Question about Konica Minolta Office Equipment & Supplies
How can i fix error C6101 of my BH-195?
After a copy error C6101 comes out.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Konica Minolta Master
  • 884 Answers
Hi
The problem appears to be with the scanner unit
Scanner home detection failure
- When the power switch is turned ON or a scan operation is completed, detecting the home position fails. 1 Turn OFF and ON the power switch.
2 Check the connector between M3-MFPB P101 for proper connection and correct as necessary.
3 Check M3 for correct drive coupling and correct as necessary.
4 Check the connector between CIS-MFPB P102 for proper connection and correct as necessary. 5 M3 operation check. 6 Change M3. 7 Change CIS. 8 Change MFPB. You can find the page here, and it gives other error codes and their solutions as well.
Error Codes Konica Minolta bizhub 195 page 2
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 25, 2014
Conika minolta bizhub 215 error code c6101
The scanner is not going back to home position, have a tech come out to check this. The scanner is what moves when scanning a document on the big glass or if using a document feeder
Apr 08, 2017 | Minolta Office Equipment & Supplies
What is konica 215 Error C6101 Repair codes?
The scanner can not not detect home position, the scanner is what moves under the big glass, is it locked??? screw installed left side of machine or some one messing with it? have tech check it out
Apr 12, 2016 | Konica Minolta Office Equipment & Supplies
C6101 error code in konica minolta 164
scanner home position. The scanner located under the big glass to the left is not finding home check that it is not located or jammed.
Jan 30, 2014 | Konica Minolta bizhub C250 All-In-One...
I have an error 6 for BH LK5900, PLEASE HELP TO FIX THE MACHINE
follow this steps and fix it. God bless you
Internal memory error
Console is not able to write and
read the internal memory
Turn off and on again to clear Error 6
Oct 10, 2013 | Bh Fitness LK5900 Voyager Avant Folding...
Bizhub 164 machine trouble c6101
hello sir i rajiv paramount inc in jalandhar pls send error c6101 codew
Apr 27, 2012 | Office Equipment & Supplies
How I can get a Nokia BH-503 driver cd?
How to connect bluetooth headset Nokia BH-503 with Windows 7
I try to use bluetooth headset with my laptop(Dell Latitude E6500) but I can't find device Nokia BH-503 in my bluetooth searching windows.
Many people found this problem. How to fix it? I think this problem is human error or device manual not cover,how to use device with computer and laptop.
if you want to find your bluetooth devices when you search bluetooth devices from your computer.
- Turn off bluetooth headset.
- Start add bluetooth devices function from your computer for search bluetooth devices.
- Hold call button on Nokia BH-503 untill the light blue and red blink (not only light bule blink).
- You will see Nokia Bluetooth BH-503 in your searching window.
- select Nokia BH-503 device and click "Next" for connect the device
- wait for windows find and install driver.If can't found driver let to check it in this web -->>>http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Nov 15, 2011 | Nokia BH-503 Bluetooth Headset
Tengo un problema q es fixed disk parameter table or BIOS error system halted que puedo hacer
Deberías tener ciertas habilidades técnicas para resolver este problema, no es sencillo lo mejor sera que lleves tu computadora con un especialista el error que te marca es un error de la memoria del BIOS la encargada de iniciar tu sistema operativo(windows) llévala al técnico.
Suerte.
Aug 25, 2011 | Compaq Armada M700 Motherboard
It wont turn on
  • Turn on CPU.
  • CPU will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
Thanks.
May 14, 2011 | Computers & Internet
When I tried to use my Canon SD870 this morning, I found the lens was not fully closed. I tried to open and close a few time and it still does the same thing, not open or close fully. I then opened it and...
A lencsét objektivet, motor hajtja. Bekapcsoláskor ha hallod a zúgását, csak halkan, vagy akár er??sen, akkor por, piszok akadályozza a fókuszálásban. Nem szabad eröltetni. Teljes szétszerelés, és tisztára takaritani. Csak szakember!!!!!!! Esetleg leveg??vel kifúvatni, kivülr??l.
Hasznos volt? értékelj
Feb 05, 2011 | Canon PowerShot SD870 IS Digital Camera
587 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
