Question about Car Audio & Video
Cdew233r wont hold settings
Unit wont hold settings when turned back on
  • 1,675 Answers
Hi Paul
sounds like the constant live is not attached, normally this can be attached to a live feed from the fuse box, not one that powers off when you turn your car off, normally on the power plug with the wires you will have a red, a yellow and a black one, black is normally the earth, red is normally power to the system, and yellow is normally the constant live, but you will have to check this with the installation guide in the hand book to be 100% sure here is the page to your handbook last page shows exactly what i just mentioned hope this helps
http://www.alpine-europe.com/fileadmin/user_upload/manuals//car_audio_manuals/CDE-W233R/OM_CDE-W233R_EN.pdf
Posted on Nov 25, 2014
Receiver wont hold memory, all levels go to zero when turned off
I'm not sure about this receiver, but it has one of three things, batteries on the back of the unit(very old school) a battery backup inside the unit, or a Super Capacitor(capacitor backup around 1f).
If you are interested in having your Denon repaired, please visit my website at audioserviceclinic.com. Thank you.
Aug 29, 2015 | Denon AVR-591
Sharp tv 70 inch wont turn on blinking 5 times fast 2 times slow
Which model do you have because the blink code differs from model to model. Did you try a hard reset? Meaning, unplug the unit, wait a minute or two, then holding the power switch down, plug the unit back in while still holding the power switch down. When it comes back on, release the button.
Jul 14, 2015 | Sharp Televison & Video
HELP!! my nokia 6500s wont allow me to get on the menu screen,, whenever it starts up,, it shows Push to talk,, and it wont go away,, ive restarted it several times,, it still shows push to talk,, push to...
Try doing this. Turn off the unit, remove the battery, press and hold the power button (while battery is out), then put the battery back and turn it back on. If that doesn't work, just repeat the steps including removing the Sim Card. Or turn on the unit without a Sim Card.
You can also try using reset codes but that would reset EveryThing back to default settings which might include losing the settings of your provider which is not recommended. But the initial step is safe to use.
Hope this helps.
Nov 16, 2010 | Nokia 6500 Slide Cellular Phone
My garmin 255w nuvi keep turning off and wont turn on
It is a good idea to perform a hard reset on your Garmin Nuvi after updating the software.
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
Dec 29, 2009 | Garmin nuvi 255W GPS Receiver
Wont turn on
• Make sure the player is not on hold. Look at the side of the unit and make sure that the HOLD switch is positioned to OFF.
• When you charge the player, does it indicate it's charging? If it does, connect the unit to the PC and poke the reset hold (at the back) with a paper clip until the lights on the unit go out. Disconnect the unit and try turning it on.
• Worst case scenario is the unit may be defective.
Hope this helps!
xo
R
Jun 23, 2009 | Samsung YP-K3 MP3 Player
My navigon 2110 wont turn on
2 things that might help...use a paperclip and press the reset button (small hole on side, you'll feel a click) hold it for 5 seconds. THEN hold down the power on button for over 10 secs (keep holding while it shows version number) and it will perform a factory reset. You will likely lose any settings and addresses, but better that than no GPS unit.
May 10, 2009 | Navigon 2110 Series Satellie GPS Receiver
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
HP Pocket Pc won't turn on
I assume you have already tried a reset with the stylus in the hole in the side of the unit, if not try it.
if you want to try to hard reset. (this will reset to the settings it came from the store with). Try one of these two techniques.
1. hold the power button while inserting the stylus into the reset hold until the screen flashes.
2. hold the power, calendar, and email button while pushing the stylus in the side/bottom of the unit until it resets.
Jan 28, 2008 | RIM BlackBerry Pearl 8100
DVD player wont show on screen
You can reset the dvd player back to the original settings by doing the following: While stopped, press and hold [QUICK OSD] [DVD-S29] or [ADVANCED DISC REVIEW] [DVD-S26] and [PAUSE] on the unit and then also press and hold [< OPEN/CLOSE] on the unit until ?Initialized? disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Jun 26, 2007 | Panasonic DVD-S29 DVD Player
Car Audio & Video Logo
51 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
