How can i enter touch screen adjustment without using the touch screen on a Konica Minolta 250?
  • 25 Answers
If it's on the network, then you should be able to access the internal web page for configuration. Type the printer's IP address in your internet browser.
Posted on Nov 25, 2014
  • Valentin M. Nov 26, 2014
    Thank you for the quick reply but i can't find the option to calibrate the touch screen via network. The problem is that the touch panel is so decalibrated that i can't enter service mode to calibrate it (i am not able to press END after i type the password)
5 Suggested Answers
SOURCE: error c2557 konica minolta 250/NEC IT2530
Reset it, start it with the right door open, go to service mode, clear the counters for drum and developer and go to functions menu. Close the right door and start immediately the F8 function. It should work.
Posted on Aug 23, 2009
  • 158 Answers
SOURCE: konica minolta biz hub C250 need to reset admin code URGENT
you cannot overide the administrator password on the konicas the default password is 12345678 try that
Posted on Oct 31, 2009
  • 44 Answers
SOURCE: bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
Posted on Nov 29, 2009
  • 19 Answers
SOURCE: how to scan to smb with konica minolta bizhub 250
create a folder on the pc you want to scan to and share the folder on the network. This must be done or the printer will not see the folder. Then register a new SMB user on the bizhub and direct it to that pc's IP and the shared folder.
Posted on Jul 28, 2010
How do I recalibrate the screen on a Bizhub 250?
Remove the Compact Flash Cover. Located Right side next to where the network cable is installed. Remove the cover, using a small screw driver or small plastic stick depress black button gently. Called the Warm Restart switch.
When "." appears at the center on the left-hand side of the screen, enter "3" from the via 10-Key Pad. Enter the 8-digit service code and touch [END]. (Default value: 00000000) if required.
Touch [Touch Panel Adjustment] from the Initial mode screen.
Following the arrow mark, touch the four points (+) sequentially on the screen using a pen. DO NOT USE A SHARPE POINT!!!!!.
Jun 21, 2016 | Konica Minolta bizhub 250 All-In-One Laser...
How to enter service mode in konica minolta develop ineo 250
Utility -> check details -> stop 00 stop 01 -. enter password 92729272 or other password and touch ok go to function and press f8 tcr auto adjust
Nov 01, 2015 | Konica Minolta Office Equipment & Supplies
Konica Minolta bizhub 250 needs re calibrated, my touch screen is off centered when i hit buttons?
take the display all a part and clean the touch screen, dirt get in between the plastic pannel and the touch display, and if it doesn't work, replace.
Sep 09, 2014 | Konica Minolta bizhub Office Equipment &...
How can i enter the service mode for konica minolta bizhurb 250/350 black an white copier and how to adjust ATDC and to run f8?
To enter service: utility/counter, counter details, stop, 0, stop, 0, 1, then 00000000. F8 is found under functions menu. ATDC is run by F8.
Aug 11, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Touch screen not working
Remove the plastic cover situated on right side upper after the LAN,USB contact and press the little black microswitch,enter 00000000 ,press END ,press touch panel adjustment,Exit.
Jul 18, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
TOUCH SCREEN
Initial Mode Function Setting Procedure
1. Remove the Compact Flash Cover [1].
2. Press the Warm Restart switch [2].
3. When "." appears at the center on the left-hand side of the screen, enter "3" from the
10-Key Pad.
4. Enter the 8-digit service code and touch [END]. (Default value: 00000000)
Initial Mode: Total Clear
Marketing Area
Image Data Clear
Clear FAX Setting
Date/Time Setting
Trouble Reset
• To adjust the position of the Touch Panel display
• Make this adjustment if the Touch Panel is slow to respond to a pressing action.
• When the control panel is replaced.
1. Touch [Touch Panel Adjustment] from the Initial mode screen.
2. Following the arrow mark, touch the four points (+) sequentially on the screen using a
pen.
NOTE
• Be sure to touch the very center of each point.
• Use care not to damage the screen surface with the tip of the pen.
Feb 12, 2014 | Konica Minolta Office Equipment & Supplies
The touch screen on my minolta 350 can't be displayed whenever i press exactly on the written box but below the written box it can normal be displayed, i figure out it must need some adjusts to put it...
10-Key Pad.
Functions • To adjust the position of the Touch Panel display
Use
Adjustment
Procedure
pen.
NOTE
Malfunction is detected c2557
Entering the service menu is simple pres utility > (touch screen) original size> (kepad) stop>0>0>stop>0>1 the password from the manufacturer is 00000000 , in the service menu select tech mode in ther yowl find the different start modes F8,F... , and you have printer select printer and acdc adjustment , pres C to clear the value and via keypad enter the desired value .
Feb 04, 2011 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta 250 Bizhub scanning Operations
You need to create a "one-touch"
This can be done in the Admin Screen without having to enter a code.
Better yet is to just yype the IP address into your browser and create them there.
The copier will need an email address in order to send them and you may need to log out and then back into the 250 as an "Admin".
Jul 21, 2008 | Konica Minolta bizhub C250 All-In-One...
jasbo
jasbo
