Question about Mercedes-Benz Mercedes ml 320 cdi headphone. . rear entertainment;
Ml320 white smoke at engin
I took it to many mechanics but they cant find the problem. please assist me because i need my car fixed
    Problem Solver:
  • 10 Answers
If the white smoke coming from your tail pipe or inside the engine compartment,if it from tail pipe you over fill your engine oil above normal level
Posted on Nov 26, 2014
Wouldn't start fitted new injector went 1 week stopped wont start agian blowing white smoke told injector going again had 4 new ones fitted still wont start. help please.
Hi my name is Brandon I am mechanical n electrical engineering technician and 4 generation mechanic its a blessing by God! But tell you little bout what I do I am not a mechanic I am the man they call when reg... mechanics cant fix it and I need more information to be right on the money but I bet that the tho... body is messes with new head gasket is they took off the cable link off and put it back to far open and the tho. Body is sticking open all way or to much and not closing but if you will email me I will get the information and tell you how to fix it but sounds like you blow a head or head gasket and have you checked fuel pressure and plugs white smoke tells me that water is in the conb... chambers
Brandon,
Mechanical n electrical engineering technician
Email address is (brandonbrownfeb1990.bb@gmail.com)
I will get back to you asap soon I can
Thanks God bless you
Jan 11, 2016 | Cars & Trucks
Why is white smoke issuing from exhaust?
White smoke is coolant burning. Check radiator for oil and check oil cap for foam if you have one or both not good.
Aug 18, 2015 | 2010 Lincoln MKT
How do i fix smoke coming off my car?
Don't drive the car. With white smoke, coming out of the exhaust, you must have blown your head gasket. It will also evaporate the cooling fluid, making the engine run without cooling.
Look for a certified repair shop, to get this repaired.
Apr 13, 2015 | 1998 Daihatsu Sirion
White smoke
You need to replace the valve stem seals in the engine.
Nov 17, 2014 | Chevrolet 2000 Chevrolet Venture
I have a 2005 mazda 6 3.0 and the engine light is on it blinks when I drive and stops when I stop it also has whitest smoke coming out of the exhaust really bad. the smell of the fumes are bad in the car....
Hi, White smoke is a leak of coolant in the engine. You will have to replace the engine head gasket. This will be an expensive job.
If you do it yourself you will have to know alot. My advice is take it to a good mechanic. Good luck
Mar 13, 2014 | Cars & Trucks
Car wouldn't start, but when it did it was smoking
One thing used many mechanics for diagnosis is: What color was the smoke?
White smoke usually means the engine is failing, and can indicate a leaking head gasklet, a cracked block, or a cracked head. This color smoke is from water and/or coolant getting into the cylinders.
Black smoke indicated too much fuel, and the engine may be "flooded", indicating a less expensidve fix.
Grey smoke indicates oil smoke from worn rings or worn valve stem seals.
The white smoke says you should have someone look at this really quickly to see if immediate attention is needed.
Be blessed
Jan 28, 2013 | Cars & Trucks
Found a crack in the exhaust manifold
transmission solenoid and misfire code unrelated
but need looking into
02 sensor should be fixed with replaced 02 sensor
egr code only if crack is close by
cast iron zorst manifolds
if the crack takes up when engine is running
not urgent
when ready source
a used manifold without a crack from a wrecker
cracks in cast iron zorst manifolds cant be welded
sucessfuly
or buy (extractors )metal exhaust manifold
if they crack... they can be welded
Mar 07, 2017 | Cars & Trucks
Hello I have a 2001 ponitac aztec and I am being to have trouble with it. When I start it up it has white smoke and shakes really bad but once I get to driving it it drive perfect. I took it to a mechanic...
SOUND LIKE LEAKING HEAD GASKET.ANTIFREEZE IS BURNING WITH FUEL CAUSE SEVERE ENGINE MISFIRE THATS WHY ENGINE SHAKING BAD ITS MISFIRING.TIME YOU NEED A NEW ENGINE WHEN ITS SMOKES HEAVY BLUE SMOKE USE A QUART OF OIL ONCE OR TWICE A WEEK.
Aug 05, 2010 | Pontiac Aztek Cars & Trucks
Car is smoking on start up, a lot of white smoke
If the engine is using oil then first remove the dipstick and run the engine, check to see if heavy smoke is coming out of the tube, this would indicate worn piston rings,if it is not so dense, yet you are using oil and it smokes bad from the exhaust, then its likely the valve seals are worn. either way, unless you have mechanical knowledge, tools etc , you need to take it to a mechanic for the engine repairs or live with the oil consumption. There are no quick fixes for engine wear.
Feb 25, 2010 | 2006 Toyota Corolla
White smoke on starting engine ml270
although mercedes recomend using synthetic motor oil im 90% sure that your mechanics mistake (putting to much oil in it) ruined your piston rings thats what the white smoke is all about!! oil is getting into the cylinders!! make him replace them for free since he caused that prblem im sure he has insurance!!
Apr 15, 2009 | 2006 Mercedes-Benz ML-Class
Mercedes-Benz Mercedes ml 320 cdi headphone. . rear entertainment; Logo
110 people viewed this question
Top Mercedes-Benz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mercedes-Benz Audio Player and Recorder Expert? Answer questions, earn points and help others
