or repair.
Dec 06, 2009 | Sony Handycam DCR-SR80 HD Camcorder
Sony dcr-hc21
Connecting flexible cable between LCD and Camera board is cracked and requires replacement.
Let me know if you want to replace it yourself to provide you part number info for that flexible cable.
May 08, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
PUEDO UTILIZAR MI CAMARA DE VIDEO SONY DCR-SR 30 COMO WEB CAM PARA MI ORDENADOR PORTATIL, ASUS?
Si puedo utilizar su camara por eso. pero, la directiones estan en engles.
Primero es para S- Video
La orta mas pavajo estan directiones para USB Streaming
How to use a Sony® camcorder as a Web cam with a composite video or S-video connection.
Solution
sp.gif sp.gif IMPORTANT: The computer must have a composite Video or S-Video input jack [FIG. 1]and compatible webcam software installed. Some computers may require a video capture card and/or sound board.
NOTE: This procedure cannot be performed when using the battery of the camcorder as a power source. If the camcorder is turned on, but not recording or playing a tape, it will automatically turn off after 5 minutes to conserve battery power. In addition, please be advised that this procedure may not work for all Sony camcorder models even when using the AC power adapter. Some models have an automatic demonstration mode that will activate after 5 minutes if the camera is turned on but not recording or playing a tape.
  1. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  2. Connect a composite video cable or S-Video cable to the VIDEO or S-VIDEO jack on the camcorder. NOTES:
    • Sony camcorders usually come packaged with composite Audio/Video cables; S-Video cables are sold separately.
    • To purchase either of these cables, check with your local electronics dealer or visit the Sony® Parts and Accessories Sales Web site or by call (800) 488-7669.
  3. Connect the other end of the composite video cable or S-Video cable to the VIDEO IN or S-VIDEO IN jack on the computer.
  4. Turn on the camera by moving the POWER switch to the CAMERA position.
  5. Remove the cassette tape from the camcorder.
  6. Turn on the computer.
  7. Start the webcam application to be used. NOTE: Contact the software manufacturer for assistance with setting up or using the webcam software.
[[Direct Accessories and Parts Center, DAPC]] How to use a Sony® camcorder as a webcam using USB Streaming. Solution
  • Not all Sony® camcorders are equipped with a USB Streaming port. For compatibility information, or if you require further assistance with any of the steps below, consult the instruction manual of your camcorder. A copy of the camcorder instruction manual is available in the Manuals/Specs/Warranty section of the Sony® eSupport Web site
  • The USB Streaming driver is not compatible with the Apple® Mac OS® operating system.
  • The computer should have a factory installed USB port and compatible webcam software, such as Microsoft® NetMeeting®.
  1. Install the USB Streaming driver on the computer from the CD provided with the camcorder.
  2. Restart the computer.
  3. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  4. Connect the supplied USB cable to the camcorder and computer.
  5. Turn on the camcorder by moving the POWER switch to the CAMERA position.
  6. In the camcorder menu, set the USB STREAMING option to ON .
  7. On the computer, start the webcam software.
Apr 06, 2009 | Sony DCR-SR30E Camcorder
LCD Screen Turns Blank with i rotate it 180 degress
Seems like the cable is damaged. You should get it fixed by SONY.
Feb 24, 2008 | Sony Handycam DCR-HC30 Mini DV Digital...
Re-attach power source
Okay I fixed my camcorder. I did a ggogle search and came across this solution which worked...I strongly suggest you do this. I whacked it two times on each side with the palm of my hand. IT WORKS NOW! I guess sony is aware of this malfunction and this is probably how they fix it....The error code is gone the tape plays. And it didn't cost me a penny.... Good luck and let me know if it worked for anybody else......
Dec 26, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
Screen won't work when camera is on
the cable of the lcd monitor have already a cut connection that why it have position that turn on the lcd...
Nov 30, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
The LCD is flashing eject indicator with error no. C:31.23 ,So before that it was showing reinsert the caset
According to Sony, the 31 problem is one that requires a power reset of the camera. Turn off the camera, remove the battery, remove the AC adapter if it is in use and then wait several minutes before re-attaching the battery and/or power and turning the camera on again.
The 23 problem is a non-Sony InfoLithium battery. Apparently these smart batteries interact with the camera. According to Sony: "Replace the battery in the camcorder with a Sony® InfoLithium battery or connect the supplied AC power adapter."
Nov 21, 2007 | Sony Handycam DCR-TRV480 Digital Camcorder
Mini DV camera decided to cease working
i recently had a similar issue and couldn't locate the power cable for a wall outlet . after trying half the electronics stores in town and multiple universal power adapters , my son left his power cord out for his ...sony play station portable (PSP) . my camcorder started up like it was new upon pluging this cord in . hahaha , sorry just looked at the date of entry on this thread . well i hope this info may be of use to someone.
Oct 03, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Video Cameras Logo
63 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
