Safe power evo HF siel ups,battery charger off due to over temperature giving code L37.How can I restart the battery charger, the rectifier is working fine giving output to the inverter.
    Top Expert:
  • Computers & ... Master
  • 22,107 Answers
If the thermal fuse resets, when cool it will work again.
Posted on Nov 25, 2014
3 Suggested Answers
lincen
  • 6 Answers
SOURCE: Dell Laptop Battery Charer
Generally the LI ion material is nucleus in the laptop battery inside, It with suited manage power supply electrocircuit make up of laptop battery. It’s encase in the laptop inside charge and use. result in because high temperature condition work on long time. But the LI ion battery apply use condition temperature 25-30℃ confine. Therefore at laptop host computer temperature high attain 40℃ usually, so have existence blast or combustion latency safety problem and shorten use life the battery.c
That has be dead against use front happen problem and LI ion battery trait., when charge battery must take out use, has insure up to snuff on room temperature charge , as well as can avert happen blast or combustion or life reduce problem. simultaneity can let it is accomplish normally charge and discharge process the battery , It’s activation state urge LI ion battery inside is longtime. Can prolong use life the battery.
That has be dead against use two species battery voltage parameter at laptop IT trade, the product have setup switch switchover voltage, insure apply two species different voltage laptop battery charge, any more introduced commutator model the product DC output plug, can use different variety, let use charger electricize for laptop battery is safety and set one's heart at rest. And that can prolong use life the battery, best economize expenses which needless for the peoples.
It’s charge use AC to DC, DC to DC two model charger. May use in the home or office ,and car or ship or train. Usag is best convenience .
If you have need the product, please contact us
Mobile:13751018213
skype:lincen18213
Email:lincen18213@163.com
Posted on May 04, 2009
Geekman
  • 32281 Answers
SOURCE: ibm thinkpad t43 backlight inverter issue
Did you say the the video output flickers on and off when you connect an external monitor to the video output. If the inverter is faulty this would not affect the video output and the external monitor would not flicker but if the external monitor flickers it would point to a video card problem.
Posted on Jun 14, 2009
Canon Vixia HF M41 doesn't charge battery - red light flashing rapidly
If you don't use the battery for a long period of time even a new battery may become dead. You can try a new battery. If it still doesn't work then the problem is with the charging IC. u can also try a desktop charger instead of direct charger.
Mar 04, 2013 | Canon VIXIA HF M41 Camcorder
I HAVE NI LIGHTS UNLESS I HAVE BATTERY CHARGER HOOKED UP
Right if you can start the bike once you have charged the battery this is how to test rectifier without paying if its faulty it will give the bike to much voltage and will pop the bulbs if it don't do that it will go the other way n your break light or even just normal rear light will flicker wen idling as all the rectifier does is gives you a consistent voltage feed of example say 48 volts and it shouldn't drop any lower. If you can't get lights at all without being on charge your rectifier is definatley knackered as that shows it isn't sending any power/voltage to your lights as there ay nothing else that your lights would work off except the stator/generator you may have worn bushes the copper rolls round the stator or even a bad connection try that is ok its defo rectifier
Aug 16, 2012 | 1993 Suzuki VS 1400 Intruder
Compaq notebook evo n1020v won't power up. Battery charger is brand new.
Remove the main battery, now try power on, if okay the battery needs to be replaced. Sub out ram one at a time to see if you can start it.
Mar 18, 2012 | Compaq Evo N800v Notebook
Item wont power up, it give error message
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
SAFE MODE
At start up press F8 go2 SAFE MODE thn type at run chkdsk,chkdsk/f/r & thn restart pc
Else Repair XP
Else clean ram BY RUBBER
Feb 25, 2011 | Compaq Evo D510 PC Desktop
I accidently connected a 28volt charger to my evo
if the battery charger powers the computer, then i would imagine the motherboard is fine...
there should be some kind of fuse insode the battery to prevent things like this from causing them to explode.
Replace the battery
Oct 11, 2009 | HP Compaq Evo Notebook N600c
My 2008 gsxr 600 that i bought 2 days ago is running off of battery only not recharging while running. bike shuts down when battery is dead can push start but soon dies again also shows SD on the display...
Its nothing to do with the damper
The battery may not be accepting charge due to its age or condition (although as u can bump it soon after it sounds ok). Check this out with a charger & meter
There may be a bad or dirty connection somewhere between the alternator & regulator/rectifier or from there to the battery
It could also be a defective alternator winding or regulator/rectifier unit
Ride Safe
Bike-doc
Please mark this as useful (if it has been!!)
Aug 03, 2009 | 2008 Suzuki GSX-R 600
No power on
cheak the all battery points.
Jun 10, 2008 | Compaq Evo N610C Notebook
Compaq computer shutdown
This can be due to several reasons
1)The charger is dead-> Try a different charger
2)The dc powerjack on the laptop is burnt(you have to take it part and check it...
3)Last but not least it could be a battery problem..you have to get a new battery..
Mar 26, 2008 | Compaq Evo N610C Notebook
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
