Question about Neuspeed 48.10.02 Standard K04 Turbo Kit for 1998-2005 Volkswagon Passat Audi
Radio gas door heater blower does not work what should I be looking for
Checked fuses
  • 937 Answers
Multiple component failures suggest a power problem so good call to check fuses. Next step is to look for a wiring diagram to see if they are on the same circuit and either find the power interruption or possibly lost ground.
It is possible that a VAGCOM scan may reveal the problem as well.
Good Luck
Posted on Nov 25, 2014
Heater system
There are three fuses involved, all of which are in the fuse box in the dash.
15amp radio hvac powers the control module on the dash.
10amp hvac also powers the module.
30amp high blower fuse powers the blower motor only.
Check your owners manual for details.
Jan 25, 2014 | 2003 Chevrolet Impala
Why is the heater blower not working on my toyota 86 avalon
its more than likely a fuse. radio and clock are on the same fuse.
but not sure think that the blower is on a different fuse.best way is check them all.
Jan 19, 2014 | 1998 Toyota Avalon
Ac/heater fan doesn't work
According to my wiring diagram, the blue and white wire from the blower motor gets power from the key switch. The fan switch and resistor grounds the motor.
No blower fuse is listed.
Feb 03, 2013 | 1988 Honda Accord 4 Door
Heater blower and radio stopped working
sounds like a loose fuse or relay . check all the relays and fuses
Dec 02, 2012 | 2006 Audi A3 2.0T
99 olds heater heats,but doesnt come on
CHECK HEATER AND AC IGNITION 10 AMP FUSE UNDER HOOD JUNCTION BOX.IF ALL IS GOOD CHECK BLOWER MOTOR FUSE AND RELAY.IF ALL LOOKS GOOD. TURN ON CONTROL SWITCH TO CHECK TO SEE IF POWER GOING TO BLOWER MOTOR IF YES BLOWER MOTOR BAD.IF NO POWER GOING TO BLOWER MOTOR FUSE AND RELAY GOOD.YOU HAVE BROKE WIRE BETWEEN SWITCH AND BLOWER MOTOR OR CONTROL SWITCH FAULTY. TO GET TO BLOWER MOTOR ITS LOCATED UNDER THE DASH ON PASSENGER BEHIND GLOVE COMPARTMONT YOU DONT HAVE TO REMOVE GLOVE BOX ITS JUST BELOW IT FAR BACK.YOU NEED TURN OFF RADIO FIRST THEN DISCONNECT NEGATIVE BATTERY CABLE WAIT 20 MINUTES THIS DISABLE AIRBAGS AND THE BCM.REMOVE BLOWER MOTOR HOTWIRE IT TO SEE IF ITS WORKS. IF NO BLOWER MOTOR NO GOOD.IF BLOWER MOTOR GOOD THE AC AND HTR CONTROL SWITCH IS BAD DEALERSHIP FIX.
Dec 30, 2010 | 1999 Oldsmobile Alero
I have just replaced my thermostat housing bleed the radiator and i still got no heating the thermostat is brand new
MAKE SURE BLOWER MOTOR OPERATING IF NOT CHECK FUSE AND RELAY.ALSO CHECK HVAC FUSE THIS CONTROL HEATER + AC CONTROL SWITCH AND MODE SELECTION FOR OPENING AND CLOSING HEATER DOOR OR HEATER CONTROL VALVE AND AC+ DEFROST AIR DOOR.IF BLOWER AND HVAC FUSE OKAY.IF YOU HAVE MANUAL HEAT CONTROL MAKE SURE MODE SWITCH IS RECEIVING VACUUM. YOU HAVE TO REMOVE HEATER CONTROL SWITCH AND CHECK TO SEE IF GETTING VACUUM GETTING TO SWITCH LOOK FOR BROKE DISCONNECTED VACUUM LINES IN THE DASH AREA.IF YOU HAVE CLIMATE CONTROL.YOU COULD HAVE A FAULTY ELECTRICAL HEAT DOOR ACTUATOR.SOME CLIMATE CONTROL CARS HAS THE CLIMATE CONTROL PROGRAMMER HAS TO BE REPROGRAM BEFORE THE HEATER AND AC WILL WORK AGAIN.YOU NEED A DEALERSHIP SCANNER TO CHECK IT OUT.BUT IF YOU HAVE MANUAL CONTROL CHECK TO SEE IF YOU GETTING VACUUM.IF YOU GETTING VACUUM AT HEATER DOOR VACUUM ACTUATOR OR HEATER CONTROL VALVE EITHER ONE OF THOSE COMPONENTS COULD BE FAULTY.WARNING YOUR VECHICLE HAS AIRBAGS YOU HAVE TO DISARM THEM BY REMOVING FUSES WAIT 20 MINUTES BEFORE WORKING ON DASH AREA.YOU HAVE TO CRANK CAR UP TO CHECK TO SEE IF YOUR HVAC GETTING VACUUM.
Oct 24, 2010 | Renault Sport Cars & Trucks
Heater will not work. Blower will not come on. Checked all fuses they seem to be ok.no power at blower resistor also the radio and cd player will not work Is there a relay for asseroies
Did you check the fuses by eye or measure the voltage with a meter? There may be a separate fuse panel in the engine compartment as well as in the interior. Look for a fuse marker Accessories too. The blower, radio, etc are controlled by the access. circuit.
Feb 06, 2010 | 2005 Suzuki Reno
Electric windows and tempeture on dash are not working
IF ALL WINDOWS ARE NOT WORKING IT LOOKS LIKE.THE POWER WINDOW CIRCUIT BREAKER IS BLOWN.CHECK THE HEATER AND AC IGNITION FUSE.MAKE SURE POWER IS AT THE SWITCH.IF ALL IS GOOD.CHECK BLOWER MOTOR FUSE AND RELAY.IF THEY ARE GOOD.HOT WIRE BLOWER MOTOR IF IT WORK YOU HAVE A BAD BLOWER MOTOR SWITCH AND RESISTOR.IF BLOWER MOTOR DONT WORK.REPLACE BLOWER MOTOR.
Aug 26, 2009 | 2007 Ford Focus (3 Door) Hatchback
Heater fan not working
Yes,
there is 1 relay to work it properly,
so you ahve to check it with your regular multimeter,
this way you can do you solution ,
THNX
May 18, 2008 | 1998 Ford Contour
Neuspeed 48.10.02 Standard K04 Turbo Kit for 1998-2005 Volkswagon Passat Audi Logo
378 people viewed this question
Top Neuspeed Scuba Diving & Snorkeling Experts
ray gallant
Bill Boyd
Are you a Neuspeed Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
