Question about Canon imageRUNNER 2520 Laser Multifunction Printer
Error Code: E000020 for CANON IR2520 Turn the main power switch (on the main unit's left side) OFF & ON, If the machine still does not operare normally, contact your service representative with
While copying the machine scans well, and print some few pages and stop with the following message :- Turn the main power switch (on the main unit's left side) OFF & ON, If the machine still does not operare normally, contact your service representative with the error code below. e000020
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 884 Answers
Hi there
On the page below I can find an error code E002-0000 for your Canon model, but not the code you specify, as all codes seem to be in the xxxx-xxxx format.
The page is here and carries all the error codes
Error Codes Canon iR2520
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 25, 2014
Testimonial: "Thank you all; I just realized it was a fan problems, I found the three fans FK2-0360-000 are not working, I am looking for the fans so I can replace them, I hope that is the cause of the problem, once I fix all the fans I will update the findings"
4 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: ERROR EOOOOOO-OOOO IN CANON6000 PRINTERS
Hi there
E000000-0000
E000 to E004 are all to do with the fixing unit.
It can be reset.
It has been known to be caused by noise on the mains supply so a filter might keep it away.
To reset. Press the star button followed by 2 and 8 at the same time, then the star button again.
You should now be in service mode.
Select COPIER and this will give you some options along the top.
Select FUNCTION.In the list select CLEAR.
From the next list select ERROR and press ok.
Then switch off machine and back on at the power socket.
If it clears then all is ok.
Be warned!! Do not try to change any settings in service mode or clear any other function!! It is very easy to turn the machine into a cabbage.
Sorry I cant help you more than this, hope it works for you
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
sabuv
  • 113 Answers
SOURCE: The copier is saying: Turn the
The shutter open sensor does not go on. (The shutter does not open.)
1. Check the shutter home position sensor. Is it normal? 2. Check the wiring between the finisher controller PCB and the stack feeding motor and between the finisher controller PCB and the shutter open/close clutch. Is it normal? 3. Is there a fault in the shutter mechanism? 4. Try replacing the stack edging motor and the shutter open/close clutch.
Posted on May 11, 2011
  • 7 Answers
SOURCE: Error code E000007 - 0000 always appear on my Canon ImageRunner 3235 during copying and printing
The fuser film is not rotating properly.Replace it .
Posted on Jan 11, 2013
Error code E000002 in Canon IR2520
Dear
it indicates fixing unit temp could not raised to predetermined value. The following steps may be taken to clear the error.
CLEAR>ENGIN>ERRLR; and then turn OFF and then ON the power.
2.Check connection of the Connectors (Thermistor Connector and AC Connector).
3.Replace the Fixing Assembly.
4.Replace the DC_CON PCB.
Thanks
Feb 13, 2015 | Canon Office Equipment & Supplies
How to reset an ir2520 leser printer?
On the control panel press:
aditional function
aditional function
should appear ins screen "#sssw"
search with the left arrow until "CLEAR" appear on screen
press ok
search with the left arrow until "ENGINE" appear on screen
press ok
the screen displays: ERRCLR press ok again
turn off the machine from the main switch (located on the left side of the machine) for 5 seconds
turn back on the machine and try to make some copies
if problem persist replace fixing film assembly
May 03, 2014 | Canon Office Equipment & Supplies
How to fix a problem when the machine report e000001 error?
follow these steps: (with machine powered on)
1. press adittional function
2. press number 2
3. press number 8
4. press adittional function again
5. with the left arrow search for "clear" and click ok
6. with the left arrow search "engine" and click ok
7. select " ERRCLR and press ok
8. turn the machine off for about 5 seconds from the main switch.
9. power on the machine and try to make some copies.
10. if problem persist replace the fixing heater assembly
May 02, 2014 | Canon Office Equipment & Supplies
IR 3030 error code E000020-0000. I am looking to find out the what this error code means. Thanks in Advance
Hello Cg
Well, the code means that the path between the toner bottle and the toner hopper is clogged. In 5 years of dealing with this device I have never seen that to be the case and our company has a pretty big poulation.I also have been working on copiers for 23 years. I can only guess, but have you recently had a new drum put in due to poor copy quality? If so, the installer may have disconnected the connector to the developer unit. We need to turn the main power off (located on the right side.....rear like a light switch) and TRULY power off the copier. Then verify the connector to the developer unit in seated properly. Then power the copier back up. If this does not help then you have have a unique and ugly problem that may require a tech. I hope not, thats why I'm trying to help. Good luck. SPINAL
May 04, 2011 | Canon imageRUNNER 3030 Black and White...
Turn the main power switch(on the main unit's right side)off and on again. error code E000000-0000
check the power supply first. is there any voltage fluctuations? Go to service mode. Addl. function>2&8>Addl. function> select copier. function>clear>err>ok. switch off the machine, wait for 15 minutes & turn on
Apr 09, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Solution for canon ir 2520 error code E000020
E020 0000
The path between the sub hopper and the developing
assembly is clogged with toner.
1.Check the rotation of hopper motor gear. (If rotating, false
detection by the sensor is doubted. Feed the toner to the
developing unit in service mode: CLEAR>ENGIN>TNRINST.)
2.Replace the Developing Assembly Toner Sensor (TS1).
3.Replace the Sub Hopper Toner Sensor (TS2).
4.Replace the DC Controller PCB (PCB4).
SERVICE MODE:
* 28 * or MENU and #
Jun 30, 2010 | Canon Office Equipment & Supplies
E000732-0001 Error Message
E732 Error code details
  Main cause
 The cable connector has poor connection. The reader controller PCB is faulty.
Condition
 0001 The main controller PCB detects a fault in the communication between the reader controller PCB and the main controller PCB. Connectors
1) Connect the cable [1] for the environment heater.
ir7200-f04-309-01_e.png 2) As needed, connect the reader unit anticondensation heater cable [1].
ir7200-f04-309-02_e.png PLS RATE ME!!!!!!!THANKS MATE.
Sep 23, 2009 | Canon imageRUNNER 8500 Copier
Error
E000007-0000 code is Fixing Film error.
FM2-3346-000
1 FIXING FILM ASSEMBLY 120V
FM2-3353-000
1 FIXING FILM ASSEMBLY 230V EXCEPT CN
FM2-3329-000
1 FIXING FILM ASSEMBLY 230V CN
Sep 11, 2009 | Canon iR 2016i Black and White Copier
Error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Aug 20, 2009 | Canon imageRUNNER C3200 Copier
What does E000020-0010 error code mean?
e0020 is to do with there not being enough toner in the developer unit.
Firstly it may be a good idea to check/change to toner cartridge.
Switch off and disconnect from mains for the next bit.....
If ok remove the developer roller, cover is above the manual tray on the right hand side then once inside dev unit has connectors at either side, check they are properly seated. If you need to remove the dev there are several black screws around a metal plate all need removing. The roller should be black with toner. May need replacing depending on age and usage of copier.
Mar 30, 2009 | Canon imageRUNNER 7200 Copier
Canon imageRUNNER 2520 Laser Multifunction Printer Logo
743 people viewed this question
old marine
old marine
