Question about Refrigerators
Have a Samsung 690l side by side freezer started flashing 20 now completely stopped working all together. Motor stopped.
    Scholar:
  • 91 Answers
Turn the unit off, allow to stand for a day to reset itself then turn back on, if still not working, suspect compressor failed or starter on compressor needs repalcing
Posted on Nov 26, 2014
  • 958 Answers
SOURCE: samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Posted on Feb 12, 2008
  • 9 Answers
SOURCE: SAMSUNG RS20CCMS
Defrost by turning off for 48 hours and the unit will work ok (for a while)
Its a design fault common to many Samsung Side By Sides
Posted on Sep 06, 2008
SOURCE: Samsung RS2533SW freezer not cooling problem
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Posted on Apr 20, 2009
  • 323 Answers
SOURCE: Samsung RB215LABP bottom freezer ,the freezer side
20 degrees seems like a good temp for your freezer!!!
Posted on Oct 24, 2009
  • 117 Answers
SOURCE: I have a 6 yr old Samsung RS21 FCNS &
you probaly need a rs21 repair kit
have a look at these videos on youtube ...
click here samsung fridge freezer diy problems
Posted on Oct 19, 2010
Samsung refrigerator has 21 E code flashing
Freezer fan error. Most likely the fan in your freezer has stopped working completely
Jul 05, 2016 | Samsung RF260BEAESR 25.5 cu. ft. French...
Freezing compartment stopped operating. Heard motor struggling, then stopped. Frost had gathered at the back wall of the freezer to over 1/2 inch thick. Refrigerator side also gave out cooling. Cleaned...
Hi, What you are having is a defrost problem. You will need a defrost timer or on newer models the control board, also the defrost heater and the termination thermostat. You will need your complete make and model number to get the parts from a local supply house. You will need to unplug the machine. The back wall of the freezer needs to be removed. Use a blow dryer to get rid of ice buildup. Install parts. Timer is probably in the frig compartment or the board on newer models on back of frig. Hope this helps
Jan 18, 2011 | GE Refrigerators
Hi I have a Maytag fridge freezer GC2227CDFB The fridge compartment has stopped working, the lights still come on when door open, the motor seems to be working, when temp. setting is turned down to 0 the...
Your problems are exactally the same as mine. I have taken the freezer back panels off and fornd the elements blocked with ice, the upper and lower channels to the fridge are blocked with ice and obviously therefore no0 cold air is going the fridge, I have de-frosted the freezer and put back together and everything works great for 2 weeks when the same thing accurs. My settings for both fridge and freezer are on the lowest possible, but the wife does fill the freezer with too much food! I guess I need an expert in!!
Jun 16, 2010 | Admiral 26 cu. ft. Side-By-Side...
MY GE Refrigerator-Freezer , model TCX20 motor is humming!!!
There may be a build up of ice in the freezer compartment and ice touching the fanblade. The unit needs to be defrosted.
Nov 06, 2009 | Samsung RS2630WW Side by Side Refrigerator
Samsung RM255LASH - flashing error code 98 a8 after power glitch
Just happened to me with a power flash- fixed it by pressing and holding the Freezer and Frig buttons together until the screen flashed and reset. Wheww! Though it was a gonner! Fine now:) Hope it works for you!
Nov 06, 2008 | Samsung RM255LASH Side by Side...
Dec 02, 2007 | Refrigerators
SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Oct 12, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
