<!-- from fixya rte -->The paper missing during the printing - Office Equipment & Supplies
  • 56 Answers
What do you mean missing ,if you mean mid feeding try cleaning the feed rollers with a damp cloth the rollers are usually located above the paper once the paper cassette is removed
Posted on Nov 25, 2014
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
Tip
Noise while printing - Diagnosis Pt 1
<p>Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.<br /> <br /> <span><b>NOTE: </b></span><br /> Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.<br /> <p>The following table describes some of the noises to be expected in a printer functioning normally:<br /> <span>Noise occurs:</span> <br /> <span>Additional information:</span> <br /> During power-up<br /> When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:<br /><br /><br /> <ul> <li> <p>Before and/or after printing<br /> <li> <p>During power on <br /> <li> <p>After the printer has been on standby/idle for some time<br /> <li> <p>After replacing a cartridge<br /> <li> <p>In the middle of a long print job (such as printing many photos)<br /></li></ul> During printing*<br /> <ul> <li> <p>Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.<br /> <li> <p>While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).<br /></li></ul> During paper ejection*<br /> At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.<br /> During copying/scanning<br /> The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).<br /> Post-printing with no additional jobs in the queue<br /> Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.<br /> Between print jobs<br /> The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.<br /> In the accessories<br /> There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.<br />
on Mar 10, 2011 | Office Equipment & Supplies
COLOR PRINTING PROBLEM
Have a look at your printer software settings. You may have it set to black and white only. There may also be a driver that was missed during installation to allow colour printing. Try reinstalling the software.
Dec 26, 2013 | HP LaserJet CP1215 Color Printer
Hp designjet 500 plus42" print miss some area
1- CHUECK THE HARDWARE OF PRINTER SHAFT
2-THE INK VAT PAPER HAS BEEN TORED
Dec 16, 2012 | HP DESIGNJET 500 InkJet Plotter Printer
Hello , I think during the firstinstallation I missed something because I do not see colors properly. are very pale. I do not know how to give a general reset.
Perhaps you need to adjust the printer settings in your computer?
Pay special attention to the print quality settings (if Draft mode is default, then you'll get weak colors), and to the paper (media) type - it won't let you print photo quality printouts on plain paper, as normal paper cannot accept too much ink (it would get soaked and colors would blend ugly).
If you put in high quality, expensive photo paper, and in the settings the paper would be set to "plain paper" - you'll get washed out colors on the printout, because the print driver in your system thinks that the paper is ordinary and limits the amount of ink used.
Please come back and leave a rating/testimonial if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 28, 2011 | HP PS C4780 All in One InkJet Printer
Page is not loading during printing
Occasionally, paper cannot be load during a print job.
Some of causes include:
• The tray is overfilled.
• The front cover has been opened during a print job.
• Paper that does not meet paper specifications has been used.
• Paper that is outside of the supported size range has been used.
If a paper jam occurs, the On Line/Error LED on the control panel lights red.
Find and remove the jammed paper. If it is invisible, look inside the printer.
Note: U would find the complete instructions along with the screen shots in the below link
http://tinyurl.com/notloading
Best of Luck
Dec 05, 2010 | Samsung ML 2010 Laser Printer
Magenta and cyan will not print on my hp officejet pro L7590 -- it started with a paper jam that was corrected - ever since then only the yellow and black will print on the paper -- printheads are good and...
Same thing happened to my printer hp L7590. Printed diagnostic, only black and yellow printed; diagnostic for printhead health Ky=good, MC= good. Only Hp products ever used. Uplugged, & discharged static, cleaned copper parts of printhead. Still no fix. On visual examination of floor of printhead compartment rectangular pad ( approx 1/4" by 1/2") is missing. I can only guess that during the paper jam, somehow the pad got caught up and went awol. Not sure what to do now.
May 26, 2010 | HP Office Equipment & Supplies
My mp830 prints and scans fine, but it won't scan dual side. it scans the first side, then starts to pull the paper back the other way, but it only goes a little ways (1-3") then the paper stops, like it...
Close the inner cover, and press the OK
button to clear the error. The paper being
printed at error occurrence will be ejected
without printing the remaining data for the
ejected paper, then printing will resume from
the next page.
Oct 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Print Quality Problem
Hi jepeto997:
Try these steps.
Check for and remove any media, jammed
paper, or debris found in the printers exit
path.
2. Did this correct the problem?
Complete. Go to Step 2.
2 1. Clean the maintenance kit wiper blade or
replace the maintenance kit.
Complete. Go to Step 3.
3 1. Check the exit area, exit frame, the
preheater, maintenance kit, and the
printhead (including the paper release blade)
to see if there is anything touching the drum
assembly.
2. Reseat any printer component interfering or
touching the drum assembly.
If there are streaks on the front side only of a
2-sided print, the preheater may be scraping
ink off the print.
2. Look for ink shavings along the streaks on
the printed paper.
3. Clean the preheater using the Control Panel
Remove Print Smears function.
4. Did this correct the problem?
Complete. Go to Step 5.
5 1. Possible weak or missing jet. Print the weak/
missing jet test print from the Control Panel,
see "Weak/Missing Jet" on page 5-33.
Complete. Go to Step 6.
6 1. Possible discolored jet. Print the solid fill test
print, see "Black, Red, Green, Blue, Cyan,
Magenta, and Yellow Solid Fills" on
page 5-40.
Complete. Go to Step 7.
7 1. The X-axis drive is not functioning correctly.
If the X-Axis Drive does not move the
printhead smoothly and evenly during
printing, vertical lines appear on the print.
For information about X-Axis Drive
problems, see "White Stripes (Pinstripes)"
on page 5-30.
Complete. Go to Step 8.
8 1. Smears on a duplex print can be caused by
the paper preheater operating at a
temperature that is too high or debris is in
the duplex roller or duplex paper path
guides.
2. Run the service diagnostics Duplex Path
test to check the paper preheater’s
temperature.
3. Is the operating temperature within the
correct value range?
guides.
temperature.
Replace the
preheater.
Replace the
electronics
module
Hope this helps
3. Clean the paper release blade.
May 20, 2009 | Xerox Phaser 8560N Laser Printer
MFC-3240C
The printer may not be scratching your printout but you may have a clogged printhead. A clogged printhead will constantly miss a spot creating an effect of a scratch printout. Please run an all inks printhead cleaning routine (2 or 3 times) and create a test page. Best Regards
Aug 20, 2007 | Brother MFC-3240C All-In-One InkJet...
jasbo
jasbo
