Question about Epson Office Equipment & Supplies
Epson Aculaser C1750N printing black
Pages are black all over and dirty on reverse side
  • 25 Answers
When a color printer prints all black, it means the printer is putting either just black on the page, or all colors which appear black. The first step is to figure out if it's just black, or all colors. You can print a half page by opening the printer during a print. Then look at the page to see if there is any color in it. Try rubbing some of the toner across the page to reveal colors.
If the problem is black only, then try replacing the black cartridge. If the black toner doesn't fix it, then it may the the black laser or control module.
The all colors are on the page, then you probably have a bad control module.
Posted on Nov 25, 2014
  • 7 Answers
SOURCE: Epson Aculaser C1100 - misaligned printing
The paper tracking on the epson is not perfect. You may also notice that the paper can skew off / twist as it goes through, especially if printing on the rear side. Try printing a box aligned with all margins and you'll notice that it doesn't align with the paper edges.
Solutions:
a) The specific issue that you speak about can be compensated for in the "extended" settings on the prinproperties. You can "Offset the print" by a mm or so to adjust slight inconsistencies and get, for example two text frames to print back to back, lined up.
b) When printing the reverse side of paper, use in the general properties tab, paper type, "plain (back)". The printer then seems to compensate a bit for the fact that the now heated and curled paper needs to move through the mechanism.
Posted on Mar 24, 2008
tigertail
  • 163 Answers
SOURCE: Solution for
The four coloured dots are what is known in the trade as "Traffic Lights". They happen when the photocuductor (PCU) drum gets scratched. If you do a black only print you will only get a black dot, if you do a print with some colour in it you will get all four dots repeated at 150.41mm (PCU drum circumference) intervals. The best answer would be to replace the PCU but it is expensive. The alternative is to take out the PCU, find the scratch and try to polish it out with a very soft cloth. This will only work on the lightest of scratches. Be very careful not to scratch the drum further and avoid shining any bright light on it as it will damage the photo-sensitive surface (normal ambient light is OK).
Posted on Apr 11, 2009
ctf1800
  • 4402 Answers
SOURCE: Lexmark E232 - BLACK SMUDGING on sides of print
try replacing the toner cart. or toner leaked on the area below in which case you will need to blow it out.
Posted on Jun 04, 2009
tigertail
  • 163 Answers
SOURCE: We have just changed the
Oh-ho! The coloured spots are what is known as "traffic lights". To be sure these are the symptoms: You will have a black spot then a slightly larger gap then the three colours regularly spaced, the pattern will repeat every 150mm or so. If you print a black only page then only the black dot will appear, print with any colours and all four dots will be printed. It is caused by a tiny/slight scratch on the photoconductor (PCU) drum (usually caused by mishandling, a loose or foreign object inside the printer or even trying to print on stapled paper!). Polishing the drum using a very soft dry cloth can often help to get rid of the scratch, but remember to keep it away from any bright light as this will damage the sensitivity of the drum. The traffic lights will be in line with the scratch so concentrate your efforts in that area. Also, while the PCU is out, take a good look inside the printer for any loose or protruding objects, rotate the toner cartridges from above with the front cover closed (opening the front locks the cartridge carousel in position). I sincerely hope this helps as the only other remedy is to replace the PCU with a new one.
Posted on Jul 08, 2009
tigertail
  • 163 Answers
SOURCE: No print on the RHS of page using Epson Aculaser C1100
Two things to check,
1- clean the laser by opening the front cover, pull forward the green lever on the R/H side, take off the little panel on the R/H side of the printer and pull out/push in the lens cleaning "stick". Replace panel and push the lever back in, close the front and try a test print.
If that didn't work:
2- Open the lid, lift the orange lever and remove the photoconductor. Be careful with it as it is easily scratched. Inside the printer rotate the toner cartridges and check that the cartridge lock levers are fully locked as even a couple of millimeters can block the laser.
Hope this helps.
Posted on Sep 09, 2009
Testimonial: "Solved my problem immediately - very many thanks for the expert advice."
Hi. Epson C3000 aculaser. It is ghosting on only on black at a pitch of +/-62mm and also printing horizontal black smudges across both side of the paper at a pitch of +/- 25mm. I have totally cleaned the...
Hi Colin.
I just have had the same problem with my Aculaser C4200.
I may have found a way to solve you problem.
Just print 10 blank (without anything), and after that i took all toner's, the fuser etc. and put it back again. Printed 10 more blank pages, and printed over 200 pages with lot of tekst and colour (think that 50 pages could do it).
After 2 days everything is still ok for me.
Sep 30, 2010 | Epson AcuLaser C3000 Printer
Right hand side page print quality very poor, almost unreadable
this is cause of the lens is dirty with toner droping..
open the front cover and on the right side, there is a level for you to pull out.. at the right side of the printer, open the small cover and you will be able to find a cleaner. To clean..pull out the holder few times.. by applying slight pressure..that will clean the bottom lens..and u should be able to print out fine now..
Feb 26, 2010 | Epson Aculaser C1100 Printer
Light print on right side of page
from what you are saying, if color is fine and black is not, its most likely the black drum that is the problem. the toner is part of it. try taking the black toner out and shaking it, and putting it back in, if it still does not help, most likely it is the toner/drum.
thanks adi
May 05, 2009 | Epson AcuLaser CX11N All-In-One Printer
Prints in black are poor quality
fist of all reunisall your printer driver ....
if problem dose not fix .
it means black colour laser section have problem so you can clean lens of laser if posible and replace laser secaner.
thanks
Apr 29, 2009 | Epson AcuLaser C4100 Printer
Solution for "I have a Epson Aculaser c1100 and four coloured dots have appeared when printing. These dots are approximately 5cms from the left side of the page and print in a small vertical group. Each...
Apr 11, 2009 | Epson Aculaser C1100 Printer
Epson C1900 "ghost " images
Sounds like the transfer roller or the fuser unit may be faulty. Look at the fuser to see if the roller surfaces are dirty. If so, replace the fuser.
Jul 20, 2008 | Epson AcuLaser C1900 Printer
Your application will actually override the settings of the printer, what i can suggest is for you to check if you are using the correct page length and margin setting in your software program.
Try using Laserjet 3 emulation driver as well
Feb 08, 2008 | Epson Aculaser C1100 Printer
Epson c1100 print problem
you can try this:
remove the toner and photoconductor then tip it GENTLY from side-to-side
reseat them and print
Dec 18, 2007 | Epson Aculaser C1100 Printer
85 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
