Question about Refrigerators
Have a Samsung 690l side by side freezer temp started flashing 20 now grudge freezer completely stopped.
    Problem Solver:
  • 16 Answers
This one is easy.... call an engineer
Posted on Nov 26, 2014
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
SOURCE: Samsung RS2533SW freezer not cooling problem
mine did the same thing. It was the mother board.
and guess what? they don't sell that motherboard anymore.
I will never buy Samsung again!
Posted on Dec 15, 2007
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Posted on Apr 20, 2009
beamerguy740
  • 65 Answers
SOURCE: rs21 samsung twin cooling
These usually have one compressor and an evaporator on each side with a fan. check the fans first then the defrost timer, heater and limit thermostat.
Posted on Sep 14, 2009
SOURCE: Freezer side tmp flashes/makes noise/inside back panel iced
The freezer side is off. The temp is flashing on the meter in front of the refrigerator. This is a Samsung RS2545SH. Does this freezer have a reset button or what shall I do.
Posted on Feb 01, 2010
Have a Samsung 690l side by side freezer started flashing 20 now completely stopped working all together. Motor stopped.
Turn the unit off, allow to stand for a day to reset itself then turn back on, if still not working, suspect compressor failed or starter on compressor needs repalcing
Nov 25, 2014 | Refrigerators
Samsung SRS583DW Fridge / Freezer not freezing
The unit has a built in defrost cycle that is controlled by the main board. You need to replace that board.
Nov 20, 2013 | Samsung Refrigerators
SAMSUNG RS275 REFRIGERATOR SOLUTIONS
Yes. check the thermostat. mine done the same thing.
Sep 01, 2012 | Samsung Refrigerators
Sr s22ftgrs bad freezer temp
HI PAVLOS.from what u say it sounds like it just needs a good good service.clean all vent holes and blow the hell out of the condenser unit .it should work.ventilate well.could be heating up and stopping long.good luck ali
Jul 12, 2012 | Samsung SRS20DTD Side by Side Refrigerator
Jan 19, 2010 | Samsung RS2630SH Side by Side Refrigerator
Samsung american fridge sn 188742bp100124K
The freezer temperature ok.
The fridge keeps freezing
Dec 06, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Samsung side by side srs580dw stops freezing and chilling
Since the temps on the display don't show correctly I'd assume something is wrong with that. If the temps are sending info out that the unit is OK and at proper temp (when it's not) then the compressor won't turn on because it thinks the fridge is cold enough. Soooo... I'd suspect that control board. It's item 48 on this diagram http://www.partselect.com/Schematics/Maytag/SS10-2.gif
Jan 13, 2007 | Samsung RS2630WW Side by Side Refrigerator
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
