Question about Winco Professional Induction Cooker - 1800W, 120V
If induction cooker does not heat the pot
When we put a pot on the top of indcution cooker it does not heat the pot
    Habit-Forming:
  • 51 Answers
Induction-compatible cookware contains contains iron or has a layer with magnetic properties. Cast iron, enamel cast iron and most types of stainless steel cookware are all induction compatible (But not all types; for instance, All-Clad's MC2 line, which is made of aluminum and stainless steel, is not induction compatible)
Posted on Nov 26, 2014
    New Friend:
??? ??? ????? ????? ?? ????? induction cooker ??? ??? ?? ??? ??? ???? ?? ??? ??
Posted on Jul 09, 2015
Can you put a Greek coffee maker on a glass top new coker
There are essentially two types of Coffee Maker, one where the water is heated by an immersion element (where the water is heated by electricity), and a Boiling Water Coffee maker, where you heat the pot on a stove top element either by gas or electric heat.
(If you hve one of the electric immersion ones, don't do what a famous comedy showed and place the coffee pot on the HOT SURFACE of the cooker.
While the first pot of coffee might get warm, the idea is to heat the water from the inside, then have the coffee brewed by the machine after.
Is there a MODEL or NAME on the BOTTOM of the maker?
Google or search for these things first and get back to this board if that does not help.
If I understand your question (sort of) , are you asking if a Metal pot can be placed on the top of an INDUCTION type cooktop, where the special rings Induce a current of electricity into the bottom of the fry-pan or Stock-type pot to boil water or fry items in oils.
I do not know if there is any special method used in Greece to make coffee. Please provide details, if you were not having a 'glass' cooktop.
After some research, a 'Greek' coffee maker or 'Bricki', is a stainless steel or copper pot used to boil the water and grinds together without any extra filtering.
So, the Original Poster needs to determine what the pot is made from (The type of metal), and the other part is what type of cooker element is underneath the 'glass' part of the stove.
The Test is if you turn on the element, and watch it, does it glow red underneath or not?
If it glows red, then the heating elements are embedded into the glass and the stove functions similar to a regular electric range.
If the 'glass' portion is black and does not glow red without a pot on the top of it, then it is an INDUCTION element, and the Inductor NEEDS a metal pot on top to induce a magnetic field to make the bottom of the pot warm up.
Based on the Size of the Pots shown in pictures, it may be too small to function in your particular cooker. A model of the cooker would help. The label is usually on the door frame to the oven or a logo or name near the contol knobs.
Sep 06, 2017 | Coffee Makers & Espresso Machines
Induction cooker slowly heating what probalam
possibly wrong type of POT has to be magnetic check by placing a magnet against the bottom of pan or skillet. if it does not stick it is not for induction cooking .
Jul 16, 2016 | Kitchen Appliances - Others
New rangemaster prof.fx90 induction cooker but hob not working. - comes on if a ring is on if you touch the hob but no other lights come on + it won't heat up.
Induction stovetops wont heat until a metal pot is put on top of the element. They work through electromagnetism. These tops wont work with glass or aluminium pots. They have to be steel.
Nov 28, 2014 | Rangemaster Kitchen Ranges
Pressure cooker is not heated on induction cooker
Likely the pressure cooker base is not induction-compatible. This is the case with all aluminum pressure cookers and some older stainless steel models. Your cookware store will have a small metal plate that you can put on your induction burner to heat non-induction compatible cookware.
Nov 10, 2013 | Home
When have weight on induction cooker cooker can not cook
Remember that induction cookers are fussy that you have a special stainless steel pot or pan made just for induction cooking. It must be an 18/10 alloy (18% chromium and 10% nickel)
Oct 02, 2013 | Winco Professional Induction Cooker -...
Induction cooker
Remember that induction cookers are fussy that you have a special stainless steel pot or pan made just for induction cooking. It must be an 18/10 alloy (18% chromium and 10% nickel) If you have the correct pots then it will need a repair.
Sep 25, 2013 | Winco Professional Induction Cooker -...
The induction cooker when put on it shows E6 after about a minute or so and no heating takes place.
There is a error message there, it indicate a problem with your induction cooker. It cause a defective winding wire or circuit controllers your know induction cooker works similar to the principle of electro magnet induction, it give heat to metal cooking pot. I hope I give you a idea regarding what happen to your unit.
Mar 23, 2011 | Microwave Ovens
I have a prestige Induction cooker... a new one. When I tried to turn it on for first time, it just shows "-- -- -- --". Post this, even after placing a induction cooker compatible vessel, it...
We have a Prestige Induction cook-top Model PIC 3.0. It gives the error "-- -- -- --" and a beep when the power is turned on. Can anybody help. My email is asbhambra@gmail.com
Mar 11, 2011 | Microwave Ovens
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
I have a new induction cook top. When using for the first time I found an F or P appeared next to the element I was using. I have bought stainless steel cookware specifically to use. The user manual...
Stainless steel (or Aluminium) cookware will not normally work with an Induction cooker: Induction cooker need cookware that have a certain amount of metal especially at the bottom of the pot or pan.
An easy way to check if the cookware is suitable is to use a small (fridge) magnet: if it stick to the pot/pan then it is very likely that the pot/pan is suitable for induction 'magnetic' cooking!
Hope my small hint is of assistance and if so, vote accordigly!
Oct 03, 2010 | Westinghouse Microwave Ovens
Winco Professional Induction Cooker - 1800W, 120V Logo
485 people viewed this question
Top Winco Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Winco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
