Question about Whirlpool Ovens
We have a Whirlpool AKZ456/WH. I am not sure whether it is hard wired or just a 13am plug installation (like some ovens I have seen?) Normally I would remove the oven myself and have a look, but a
We have a Whirlpool AKZ456/WH. I am not sure whether it is hard wired or just a 13am plug installation (like some ovens I have seen?) Normally I would remove the oven myself and have a look, but as its at a rented property I am a bit loathed to ask the tenant & I cannot find any reference material on the Oven itself
    Top Expert:
  • Whirlpool Master
  • 44,041 Answers
It is possible that inquiry to Whirlpool could yield installation instructions you could refer to to guide removal.
Posted on Nov 25, 2014
bigg t
  • 640 Answers
SOURCE: Whirlpool oven fault f03 shown
f03 error is a sensor error.you could have taken an ohm reading on the thermistor to see if it was bad.if you replaces the t-mistor then the only other component responsible is the board.make sure all the connections on the board are clean and tight before you replace it.
Posted on Sep 29, 2007
hotuna
  • 288 Answers
SOURCE: 3 wire oven with 2 wire source
Your new oven utilizes 220 volts, but it also has some 110 volt features that need a neutral to work properly. Your old oven was wired without the neutral, probably when the house was built. There are 2 answers to your question. #1, no you should have an isolated neutral or common (same thing) wire, so it should have one. #2, if you connect the white on the new oven to the ground wire it will work. The neutral wires are all connected to the grounds at the breaker panel. Look at it if you don't believe me. The ground is there as a safety to you. if you connect the neutral (the white wire on the new oven to ground) you will be eliminating the safety feature on that appliance. So, I do not recommend you connect the white wire on your new oven to the ground wire out of the wall. But if you do it will work, you will just not have any back up protection if there ever is a problem with the electrical on that appliance. I hope this wasn't too confusing, the answer is you will need to wire the oven properly by adding another wire if you want to be completely safe and within electrical codes.
Posted on Dec 06, 2007
revamos
  • 16 Answers
SOURCE: Whirlpool Oven Shutdown Fuse
you need a new fuse it is not resetable should use renches but be carful if not comfortable call service
Posted on Apr 19, 2008
barkencoa
  • 3463 Answers
SOURCE: Installing a B1641 oven
Providing it is just a single fan oven on it's own. then it will work fine from a normal 13 amp socket.
If it is a double oven, then it will have to be hard wired into a cooker control switch box, protected with a 30amp circuit trip or fuse.
Please rate my solution to your query.
Thanks.
Posted on Feb 19, 2009
heavyice
  • 374 Answers
SOURCE: I have a whirlpool oven model no. G2P61/01SR/WH. It does not heat
The problem lies in your magnatone used for heating up the oven.You need a replacement for that.
Posted on Jun 04, 2009
Do i need to hard wire a single oven
Welcome to FixYa.
You don't HAVE to hard wire, you can install a regular oven plug and receptacle outlet, but this is the recommendation of Bosch.
**Before installing the oven have a qualified electrician verify that your home is provided with adequate electrical service and that the addition of the oven will not overload the branch circuit on which it is to be installed. A separate three-wire or four-wire single phase, 240 Volt, 60 Hz., or a 208 Volt, 60 Hz. branch circuit is required.**
I'm not sure how clear this will come out when I post it, so if it is not acceptable let me know. I can send you the complete installation guide "pdf" via email if you post an email address.
I'll watch for your reply, good luck. Thank you for choosing FixYa today for your inquiry.
Regards,
Macmarkus :)
Jan 09, 2011 | Bosch HBL 442 / HBL 446 Electric Single...
Can your provide me the Instruction manual in English language for Whirlpool Microwave Over Model No.MT 228/WH.
Please try these links and post your query.
www.devicemanuals.com/guide/???Microwave%20Oven/???Whirlpool-manuals.html
www.retrevo.com/samples/???Whirlpool-Microwave-manuals.html
Sep 27, 2010 | Ovens
Whirlpool double oven?
Yes, just go to whirlpool.com and you can download and print out a manual.
If you have any more problems, you may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
for all your appliance service and parts issues.
Nov 06, 2009 | Ovens
DIAGRAM FOR A ELECTROLUX EOG600BN
240v mains powered soloniod for the oven is probably burnt the only other possibilities are the cooling fan on top or even the reignition unit on the top
Aug 21, 2009 | Electrolux Ovens
Jun 04, 2009 | Whirlpool RBS275PD Electric Single Oven
Sep 28, 2007 | Ovens
Ovens Logo
76 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
