Safe power evo HF siel,battery charger off due to over temperature giving code L37.How can I restart the battery charger, the rectifier is working fine giving output to the inverter.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Problem Solver:
  • 20 Answers
U can charge it by using the battery of any other device aid same power or else can change the battery
Posted on Nov 25, 2014
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: ibm thinkpad t43 backlight inverter issue
Did you say the the video output flickers on and off when you connect an external monitor to the video output. If the inverter is faulty this would not affect the video output and the external monitor would not flicker but if the external monitor flickers it would point to a video card problem.
Posted on Jun 14, 2009
Canon Vixia HF M41 doesn't charge battery - red light flashing rapidly
If you don't use the battery for a long period of time even a new battery may become dead. You can try a new battery. If it still doesn't work then the problem is with the charging IC. u can also try a desktop charger instead of direct charger.
Mar 04, 2013 | Canon VIXIA HF M41 Camcorder
I HAVE NI LIGHTS UNLESS I HAVE BATTERY CHARGER HOOKED UP
Right if you can start the bike once you have charged the battery this is how to test rectifier without paying if its faulty it will give the bike to much voltage and will pop the bulbs if it don't do that it will go the other way n your break light or even just normal rear light will flicker wen idling as all the rectifier does is gives you a consistent voltage feed of example say 48 volts and it shouldn't drop any lower. If you can't get lights at all without being on charge your rectifier is definatley knackered as that shows it isn't sending any power/voltage to your lights as there ay nothing else that your lights would work off except the stator/generator you may have worn bushes the copper rolls round the stator or even a bad connection try that is ok its defo rectifier
Aug 16, 2012 | 1993 Suzuki VS 1400 Intruder
Item wont power up, it give error message
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
SAFE MODE
At start up press F8 go2 SAFE MODE thn type at run chkdsk,chkdsk/f/r & thn restart pc
Else Repair XP
Else clean ram BY RUBBER
Feb 25, 2011 | Compaq Evo D510 PC Desktop
I accidently connected a 28volt charger to my evo
if the battery charger powers the computer, then i would imagine the motherboard is fine...
there should be some kind of fuse insode the battery to prevent things like this from causing them to explode.
Replace the battery
Oct 11, 2009 | HP Compaq Evo Notebook N600c
My 2008 gsxr 600 that i bought 2 days ago is running off of battery only not recharging while running. bike shuts down when battery is dead can push start but soon dies again also shows SD on the display...
Its nothing to do with the damper
The battery may not be accepting charge due to its age or condition (although as u can bump it soon after it sounds ok). Check this out with a charger & meter
There may be a bad or dirty connection somewhere between the alternator & regulator/rectifier or from there to the battery
It could also be a defective alternator winding or regulator/rectifier unit
Ride Safe
Bike-doc
Please mark this as useful (if it has been!!)
Aug 03, 2009 | 2008 Suzuki GSX-R 600
Compaq evo n600c battery wont work
wrong battery for it or connectoers on battery dirty could be the charger for the battery is bad and shorted battery out
Mar 26, 2009 | HP Compaq Evo Notebook N600c
Compaq computer shutdown
This can be due to several reasons
1)The charger is dead-> Try a different charger
2)The dc powerjack on the laptop is burnt(you have to take it part and check it...
3)Last but not least it could be a battery problem..you have to get a new battery..
Mar 26, 2008 | Compaq Evo N610C Notebook
EVO n600C NOTEBOOK battery not charging.
1. Check the socket u pluged it in
2. have the charger tested for continuity.
Mar 14, 2008 | HP Compaq Evo Notebook N600c
Computers & Internet Logo
David Payne
David Payne
